Old 09-05-2011, 11:20 PM   #51
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Originally Posted by Zulu- View Post
I guess it'd be in coaxial 'mode,' it's convertible. Driver's side works like normal, but I haven't swapped them yet. Yes to OEM tweeters. Maybe a fuse popped, it started to rain so didn't get to check it out with a test light.
Are they running off of the HU or an amp? Did you try them with the door panel off? Did you try swapping the OEM stuff back in? Did you use the Metra wiring harness? Do the speakers have an external crossover?
We really need more info to be of any assistance.
phenryiv1 is offline   Reply With Quote
Old 09-06-2011, 02:29 PM   #52
Zulu-
Member#: 232213
Running off the HU (Pioneer AVIC-D3), tried them with the panel off, did not swap OEM stuff back in (but I did put the OEM tweeters back in the sail panel to check and they are not working), yes I used the METRA wiring harness for the HU and speakers and, no, the speakers have an internal crossover.
Zulu- is offline   Reply With Quote
Old 09-06-2011, 03:27 PM   #53
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Was the Pioneer installed and working prior to installing the speakers, or was this an all-at-one-time install?
Typically, the speakers would sound like crap if they were bad or mis-installed. Unless something happened to the amplifier section of the HU with you having the +/- shorted out...
Your best bet might be to try to go back and reconnect the OEM coax/midrange and see if it works.
Old 09-06-2011, 04:46 PM   #54
Zulu-
Member#: 232213
No, the Pioneer has been in for awhile. I thought about all that, gonna make some time Thursday to work on it. I'm going to go out now though and check for a blown fuse, curious that the sail panel tweeter would go as well. I'd hope the HU's amp is fine, though I'd think that would affect the other speakers as well. Unsure.
Old 09-13-2011, 10:35 AM   #55
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Post #11 edited to include some pics of the install in the rear of my '11.
Old 09-23-2011, 04:03 PM   #56
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Periodic bump for visibility...
Old 10-14-2011, 02:35 AM   #57
hoofhearted
Member#: 293554
Just wanted to add something to watch out for when removing the door lock/window button trim piece. When you go to lift it if your no careful it will gouge(sp?) A mark into the door that can not be fixed. Learn from my mistake. Maybe put some blue painters tape in that area so it takes the friction and not the door its self.
hoofhearted is offline   Reply With Quote
Old 11-01-2011, 12:30 PM   #58
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Good point. I have the same marks on one of my doors and did not realize how I got them until I read your post.
Old 11-01-2011, 01:06 PM   #59
WickedRX
Member#: 298302
2013 WRX 5 Door
ISM
I installed a Headunit, all 4 speakers and a sub in mine this past weekened. The only part that went wrong is even though I was SUPER careful, I broke both the sail panels. The stupid clip would not come out the door. Even after I broke them I struggled with a pair of pliers trying to get that thing out. I figured, if I struggled with a pair of pliers then it wasnt the way I handled the sail panel, that bitch was not coming out no matter what!
WickedRX is offline   Reply With Quote
Old 11-01-2011, 01:22 PM   #60
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Was that on the rear? I had the same issue. I broke one of them and just decided to remove the lower pins on the other side and use a dowel rod to prop the panel away fromthe inner door skin with enough room to work on the passenger side.
Front was not an issue.
Old 11-01-2011, 01:32 PM   #61
WickedRX
Member#: 298302
2013 WRX 5 Door
ISM
yup, both rear sail panels. it pissed me off more because of how careful and how much time I was taking being patient to pull them off. Then SNAP! followed by a lot of cursing and stomping! lol, I crazy glued them back together knowing I will have to break them again if I take them off.
Old 11-01-2011, 01:40 PM   #62
infinite012
Member#: 74392
2015 Forester
New sail panels cost about $15 shipped each. Ask me how I know.
infinite012 is offline   Reply With Quote
Old 11-01-2011, 02:50 PM   #63
WickedRX
Member#: 298302
2013 WRX 5 Door
ISM
I dont feel so bad now.........
Old 11-01-2011, 03:29 PM   #64
hoofhearted
Member#: 293554
I broke mine also.
Old 11-01-2011, 03:45 PM   #65
WickedRX
Member#: 298302
2013 WRX 5 Door
ISM
Sounds like they are a one time use then.........
Old 11-01-2011, 04:57 PM   #66
Syrius78
Member#: 267996
2011 Wrx
Rallye blue
Mine broken too, where can I find it? Dealer does not answer my request.
I live in Canada
Thanks
Syrius78 is offline   Reply With Quote
Old 11-01-2011, 05:11 PM   #67
WickedRX
Member#: 298302
2013 WRX 5 Door
ISM
I live in Canada
Thanks
Damn, I wish I would of taken a picture of the part numbers when I had them off. If you still have yours just look for the part number on them, its molded on there. Just call a delaer and tell them you want to order 1 of each part number and you should be set.
Old 11-01-2011, 05:19 PM   #68
Syrius78
Member#: 267996
2011 Wrx
Rallye blue
Yeah
That what I did and I'm still waiting. It's been two month Already. That why I searching for a online source
Old 11-01-2011, 05:29 PM   #69
gargleblaster
Member#: 11107
2015 WRX STi
Crystal White Pearl
Subscribed. Thanks for the great info in this thread.
gargleblaster is offline   Reply With Quote
Old 11-01-2011, 05:40 PM   #70
WickedRX
Member#: 298302
2013 WRX 5 Door
ISM
Yeah
Put the part numbers in this thread detailing which one is the drivers and the passengers side. I will do some searching for you. It will help others also.
Old 11-01-2011, 05:46 PM   #71
WickedRX
Member#: 298302
2013 WRX 5 Door
ISM
Found em:
https://www.subarupartsdepot.com/oem-subaru-parts.html
Pick 2011 Subaru WRX
and following the drop down menu on the picture I attached.
Old 11-01-2011, 05:49 PM   #72
Confucius37
Member#: 291094
2011 WRX
Front Door -> Interior Trim -> Corner Cover $10.10
https://www.partswebsite.com/subarug...129&type=parts
Confucius37 is offline   Reply With Quote
Old 11-01-2011, 05:52 PM   #73
WickedRX
Member#: 298302
2013 WRX 5 Door
ISM
or this for the front.
Old 11-05-2011, 02:28 PM   #74
skris35
Member#: 300089
2008 Impreza 2.5i
Default Good info
I am looking into information into new speakers/head unit in my imperza 2.5i and this is very helpful. Thanks for sharing all your tips/tricks.
skris35 is offline   Reply With Quote
Old 11-05-2011, 02:44 PM   #75
WickedRX
Member#: 298302
2013 WRX 5 Door
ISM
If anyone is looking for front speakers that are VERY easy, I can confirm the Alpine SPS-610C and the tweeters are direct replacements. Just remove the tweeter out of the twist on housing Alpine provides and they fit like OEM in the sail panels, no cutting needed. I have the Alpine SPS-610 in the rear and they give absolutely zero clearance issues with 3/4 inch spacers.
replacing factory speakers in my 04 wrx wagon brassmonkey Car Audio, Video & Security 4 09-13-2006 01:21 PM
Question for people who replaced door speakers? glock37 Car Audio, Video & Security 7 08-11-2004 08:16 AM
replacing the speakers in my legacy JonofScio Car Audio, Video & Security 2 02-20-2004 07:47 AM
Rear door speaker upgrade (03 wrx sedan) DEE-REX Car Audio, Video & Security 9 06-14-2003 10:06 PM
door speakers in 00 sedan soob2k Car Audio, Video & Security 2 02-17-2000 03:06 PM
