Old 05-10-2011, 01:34 AM   #1
Gclark
Member#: 192352
1994 Legacy STI
ლ( ಠ ಠ)
Default Down and Dirty How To: Evo Brembos on a Subaru
So why Evo brembos?
1. Cheaper
2. Their the same thing as Subaru brembos.
3. I like red
4.
Couple notes:
Sti pads work with Evo brembos
Get the hardware kit from napa for the sti, Ill post the part number later. It was 25 shipped and everything fit fine except for the pins. More on that later.
It was fairly easy, took a few hours, could have been faster if I didn't have to run to the store.
Use Spec B rotors, should be about 12.5in. STI ones are a little to big.
Step 1:
Jack car up, jack stands, remove wheels, etc.. Use two jacks because your car is too low
Step 2:
Remove stock calipers, rotors, and unbolt brake line. If you need a refresher
http://www.northursalia.com/modifica...s/vbrakes.html
Step 3:
Grind down the flange of the caliper(angle grinder), just alittle bit, .1in, enough to make it flat.
Step 4:
Step 5:
Drill out the spindle. I used a big drill called the Hole Hawg, but any drill should work fine. The reasons for this is because the holes on the Evo brembos are further apart then Subaru ones.
Drill this one and the bottom one, just enough so you can slide the bolts in.
Step 6:
Grind down the spindle, .1-.2 of material, this allows the caliper to centered on the rotor. I took off to much so I had to use washers.
http://www.rs25.com/forums/f105/t101...ml#post1615534
Step 7:
Install the rotor and calipers, slide the pads in, push the pins in, put the Jesus clip in, and put the caliper on. Screw on the bolts, which should be a 19mm bolt. Reatch the brake line, which fits the caliper perfectly. Bleed brakes, and go break em in.
Pads difference:
Evo bolts are bigger then Subarus, here's the new size:
Napa brembo hardware number:
Yay!
I'll get some better pictures of them tomorrow, and I'll let you know how awesome they are.
CN's: Evo brembos fit on subarus with alittle bit of cutting and drilling. Brings in mad ladies.
Is this when I say haters gonna do stuff?
Gclark is offline   Reply With Quote
Old 05-10-2011, 01:39 AM   #2
Kentrik
Member#: 125937
03 WRX I do not
like your tweed, chap.
I demand a full parts and prices list right meow! This is an awesome idea. Steve and I were toying with the idea of doing something like this with some remade brackets and some Z33 calipers, but I think this would work better.
P.S. How is "not Utah"? It's been a while since I've seen you, buddy.
Kentrik is offline   Reply With Quote
Old 05-10-2011, 01:52 AM   #3
Gclark
Member#: 192352
1994 Legacy STI
ლ( ಠ ಠ)
Hey Kentrik! Not Utah sucks, I miss you ladies.
Evo Brembos shipped: $320, got them off evolutionm.com
Caliper Hardware $25, napa
Bolts: $10ish, home cheapo
Hawk Pads: $100, rallysportdirect
Centric Rotors: $120, off of wrxbrakes on here, aka kns brakes. Great guys.
So $575 for brembos, with good pads and rotors. Not bad.. If someone was to buy used rotors and pads you could save even more money.
Here's the original thread I was inspired by:
http://www.rs25.com/forums/f105/t101...-yes-suby.html
Old 05-10-2011, 01:56 AM   #4
Kentrik
Member#: 125937
03 WRX I do not
You should come back soon. Definitely check out the crazy stuff that Glenn has done to his OBS. It's seriously monster truck status now, and moreso all the time.
Yeah, I just found that thread after a quick search. You said the rotors were LGT Spec B rotors? I think if you could find some DBA 2-pieces for that, it would be a sweet setup. Do you know if the Evo rears are close as well, or are you just playing with the front for now?
Old 05-10-2011, 02:00 AM   #5
Imprzaboy89
Member#: 241311
95L V6WRXSTI type R
HE?RP DERP
wow just wow
Imprzaboy89 is offline   Reply With Quote
Old 05-10-2011, 02:12 AM   #6
Gclark
Member#: 192352
1994 Legacy STI
ლ( ಠ ಠ)
Awe man, you're making me sad. Tell him to post some pics on slcsubaru.
Yup LGT Spec B, which I *believe* are the same as Legacy gt ones. I haven't decided what I want to do with the rears yet. I might just do WRX two pots, since to install brembos on the rear you need to change the hubs and bla bla bla. WRX two pots just need a special bracket Kartboy makes.
Originally Posted by Imprzaboy89 View Post
wow just wow
Good wow, or bad wow? Oh and I have some Ralliart seats in my car :
Car in question:
Mitsubishi stuff is just cheaper
Too bad it adds instant crank walk
Old 05-10-2011, 02:24 AM   #7
Kentrik
Member#: 125937
03 WRX I do not
But WOULD you need to change the hubs up? I thought because of the differences with the STi and WRX rear rotors, that is why DBA made that rear rotor specifically FOR that swap.....the DBA 2657 rotors...
