Welcome to the North American Subaru Impreza Owners Club Sunday July 13, 2014
Texas Impreza Club
Texas Impreza Club Forum sponsored by Gillman Subaru Houston
and Gillman Subaru San Antonio
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC > TXIC Private Classifieds
Old 05-07-2011, 05:33 PM   #1
shawns_sick_STi
Member Sales Rating: (7)
Member#: 126107
2004 STi
I have got lots of items up for grabs! Located in Houston.
NEW quick reference list! just read here to see whats for sale then scan down to read more info on the item your interested in!
02-07 (maybe 08+) WRX&STi clutch
02+ WRX clutch
02-03 WRX intercooler
tdo4 turbo STILL FOR SALE!
STi connecting rods
STi pistons
STi crankshaft
GP Moto intake
4" cone air filter
unichip pnp piggy back computer
factory turbo inlet
02-07 PSM drivers rear door with door card (doors damaged and is for parts and the glass)
04-05 STi HID balast
SEE BELOW FOR PICS AND DESCRIPTIONS
02-07 WRX&STi clutch and flywheel.
the flywheel is an act streetlite and was in the car for about 4,000 miles and was just turned so it is ready to go. the pressure plate is an exedy heavy duty unit and has some burn marks but is still 100% operational. it comes with the disk shown, but i would replace it before installing it, but it would get you rolling if you needed a clutch today, but a 3 puck ceramic metallic would be your best bet. there is no through out bearing. $300 for the whole thing, $200 for only flywheel, $100 for only clutch. FLYWHEEL SOLD
02 WRX clutch
this is an almost brand new clutch, it has about 500 miles on it. i was just installed on the car i bought, drove the car home form austin then pulled the motor for a build up and put in a new 3 puck in it. so an almost brand new OEM clutch for dirt cheap. this one does come with the through out bearing. $200
02 WRX factory air box W/brand new filter. $10 SOLD
timing belt has unknown miles on it, but is still in good condition. came off of a hybrid motor set up. $10 SOLD
factory 02 WRX intercooler with STi byepass valve and samco BPV hose. all in good working condition. $100 BPV AND HOSE SOLD, $30 for intercooler
04 STi swaybars with brand new urethane bushings for a WRX. rear urethane control arm bushings inside of the housings ready to install, and rear urethane endlink bushings. this would be a great upgrade for a WRX and the rear endlink bushings will need to be pressed in. $75 for the whole lot SOLD
shawns_sick_STi is offline   Reply With Quote
Old 05-07-2011, 05:49 PM   #2
shawns_sick_STi
Member#: 126107
2004 STi
WRX topfeed fuel injectors, they came out of a working, running car. could be used to get the core charge back on a set of modified injectors. $50 SOLD
factory TD04 wrx turbo. no shaft play and no crack buy the wastegate. $75
02-03 WRX headlights W/6000k hid kit and PNP wire harness. would like to just sell it all together but will part it out. headlights work but are hazy an extra $20 and ill polish them up for you. $100 as is $120 cleaned up. SOLD
4 STi Connecting rods good condition, came out of a motor with a blown ring land. $80
7 STi factory pistons. probably only worth there weight in scrap aluminum but if you want them $30 takes them all.
Old 05-07-2011, 06:09 PM   #3
shawns_sick_STi
Member#: 126107
2004 STi
STi crank, not 100% on the year, i think ist like 04-05, it is non-nitride and looks to be in good condition, came out of a motor with a blown ring land. $150
Eagle H beam rods, used but in good condition, have some small spots on them from sitting out, but nothing a good cleaning wouldn't take care of, and not on any bearing areas. $200 SOLD
Perrin big MAF blow through boost tube, only has cosmetic blemishes and is in perfect working order, colored in there wrinkle red. SOLD
GP Moto intake for WRX&STi its a 67mm intake so it will need tuning. $80
4" cone air filter $10 SALE PENDING
unichip PNP piggy back ecu for 04-05 (maybe other years but not sure) STi, Forester XT, or turbo baja. tune that is on it runs about 19psi and set up for an intake and turbo back set up. intake that it was tuned for is the one up above. comes with instructions and all the parts. $100 and its yours.
