Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 01-31-2013, 01:14 PM   #26
SubySal
Member#: 43011
2004 Impreza RS
PacificaBlue/BlackTarmacs
Yea I was pretty much screwed under the old rule too.
I see your point, but you don't find having to put ballast on a engine mount a bit silly?
SubySal is offline   Reply With Quote
Old 01-31-2013, 07:37 PM   #27
Davidss
Member#: 27446
For you, on your car, in your situation the rule does seem silly. But the rules aren't written just for you. On other ST cars people have already been pushing the boundaries by drilling holes in the mounts until they are basically swiss cheese. Or on the Hondas it is possible to remove one of the mounts completely which saves a good bit of weight at the expense of reliability. We all want to keep the ST category streetable, fun, and reliable and the motor mount weight rule is part of that.
Davidss is offline   Reply With Quote
Old 01-31-2013, 08:20 PM   #28
polyol
Member#: 73422
04 STi
JVP
Yeah, I have cusco...they are rock solid...
polyol is offline   Reply With Quote
Old 01-31-2013, 08:22 PM   #29
SubySal
Member#: 43011
2004 Impreza RS
OK I hear ya. I already got a reply from the SCCA so I'll see if I can figure something out with them.
Old 02-04-2013, 05:12 PM   #30
AustinTX
Member#: 23954
14 BRZ
'11 Legacy 3.6R
I went ahead and got a pair of Torque Solution mounts. I'll figure out how to ballast them up when they arrive.
AustinTX is offline   Reply With Quote
Old 02-07-2013, 06:08 PM   #31
AustinTX
Member#: 23954
14 BRZ
'11 Legacy 3.6R
The Torque Solution mounts arrived, and each one is 8.5oz lighter than the OE counterpart. I'm adding the weight with longer bolts and a stack of large washers
Old 02-07-2013, 07:12 PM   #32
em99sport
Member#: 172670
2011 STI 5-door
Thanks for the update. Good to know it isn't much difference.
em99sport is offline   Reply With Quote
Old 02-11-2013, 03:00 PM   #33
AustinTX
Member#: 23954
14 BRZ
'11 Legacy 3.6R
Motor mount installed. Launching is much better with less wheel hop/engine lurching. vibration is significantly more than Group N mount when below 1000RPM. Note sure if i will leave it on or not yet. Feels more like a racecar, though.
Old 02-12-2013, 11:08 AM   #34
piknockout
Member#: 192173
2006 STU prepped STi
Sponsored by Agile Auto
Well if you decide you don't want to keep them, just mail them to me.
piknockout is offline   Reply With Quote
Old 02-12-2013, 08:34 PM   #35
Deuce Cam
Member#: 130444
'85 AE86 GTS
Ballast shouldn't be a problem since the cusco mounts weigh more than stock due to the different design which has a bunch of extra steel.
Deuce Cam is offline   Reply With Quote
Old 02-21-2013, 12:37 PM   #36
drclaw09
Member#: 90246
Drilling holes in motor mounts sounds like a terrible idea...
drclaw09 is offline   Reply With Quote
Old 02-21-2013, 01:51 PM   #37
Aczwild
Member#: 71721
'98 RS (Race Car)
'13 GMC Sierra (Tow Rig)
How long/well have the Cusco mounts lasted for those that have them? Number of auto-x's, years, etc. Currently swapping my SM prepared RS and I'm torn between MSI solid mounts (can be done in SM) and the cusco ones as I'd like to be able to drive this on the street from time to time (dont care about the extra NVH from either mount)
Aczwild is offline   Reply With Quote
Old 02-21-2013, 04:44 PM   #38
MSI
Member#: 95419
I think the main difference is the MSI mounts will lower your engine 10mm. Be carefull as some aftermarket up-pipes on the turbo cars may not clear the subframe. I have come across that once a few years back. The majority of manufacturers have no issues though.
Are the cuscos a solid or urethane mount?
-mark
MSI is offline   Reply With Quote
Old 02-21-2013, 05:26 PM   #39
Aczwild
Member#: 71721
'98 RS (Race Car)
They are a "hybrid" with internal bushings (best way I could describe them)
(pics from Rallysport direct)
I'm actually considering ordering those and designing/machining my own based on theirs which would be stronger
Old 02-21-2013, 05:36 PM   #40
Deuce Cam
Member#: 130444
'85 AE86 GTS
-mark
The Cusco bushings are rubber.
Old 03-03-2013, 10:22 AM   #41
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Here are the Cucso mounts for the FA motor in the BRZ.. Steel/rubber mix. some are already questioning the legality of them.. :/ sigh..
Bill
Old 03-05-2013, 10:56 AM   #42
silverhks
Member#: 242402
Bill:
Under the new rule, the only legality question should be weight. You might have to ballast them up...
silverhks is offline   Reply With Quote
Old 03-05-2013, 08:33 PM   #43
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Originally Posted by silverhks View Post
Bill:
yeah going to weigh them this weekend.. Personally, don't see a problem.. these things are heavy.. But to make sure.. I will post up the pics for both..
Bill
Old 03-08-2013, 01:42 PM   #44
silverhks
Member#: 242402
Has anyone weighed the msi mounts? How much are they under weight?
Old 03-08-2013, 02:20 PM   #45
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
Don't they lower the engine by 7mm?
mccanixx is offline   Reply With Quote
Old 03-08-2013, 08:05 PM   #46
yazel
Member#: 215344
2004 STU STi
Dem TiC stickers tho!
Yep ^
yazel is offline   Reply With Quote
Old 03-09-2013, 10:23 AM   #47
Aczwild
Member#: 71721
'98 RS (Race Car)
I was wondering about that, if the engine is lowered by 7mm (granted that really isnt much), does it put an increased load on the trans and trans mounts, or cause any issues?
Old 03-09-2013, 10:41 AM   #48
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
Since the trans is not generally solid mount I would wager it would be more than fine with the 1/4" change.
I was merely pointing out a possible legality issue for the class being discussed.
Old 03-09-2013, 02:24 PM   #49
yazel
Member#: 215344
2004 STU STi
Definitely not legal:
From the ST section of the rules:
J. Any engine or transmission mount is allowed provided it attaches
only to the original mounting points, does not relocate the engine/
transmission (other than incidental to changes in compliance material),
and weighs no less than the OE mount. All components between
the engine/transmission and the mounting structure are considered
to be part of the mount assembly.
Old 03-10-2013, 11:42 AM   #50
silverhks
Member#: 242402
My thoughts were actually to use washer/ spacer of some sort to raise it back up. As it comes it is definitely illeagal for stu
Also, does that wording allow any pitchstop to be used?
STU motor mount problem-suggestion inside Mojambo Autocross 7 03-22-2010 12:23 AM
STU Legal? OEM Fog Bezel, No Light (Ram Air) S1MPSONS Motorsports 13 05-20-2008 05:56 PM
APS inlet STU legal? pignoseSTI Motorsports 14 02-15-2008 10:06 AM
Heat Wrapped Up-pipe/downpipe, STU Legal? S1MPSONS Motorsports 4 11-06-2007 01:19 PM
Check setup for STU legality and competitiveness Call_me_Tom Motorsports 19 07-21-2006 06:53 PM
