Old 07-20-2002, 11:44 PM   #1
tcarter
Member#: 12366
Default HELP. I don 't know what wire to tap for my autometer boost gauge
I have everything setup and ready to rock. Boost is reading correctly. I just don't know what wires to tap into for the electrical side of it. I need to know a 12V and a ground..
Please help!!
thanks
Todd
tcarter is offline   Reply With Quote
Old 07-21-2002, 12:04 AM   #2
tcarter
Member#: 12366
Someone know the right color wires behind the fuse box?
It is a 2002 WRX.
wires wires wires.. hmmm.. which one to pick?
BUMP !!
Old 07-21-2002, 12:14 AM   #3
mitch808
Member#: 10228
2002 Subaru WRX
Find a bare metal piece in the dash for ground... For the 12V+ pick a fuse that is on when the ignition is on. Radio, ACC, ignition, etc. You can more or less jam it in the fuse hole and plug the fuse on top of it.
mitch808 is offline   Reply With Quote
Old 07-21-2002, 12:17 AM   #4
tcarter
Member#: 12366
I will give that a shot.
Thanks
Old 07-21-2002, 12:28 AM   #5
zsurfrin
Member#: 11034
Platinum Silver
there is a harness that comes out of the radio that is made to have the guages hooked to. It has positive and negative outputs. It doesn't matter how you hook it up, but if you use the radio wiring harness, you will be able to dim your guages with the dimmer switch. if you find bare metal for your ground it won't allow you to dim and the light will be on full blast all the time. i like the ability to dim my gauges along with my guage cluster and radio.
Just my 2 cents
zsurfrin is offline   Reply With Quote
What wire to tap for MAF to Snow Controller Irishman Water/Methanol Injection, Nitrous & Intercooler Cooling 2 08-11-2007 10:22 AM
What wires to tap for boost gauge illuminatin hotshot172 Newbies & FAQs 9 08-06-2005 02:01 PM
What wire to tap into for dimming dash lighting? mpaone Electrical & Lighting 4 10-18-2004 04:19 PM
Which wire to tap for gauges? Hit Man X Electrical & Lighting 9 06-08-2004 07:24 AM
