Old 07-20-2002, 08:45 PM   #1
JST
Member#: 5808
1999 RS-T/Legacy
sylver/black
Question throtle body & head porting???
Did someone have a over size throtle body and head porting on there RS-T???
Did give it give allot of power to the car???
Do you think just a throttle body over size will give a little kick to mi engine???
In what range on HP do you think it goes???
JST is offline   Reply With Quote
Old 07-20-2002, 10:26 PM   #2
redmeanie
Member#: 15702
2001 2.5 RS-T LINK'D
911verion2.0TT (soon)
Head Porting- will increase performance slightly without any other modifications...
Throttle Body- is fine as it is....It is already pretty large for the displacement of our engines anyway....
I suggest you look into it a little more before making any desicions and talk to a tuner who knows about SUBARUS...
I am working on a buildup but Im using a spare engine and doing all internals and Port and polishing the heads as well as a mild cam keeping the Stock Throttle body by the way....
Look into getting a standalone, or some injectors for a easy gain in power...
BUT thats just my 2 cents
redmeanie is offline   Reply With Quote
Old 07-22-2002, 02:47 PM   #3
jeff22
Member#: 7534
99 impreza rs-t
rally blue pearl
I prrted and polished my own heads, Had my ixtake extrude honed and throttle body bored. I got an a n/A motor about 1.2 secs better in the quater mile than without. With the turbo who knows but it pulles hard!
jeff22 is offline   Reply With Quote
Old 07-22-2002, 10:59 PM   #4
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
How much were you able to bore out the TB? There's only like 2mm of extra material around it.
Impreza Rider is offline   Reply With Quote
Old 07-23-2002, 12:45 AM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
RiftsWRX and I spent some time on my TB and managed to knife-edge it from 52mm to 57mm at the edge. Made a massive difference NA, not sure if it'll help turbo or not, though.
Old 07-23-2002, 08:24 AM   #6
jeff22
Member#: 7534
99 impreza rs-t
rally blue pearl
I sent it out to cobb and had them do it, (when they were doing it). It is alot bigger now i'm not sure how big it is i didn't measure it, but i did have to bore the inlet of my intake manifold to get it to flow and not hit a step.
V3 STi Intake Manifold & Throttle Body & Coil Pack dr3w Engine/Power/Exhaust 2 01-06-2010 07:41 PM
03 throttle body, perfect for porting jack_a SCIC Private Classifieds 1 11-03-2007 09:45 PM
Effect of bigger throttle body & extrude hone intake manifold on a low 300 whp EJ257? JDM addict Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 03-22-2006 06:55 PM
Questions about throttle body & suspension GTWagon_Phreak Legacy Forum 39 09-23-2005 09:17 AM
WTB: WRX Throttle Body & IAC valve TmR197 Private 'Wanted' Classifieds 2 01-19-2005 08:48 AM
