Old 11-06-2011, 03:40 PM   #76
jkf
Member#: 237483
2011 WRX Premium 5dr
Originally Posted by WickedRX View Post
If anyone is looking for front speakers that are VERY easy, I can confirm the Alpine SPS-610C and the tweeters are direct replacements. Just remove the tweeter out of the twist on housing Alpine provides and they fit like OEM in the sail panels, no cutting needed. I have the Alpine SPS-610 in the rear and they give absolutely zero clearance issues with 3/4 inch spacers.
That is great to hear, as I've been planning an upgrade to the 610C's up front and the 610s in the back. Did you need to use spacers on the front speakers? I'm presuming you didn't, since you say they're direct replacements, but wanted to verify.
jkf is offline   Reply With Quote
Old 11-06-2011, 04:10 PM   #77
WickedRX
Member#: 298302
2013 WRX 5 Door
ISM
Yes I did sorry about that, 1/2 inch spacers all around. Got mine from IA Performance. Easiest swap I've done so far, they come with everything you need.
Remember to buy the METRA 72-8104 TOYOTA UNIVERSAL SPEAKER CONNECTORS
You'll need 2 set
Also the tweeters youll need to remove all of the housing including the front protective grill. It comes off without any tools, nothing is holding it in place.
WickedRX is offline   Reply With Quote
Old 11-06-2011, 04:14 PM   #78
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Yes I did sorry about that, 3/4 inch spacers all around. Got mine from IA Performance. Easiest swap I've done so far, they come with everything you need.
You'll need 2 set
I can also make the spacers for you, if you'd rather have the full 3/4" thickness. If you go with the iA spacers, you have to buy 2 full sets and stack them. Plus, mine are solid PVC, while theirs are injection molded plastic. I bought the iA ones and did not like them, so I made my own (see pics on page 1).
Shoot me a PM if you want a set. I have made them for a lot of other members, by request.
phenryiv1 is offline   Reply With Quote
Old 11-06-2011, 04:25 PM   #79
WickedRX
Member#: 298302
2013 WRX 5 Door
ISM
Corrected my post, I used 1/2 inch spacers.
Old 11-06-2011, 08:14 PM   #80
Rymantas
Member#: 264225
2011 WRX Sedan
I know that each brand of speaker will have different depths, but would it be a good idea to just get the 3/4" spacers regardless of the depth of the speaker? That way there is no chance of hitting the window?
Does the 3/4" spacer cause any cone interference when the door card is placed back on?
Rymantas is offline   Reply With Quote
Old 11-06-2011, 09:29 PM   #81
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
I might be incorrect, but I think it would be for a few reasons. One that way the back if your speaker isn't exposed to the weather it it drops behind the door. Two, you have a better insulation between the speaker and the metal door. There is a techno term for this.. To me its just a rattling sound. Three, stock speakers use a 6 point mounting circle and most aftermarket speakers use 4.
Louie is offline   Reply With Quote
Old 11-06-2011, 10:18 PM   #82
vajayhawkfan
Member#: 83908
2011 WRX 5-Door
Yeah, you can pretty much plan on breaking the rear sail panels if you take them off. No doubt about that.
Good thing they are very cheap to replace. I would actually say that anyone planning on replacing their rear door speakers should buy a replacement set of these first.
vajayhawkfan is offline   Reply With Quote
Old 11-18-2011, 05:08 PM   #83
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
No cone interference with a 3/4" spacer unless you have crazy tweeter protrusion.
And yes, going with 3/4" from the beginning is a good idea. It fits, and it offers the best flexibility if you change to deeper speakers later.
Old 11-18-2011, 05:08 PM   #84
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Good thinking. I'll try to add the part numbers to the first post.
Parts are 94251 FG040 (Right) and 94251 FG050 (Left). List is $9.18 each. I got them for a little less than that from Annapolis Subaru (a NASIOC vendor- use them!).
Old 11-18-2011, 05:09 PM   #85
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Originally Posted by Louie View Post
Two, you have a better insulation between the speaker and the metal door. There is a techno term for this.. To me its just a rattling sound. Three, stock speakers use a 3 point mounting circle and most aftermarket speakers use 4.
Decoupling is the word that you were looking for.
And I corrected the mounting points in bold. But you had the right idea.
Old 11-21-2011, 04:14 PM   #86
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Updated Post 84 with sail panel part numbers.
Old 11-29-2011, 11:36 AM   #87
Vash337
Member#: 282107
2011 wrx sedan
obsidian black
great thread. did i miss the head unit install??
Vash337 is offline   Reply With Quote
Old 11-29-2011, 11:43 AM   #88
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
No, I made this thread for the speakers and door panels, but I can try to throw together a similar thread for the HU. The HU was so easy that I never got around to making an install thread. The only hard part is having the right tools (plastic trim tools) to remove the bezel.