Old 05-07-2011, 06:28 PM   #4
shawns_sick_STi
Member#: 126107
2004 STi
factory turbo inlet $30
PSM WRX/STi rear drivers side door. has a bad dent in it and is probably no good, but the glass and motor and WRX door card are all still good. window has 35% (i think) tint on it. $100
04-05 HID balast $100
Old 05-08-2011, 01:54 AM   #5
monsta121
Member Sales Rating: (11)
Member#: 261534
PM'd you about the injectors
monsta121 is offline   Reply With Quote
Old 05-08-2011, 08:47 AM   #6
shawns_sick_STi
Member#: 126107
2004 STi
PM replyed
Old 05-08-2011, 06:19 PM   #7
shawns_sick_STi
Member#: 126107
2004 STi
bump for new quick reference! lots of stuff still for sale!
Old 05-08-2011, 11:16 PM   #8
shawns_sick_STi
Member#: 126107
2004 STi
bump for another pending sale, lets keep them moving out!
Old 05-09-2011, 12:18 PM   #9
balls out baja
Member Sales Rating: (1)
Member#: 251561
05 Baja Turbo
Default Intrested in the Td04
I have never bought anything off of here so im not exactly sure how to go about it.
If you still have the TD04 for sale Ill take it!
balls out baja is offline   Reply With Quote
Old 05-09-2011, 12:40 PM   #10
shawns_sick_STi
Member#: 126107
2004 STi
I'll send you a private message then we will talk details there.
Old 05-10-2011, 12:10 PM   #11
shawns_sick_STi
Member#: 126107
2004 STi
Get things sold bump
Old 05-11-2011, 12:04 AM   #12
damick
Member#: 266242
2004 WRX
i'm interested in the turbo if you still have it.
damick is offline   Reply With Quote
Old 05-11-2011, 03:24 AM   #13
shawns_sick_STi
Member#: 126107
2004 STi
Still for sale.
Old 05-11-2011, 08:03 AM   #14
damick
Member#: 266242
2004 WRX
Originally Posted by shawns_sick_STi View Post
Still for sale.
do youknow the mileage on the turbo? is this from your own car? i'm assuming an 02 or 03..?
Old 05-11-2011, 08:17 AM   #15
powerwagon
Member#: 278381
We don't know the miles & yes it came out of my 02 wagon in good working order
powerwagon is offline   Reply With Quote
Old 05-11-2011, 11:26 AM   #16
Mauricio
Member#: 2823
only 1 oem ballast?
Mauricio is offline   Reply With Quote
Old 05-11-2011, 12:38 PM   #17
shawns_sick_STi
Member#: 126107
2004 STi
Originally Posted by Mauricio
only 1 oem ballast?
Yep only one. One of mine quit working to I ordered a new one. Then mine started working again the next day. That was 2 years ago so it's time for it to go.
Old 05-11-2011, 04:45 PM   #18
shawns_sick_STi
Member#: 126107
2004 STi
Sway bars sold bump
Old 05-12-2011, 12:51 PM   #19
shawns_sick_STi
Member#: 126107
2004 STi
Bump!
Old 05-14-2011, 09:52 AM   #20
shawns_sick_STi
Member#: 126107
2004 STi
Morning Bump!
Old 05-17-2011, 11:49 PM   #21
twistymaster
Member Sales Rating: (5)
Member#: 279743
Default Turbo ?
What is the condition of that turbo?
twistymaster is offline   Reply With Quote
Old 05-18-2011, 11:56 PM   #22
shawns_sick_STi
Member#: 126107
2004 STi
Pm sent
Old 05-22-2011, 05:08 PM   #23
shawns_sick_STi
Member#: 126107
2004 STi
Buy my stuff!
Old 05-22-2011, 06:24 PM   #24
Tabachoy_57
Member Sales Rating: (8)
Member#: 224166
PM'd you
Tabachoy_57 is offline   Reply With Quote
Old 06-05-2011, 05:23 AM   #25
shawns_sick_STi
Member#: 126107
2004 STi
Bump!
Garage Clean Out, New and used parts! Mann Engineering BAIC Vendor Classifieds 13 12-28-2011 07:32 PM
Garage Clean out: Lots of STi Parts HIREN Engine/Power/Exhaust 72 12-16-2011 11:16 PM
Garage clean out, lots of parts, CHEEP YO! UK-Wagon SCIC Private Classifieds 49 04-03-2010 09:13 PM
Cleaning Out, Lots of Misc items gosu SWIC Private Classifieds 8 11-24-2008 09:34 PM
Cleaning the garage/house out, lots of random stuff you might want. yo14jman Non-Subaru Stuff 10 10-21-2007 10:24 PM