Old 05-10-2011, 02:32 AM   #8
Gclark
Member#: 192352
1994 Legacy STI
ლ( ಠ ಠ)
Oh yes, I forgot about the special rotors. More here: http://www.fastwrx.com/rebradkit.html
Pricey
Old 05-10-2011, 02:34 AM   #9
Kentrik
Member#: 125937
03 WRX I do not
Yeah......but if you can get a full set of the Evo Brembos for like $550 shipped (and you would need this for an STi ANYWAY), wouldn't it still technically be worth it?
Old 05-10-2011, 02:58 AM   #10
Pencils
Member#: 152726
The 2003 pwrFAP
thing
Awesome
Pencils is offline   Reply With Quote
Old 05-10-2011, 10:39 AM   #11
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
are the rear evo brembos different as well???? has anyone tried them?>??
seanathanq83 is offline   Reply With Quote
Old 05-10-2011, 04:39 PM   #12
army medic
Member#: 200236
05 STi
Aspen
Nice install. Let me have your wagon!
If you can find it cheaper/same product/same quality, then it makes perfect sense.
army medic is offline   Reply With Quote
Old 05-10-2011, 04:45 PM   #13
Teh Police
Member#: 246204
My Subaru Forester
is White.
I was looking at my brothers Evo the other day wondering if this would work. All thats left to do now is figure out the best cost effective way to make the rears work.
Edit, does it matter what year of Evo the Brembos come off of?
Teh Police is online now   Reply With Quote
Old 05-11-2011, 12:56 AM   #14
Imprzaboy89
Member#: 241311
95L V6WRXSTI type R
HE?RP DERP
idk a little if both balls for doing it the way you did it and bad because its kinda ghetto lol
Old 05-12-2011, 09:19 AM   #15
Gclark
Member#: 192352
1994 Legacy STI
ლ( ಠ ಠ)
Finally took some nice pictures, Brembos are great
I don't think the year of the Evo they come from matters, but I'm not 100% sure. I haven't heard anything about the rears, who wants to try it
Old 05-12-2011, 10:06 AM   #16
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Where can I get some cake
oh snap! I'm all over this!
King of Poop is offline   Reply With Quote
Old 05-12-2011, 10:37 AM   #17
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
+2 searching for evo brembos as I type...
rexworx is offline   Reply With Quote
Old 05-12-2011, 10:45 AM   #18
Gclark
Member#: 192352
1994 Legacy STI
ლ( ಠ ಠ)
As long as you don't mind grinding down the hubs or calipers(instant weight savings ), then go for it! It takes patience and time, but I think it's worth it.
Old 05-12-2011, 10:53 AM   #19
rexworx
Member#: 103232
Since your using the Legacy rotors, doe the brake pad over hang past a rotor a bit?
Old 05-12-2011, 11:04 AM   #20
Gclark
Member#: 192352
1994 Legacy STI
ლ( ಠ ಠ)
Nope they fit fine.
Wow thread moved!
Old 05-12-2011, 11:43 AM   #21
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
Are the pistons oriented correctly? I know that someone else that did this swap had to put the calipers on backwards and thus was setting himself up for majorly uneven pad wear.
The smaller piston should be on the leading edge.
AndyRoo is offline   Reply With Quote
Old 05-12-2011, 11:46 AM   #22
Gclark
Member#: 192352
1994 Legacy STI
ლ( ಠ ಠ)
I believe so? The bleeder nipples on top, I know the guy in the rs25 thread had that problem. I guess I don't understand what your trying to say, the calipers are centered, so the wear should be even..
Old 05-12-2011, 12:21 PM   #23
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
The leading pistons are on the wrong side when swapping them to a Subaru which will cause the pads to wear unevenly. For street use they should be fine, but I wouldn't use them on track.
Tony
Old 05-12-2011, 12:37 PM   #24
rexworx
Member#: 103232
Ive also have heard of this issue. Cant you just swap the calipers from left too right, then caliper bleader and hard line from top too bottom?
Edit: Id assume you "dont" need to swap from left too right. The small piston is leading regardless of the caliper mounted on front of back of the knuckle.
Put it behind the knucle like suabrus are mounted and now the small piston is on teh bottom, but still on the leading edge. So just swap teh bleaders and cross overs from top too bottom...
Ian,
Old 05-12-2011, 01:58 PM   #25
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Ian,
I have heard people suggest this, though I'm not sure if anyone has done it (and posted pics on the forum). Doesn't look too hard since the Evo Brembos have external crossovers.
The Evo Brembo and STI Brembo use the same pad, though IIRC there's a 1mm difference in the rotors or some such (couldn't tell you which dimension either, it's been a while). I believe there was some discussion of the pads/rotors on RS25 highlighting the difference between the two. Or perhaps I read about the pad thickness on EvolutionM, can't remember.
OrbitalEllipses is online now   Reply With Quote
HOW TO: Disable DRL on 2006 STI Rootus Interior & Exterior Modification 58 06-13-2009 10:25 PM
Got down and dirty with my turbo'ed outback today impreza_GC8 Member's Car Gallery 5 08-23-2008 09:40 PM
P0171 trouble shooting before i get down and dirty Cannonbolt Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 08-21-2007 02:07 PM
Down and dirty sway bar install overview godzillasti Brakes, Steering & Suspension 1 03-06-2007 04:57 PM
Down and Dirty Battery trunk relocation godzillasti Electrical & Lighting 0 03-06-2007 03:58 PM