Edit:
Here is a link to my install thread. The section on the HU gives a pretty good overview of how it all comes apart:
http://forums.nasioc.com/forums/show....php?t=2218119
Old 12-22-2011, 03:20 PM   #89
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Periodic bump for all of the '12 buyers who roll in here...
Old 01-30-2012, 06:35 PM   #90
djseth
Member#: 180199
Like me! Picking up my 2012 STI Limited tomorrow with Nav. Thanks to all who have participated in this thread. I have read all pages and associated pages with this thread and anticipate doing front, rear and amp in it. I'm sure I will reach out to phenryiv1 and pick up the adapters/spacers. Not sure what size the speakers are F&R. Also, on the 2012 Nav, is there either a preamp level out on the back or preamp level out in the harness I could tap into?
djseth is offline   Reply With Quote
Old 01-30-2012, 08:20 PM   #91
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
I am working on getting all of this info (and a lot more) into a website for subaru owners. I took it live a couple weeks ago but it is a work in progress. Check out www.subaruaudio.net for some of the writeups and info.
The '12 does not have RCA outputs. You have to use a line output converter.
Old 01-31-2012, 07:33 AM   #92
djseth
Member#: 180199
Well, that's too bad. My Alpine amp does have speaker level in as well as RCA. Thanks for the link, I will read the posts.
Old 03-26-2012, 03:40 PM   #93
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Hmmm...this has not been bumped in a while. '12 WRX/STi owners can benefit from most of the information. Some even applies to the '12 Impreza.
Old 04-09-2012, 11:12 AM   #94
djseth
Member#: 180199
Hey all, looking for new speakers now, will either go with Infinities, MB Quart, Focal or Hybrid Audio. I think I wanna do components front and rear and put the rear tweets in the door handle, looks like a great spot for them if they will clear the back. So is there a picture driven tutorial for a back up camera install?
Old 04-09-2012, 05:59 PM   #95
Tmangt650
Member#: 277258
2008 Hatch 2.5i
So I have recently Blown my stock speakers well because I like to listen to my music loud! But everytime I think about buying new speakers I think about the mounting issues and the DIY PVC brackets. I saw you said that there was most speakers that would not fit, is there any you know that WOULD fit without modifying. (You may have said it, I will re-read the first page to see and edit if I find it)
While I do have basic knowledge on the DIY projects (especially after a detailed write up is available) I do not think I would be able to make it look nearly as clean as you did...
Tmangt650 is offline   Reply With Quote
Old 04-09-2012, 06:18 PM   #96
Syrius78
Member#: 267996
2011 Wrx
Rallye blue
My speaker fit in the oem bracket
They are great quality and i'm very happy with them. They are not cheap. I found them on crutchfield
Jl-audio tr600-cxi
Hope it help
Syrius78 is offline   Reply With Quote
Old 04-09-2012, 06:30 PM   #97
Tmangt650
Member#: 277258
2008 Hatch 2.5i
Yeah not too much worried about price, as I have put a decent amount into my current sound system. JL Audio will actually be my nuext sub upgrade. Cannot put a price on good quality sound.
Do you know if theyd fit in a 2.5i tho? I thought I read it was the same fitment..
Old 04-09-2012, 07:04 PM   #98
Syrius78
Member#: 267996
2011 Wrx
Rallye blue
I got a wrx 2011, should be the same interior. To be sure ask crutchfield, they are good.
I changd the four speaker and add a ton of dynamat
Very happy. I'm using a pioneer unit.
Old 04-09-2012, 07:06 PM   #99
Tmangt650
Member#: 277258
2008 Hatch 2.5i
Yeah ill be sure to ask them. Im in some DESPERATE need of dynomat. But the shizz is so expen$$ive..
Old 04-09-2012, 07:11 PM   #100
Syrius78
Member#: 267996
2011 Wrx
Rallye blue
Agreed, but worth every penny!!!
I suggest the nine sheet kit. Good for four door and most of the trunk. I does work well. You wont need a sub after that
replacing factory speakers in my 04 wrx wagon brassmonkey Car Audio, Video & Security 4 09-13-2006 02:21 PM
Question for people who replaced door speakers? glock37 Car Audio, Video & Security 7 08-11-2004 09:16 AM
replacing the speakers in my legacy JonofScio Car Audio, Video & Security 2 02-20-2004 08:47 AM
Rear door speaker upgrade (03 wrx sedan) DEE-REX Car Audio, Video & Security 9 06-14-2003 11:06 PM
door speakers in 00 sedan soob2k Car Audio, Video & Security 2 02-17-2000 04:06 PM
