Old 05-10-2011, 08:19 PM   #1
Caden
Member#: 281604
2002 Wrx Wagon
Default Cobb AP vrs Open source tune...
Hey guys I live up in montana and was just wondering if I should get a ap or open source tune... I have a turboback system and an uppipe. I don't know where I can get a open source tune and if I got a cobb accessport then later on I would probably get a protune..
Caden is offline   Reply With Quote
Old 05-10-2011, 08:23 PM   #2
boxer fanatic
Member#: 255153
'02 Corn fed bugeye
'11 forester 2.5X SWP
You can get a protune with open source at most shops. Opensource is way cheaper and can do everything the AP can do other than switch maps on the fly.
boxer fanatic is offline   Reply With Quote
Old 05-10-2011, 08:27 PM   #3
boxer fanatic
Member#: 255153
'02 Corn fed bugeye
You can also get a tactrix cable and flash opensource OTS maps as well from romraider.com
Old 05-10-2011, 09:47 PM   #4
tooquick
Member#: 238317
2010 WRX Limited
E-tuning is another good option if you dont have a reputable tuner near
tooquick is offline   Reply With Quote
Old 05-10-2011, 09:50 PM   #5
boxer fanatic
Member#: 255153
'02 Corn fed bugeye
Yes e-tuning is great and usually pretty affordable. I got e-tuned for $150.
Old 05-10-2011, 10:08 PM   #6
JRizzy24
Member#: 215468
2013 STi
Crystal Black Silica
Highly suggest Open Source or E-tune over a COBB. Contact Phatron
JRizzy24 is offline   Reply With Quote
Old 05-10-2011, 11:29 PM   #7
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
I'm a big believer in Open Source, but I'm not so sure about e-tunes. I don't think tuning a car sight unseen will result in the best, or even most reliable tune.
OUScooby is offline   Reply With Quote
Old 05-11-2011, 12:00 AM   #8
boxer fanatic
Member#: 255153
'02 Corn fed bugeye
I got an etune on e85 and made 324awhp and 300awtq on airboys. Been running it for 4000 miles now and no problems at all. Etunes can be just as good as a face to face tune. It really just depends on who does it in my opinion.
Old 05-11-2011, 12:05 AM   #9
Caden
Member#: 281604
2002 Wrx Wagon
Thanks for the posts everyone! I just found a guy that does open source tunes and I am going to just do that!
Old 05-11-2011, 02:41 AM   #10
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
D00d, you don't have either of those things yet. Slow down.
Also, open source is much more cost-effective.
XanRules is offline   Reply With Quote
Old 05-11-2011, 08:43 AM   #11
boxer fanatic
Member#: 255153
'02 Corn fed bugeye
double post
Old 05-17-2011, 02:36 PM   #12
andersonwrx
Member#: 248437
02 WRX Stage 4 6MT
What about a dyno open source tune versus a UTEC? is there any advantage to to using a piggyback computer with the factory ECU or can better results be had with open source and a dyno alone? I currently have an older TubroXS UTEC but wonder if I would see better results with Open Source. I have been told that the piggy back ends up "fighting" the stock ECU and effect the smoothness, power delivery (though not over all power), and gas milage. I'm hoping to set it and forget it so programming options and multiple maps are not an issue. any thoughts
andersonwrx is offline   Reply With Quote
Old 05-17-2011, 02:49 PM   #13
Cefaln452
Member#: 255736
2004 STi
JavaBlackPearl
dyno tunes are gay. do you drive your car on a dyno? NO. you drive it on the street.
Cefaln452 is offline   Reply With Quote
Old 05-17-2011, 02:57 PM   #14
dirty_sanchez
Member#: 111682
1981 Yugo hatchback
...he says to the officer while being led to the backseat of his cruiser.
dirty_sanchez is offline   Reply With Quote
Old 05-17-2011, 03:00 PM   #15
Cefaln452
Member#: 255736
2004 STi
JavaBlackPearl
fuggem. you cant dial in a car on a dyno as you can on the road.... idk about you, but I like drivability
Old 05-17-2011, 03:10 PM   #16
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
A good tune should use both. The dyno is indispensable for comparing the change in power due to changes in the tune, while the street is indispensable for tuning driveability. A tune that is developed using only one or the other will be leaving something on the table, be it power or repeatable behavior under multiple conditions.
