Old 05-11-2011, 06:54 PM   #1
ToyotaGuy
Member#: 198292
91 MR2
Red
Default I need to replace an EJ25 shortblock....
...in my 2000 Legacy L 5speed. The block itself is cracked and there is rod knock, so a rebuild is out of the question. What cars have a block I can use? How does SOHC or DOHC affect me here, and newb question, which do I have? Also, what would happen if I used a 2.2(t)L block with my 2.5L heads and such?
ToyotaGuy is offline   Reply With Quote
Old 05-12-2011, 09:22 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
You have a SOHC "Phase II" EJ25. Any '99-05 SOHC shortblock will work.
Pat Olsen
Old 05-12-2011, 11:17 AM   #3
GEE-OTTO
Member#: 201277
2009 Legacy GT
Pat Olsen
Yeah what Pat said And you can find EJ251 engines laying around on RS25.com
GEE-OTTO is offline   Reply With Quote
Old 05-12-2011, 11:44 AM   #4
JoshP
Member#: 94350
You can use the DOHC shortblock with matching gasket, lower compression and you have to swap some stuff. I dont really care for it because things dont fit very well, but it works anyway.
JoshP is offline   Reply With Quote
Old 05-12-2011, 03:20 PM   #5
ToyotaGuy
Member#: 198292
91 MR2
Red
Well I lucked out because my friend replaced the motor in is Forrester due to hg issues, so I now have a good block to swap into mine with 110K miles. Other than the idea of a rebuild which I cant afford anyway, what else should I do prior to installation with new gaskets and such? I plan to have new hg, valve cover, and t-belt. Anything else I should do?
Old 05-12-2011, 03:26 PM   #6
DarkPhoenix
Member#: 272511
1997 Legacy Outback
Ruby Mica Metallic
I would do the seals as well. Front and rear mains, and cam seals. Preemptive strike against the Subaru oil leaks.
DarkPhoenix is offline   Reply With Quote
Old 05-12-2011, 04:10 PM   #7
ToyotaGuy
Member#: 198292
91 MR2
Red
I like the idea of no oil leaks. It just makes sense to do this stuff with the motor out and pulled apart.
Old 05-12-2011, 05:10 PM   #8
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
do the valve cover gaskets and spark plug boots too while you have easy access?
Sir-Knight is offline   Reply With Quote
Old 05-12-2011, 07:32 PM   #9
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Now is also the time to think about upgrades. As previously mentioned, the HG matches the block, you can use the EJ25D if you want, just make sure to use the EJ25D gasket(since the EJ25D pistons pop out of the cylinder). Make sure that the block your friend has is good, and un-warped. A quick check from a machine shop is easier in the long run than doing the HG's again.
If you want to boost this motor later on, the EJ22E is the easiest and cheapest way to lower your compression ratio, the EJ22T brings the CR way too low, IMO. Actually, i'm wrong, sorry. If you get the SOHC block, you can swap in STI rods and pistons, which would be about the same price, but you would end up with 2.5L instead of 2.2L, bigger is better....
that's what she said.
~Josh~
Old 05-14-2011, 11:04 AM   #10
Sockington
Member#: 189689
2006 Impreza Wagon
CGM
Outfront Motorsports sells shortblocks for under $1k.
Sockington is offline   Reply With Quote
Old 05-16-2011, 03:34 PM   #11
DarkPhoenix
Member#: 272511
1997 Legacy Outback
Ruby Mica Metallic
Just basic rebuilds for about $800, using your shortblock. To purchase one outright is about $3500.
JDM EJ25 to replace Stock EJ25 acrracing Newbies & FAQs 1 07-09-2010 09:31 PM
HELP OT: Need to replace an ancient AC wall unit... tomorrow Wagon Of Fury Off-Topic 32 07-16-2008 09:07 AM
Where to buy an Ej207 shortblock? stevenh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-28-2006 02:44 PM
A bajillion options for replacing an STi shortblock stichris Built Motor Discussion 2 05-23-2006 03:34 PM
Phase 1 EJ22 mated to Phase 2 EJ25 SHortblock? huckedup16 Normally Aspirated Powertrain 0 03-25-2004 09:24 PM
