#1 |
Member#: 279134
Vehicle:2011 WRX STI sedan Blue |
Hello Guys
I just loaded the Cobb stage 1 OTS map and I was wondering if I get my car pro tune, this is going to be a big difference? Its worth it? I only have a catback (no DP). Thanks I feel like my 2007 stage 2 was quicker, maybe the power/torque curve was totally different.
#2 |
Member#: 149637
Vehicle:2010 STI SE WRB |
Of course it will be different. But would be a waste of money for how your car currently sits.
#3 |
Member#: 187013
Vehicle:2012 Red Menace |
First, a protune will always be better than an OTS tune. You need to decide if you want to spend the $XXX.xx to have it done. Personally id wait until stage 2.
Second, OBVIOUSLY your stage 2 2007 STi was faster. Its basically the same motor and turbo. What makes you think stage 1 will be quicker? |
#4 |
Member#: 279134
My 2007 was just a WRX stage 2. So at Stage 2 on my STI, It will be a good idea to Dyno tune the car?
#5 | |
Member#: 172698
Vehicle:11 STi Stg2 E85 02 v8 Spec C E85 |
Generally you can get a little more power and some added drivability with a pro-tune but it partially depends on the tuner and how they tune it. If they tune it aggressively you can see a good amount more power but it will put more strain on the motor. Staged OTS tunes are designed to be very conservative but they don't make as much power and are obviously not dialed in perfectly for each car. Good luck. |
#6 |
Member#: 281938
Vehicle:2009 WRX DGM |
dont forget your going from a 5spd, to a 6spd.. different gearing etc etc... i would do the mods necessary for stg2, and if your still not feeling good after that, then i would research into an ebcs and protune..
#7 |
Member#: 279134
Thanks for the input.
| Thread Tools | |
| Display Modes | |
| AEM Intakes for sale! (with 2008+ STi OTS maps!) | Cobb Tuning | TXIC Vendor Classifieds | 9 | 08-27-2010 12:10 AM |
| Cobb Stage 2 OTS map vs. Perrin Stage 2 OTS map | liljon350 | AccessPort | 4 | 08-09-2009 09:01 AM |
| '08 STI stock with AP base map vs Pro tuned | alfriedesq | Proven Power Bragging | 8 | 10-24-2008 03:28 PM |
| 2008 WRX: Stage 2 RalliTEK map vs. Pro Tuning | awd_dreamin | AccessPort | 1 | 08-19-2008 02:41 AM |
| PDX Tuning Protune OTS maps vs. Cobb Stage 2 93 Octane! | kinada423 | AccessPort | 285 | 12-23-2007 03:07 PM |