Old 05-17-2011, 03:12 PM   #17
dirty_sanchez
Member#: 111682
1981 Yugo hatchback
I like drivability as well. However, to dismiss a dyno tune as "gay" simply because it's not a road tune, is, well..... gay. Everything has its place.
Though with all other things equal, a good dyno tune and/or a road tune will still be "better" than any ots Accessport map.
Old 05-17-2011, 03:12 PM   #18
Member#: 51961
2005 STi
2012 WRX
There are tradeoffs
open source has the advantage of not having to switch back and forth between processors, which can lead to stumbling and other driveability problems.
UTEC has the advantage of full control over the parameters (not everything is defined in open source), speed density, on the fly map switching, etc.
Old 05-17-2011, 03:32 PM   #19
Cefaln452
Member#: 255736
2004 STi
JavaBlackPearl
Im just making the point about how some people who tune JUST on dyno... thats not right at all.
Old 05-17-2011, 04:03 PM   #20
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
Why is that not right at all? You can take the engine through any load/rev that you would see on the road. When you tune on a road you still do the same pulls through gears you'd do on a dyno. In terms of the engine what situation is going to occur doing a pull on the road that won't happen on a dyno?
You what isn't right at all, doing +100mph on a public road beacuse you want a few more horsepower.
Old 05-17-2011, 04:13 PM   #21
Cefaln452
Member#: 255736
2004 STi
JavaBlackPearl
you take a car that just got a tune off the dyno and not tweaked on the street... the drivability is going to be terrible. take that same car in bumper to bumper traffic..... same deal. Now road tune it afterwards, now youre getting somewhere.
Old 05-17-2011, 04:14 PM   #22
Cefaln452
Member#: 255736
2004 STi
JavaBlackPearl
dyno queens talk numbers. WHO cares about 1 more hp you can squeeze out on the dyno... again, you dont drive your car on the dyno do you? YOU drive it on the street under normal conditions, traffic etc.
Old 05-17-2011, 04:20 PM   #23
itscashed
Member#: 283038
WRX
Depends on the open source tune? I have had both. I had a COBB AP and I had an Open Source from Dale @boxer4racing in NC. Personally the Cost effectiviness of the Open Source, not to mention smoother powerband in this instance, made the COBB a waste of money to me. Just my .02
itscashed is offline   Reply With Quote
Old 05-17-2011, 06:12 PM   #24
KLZCYA
Member#: 281146
95 6 spd GC8 STi
Any more info on this E-tune thing? Places to send it ETC? I'm in Alberta, Canada and there arent any tuners close by.
KLZCYA is offline   Reply With Quote
Old 05-17-2011, 06:15 PM   #25
Power_shift
Member#: 221984
2006 Sti
I tuned my car last year and it was fron the accessport. I used it literally 3 times to monitor some data and that was about it. To me i paid an extra 500 dollars for something that is only useful around tune time. There is pros and cons to it. Being that i do not have guages mounted in the car it works as my guage.
Power_shift is offline   Reply With Quote
Whats better Cobb accessport or open source tune gavone23 Newbies & FAQs 7 05-05-2011 08:34 AM
Cobb AP with Open Source? Mechie3 AccessPort 11 08-27-2010 03:50 PM
Cobb AP or Open source? photodude Engine Management & Tuning 3 07-24-2010 04:01 PM
Open Source tuning or AP protuners? vasteve20 Mid Atlantic Impreza Club -- MAIC 24 01-11-2010 01:47 AM
Newb tuning questions... ap maps? open source? jbark1018 Newbies & FAQs 11 10-12-2009 09:18 PM
