Old 07-21-2002, 05:35 PM   #1
Martin Ritchie
Member#: 6771
2002 WRX WagonSilver
04 WRX Sedan Red
Question Trouble turning ignition key
My wife is having trouble turning the ignition key in her 95 Legacy LS to start the car. She has to wriggle the steering wheel before the lock on the ignition switch lets go. It has gotten progressively harder to turn the key. It does not only happen when the steering wheel is locked. She's always managed to get it started but it is becoming a pain. Any ideas or suggestions?
Martin Ritchie is offline   Reply With Quote
Old 07-21-2002, 09:36 PM   #2
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
that's the way most cars are, unfortunately. It's a bit harder to do if the steering wheel is locked.
gavin is offline   Reply With Quote
Old 07-21-2002, 09:59 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Does she turn the wheel to one side before turning the car off? When the wheels are far to one side and the pressure in the PS drops the wheel turns towards straight with some force. Sounds like it might put all this pressure against the stearing lock.
Old 07-22-2002, 08:50 AM   #4
Martin Ritchie
Member#: 6771
04 WRX Sedan Red
No, no, I know all about the steering wheel lock mechanism. It happens when the car is parked with the wheels completely straight and when the steering wheel is NOT locked. I'm assuming that there is something wrong with the locking mechanism in the ignition switch but just thought someone might have some insight before we put ourselves at the mercy of a mechanic.
Old 07-22-2002, 10:31 AM   #5
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
It can also be caused by a worn key. Do you have a spare that isn't used every day? If so try it.
HIHO is offline   Reply With Quote
Old 07-22-2002, 12:07 PM   #6
rallysquirrel
Member#: 7006
2007 SpecB
I had a hell of a time removing my key from steering column. Turned out the key was way worn, so I'm now using one of the two spare keys
rallysquirrel is offline   Reply With Quote
Old 07-23-2002, 07:44 AM   #7
Martin Ritchie
Member#: 6771
04 WRX Sedan Red
Wish it was just the key but it isn't. Does it with my key as well as hers and mine has only been used a few times. We'll probably just take it in and see what the mechanic says. Thanks for all your suggestions. That's why I love the I-Club.
ARG... 2002 Impreza Ignition Key Won't Turn piercepcable Electrical & Lighting 3 04-13-2009 10:32 PM
Turn ignition key, engine doesn't start. GreasyJoe Electrical & Lighting 14 12-16-2008 09:37 AM
Ignition Key problem: Car won't let go of the key! PhoenixDownVII Legacy Forum 14 12-23-2005 10:28 AM
sometimes I cant turn the key in the ignition balajc Newbies & FAQs 6 03-26-2003 10:25 AM
