Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Complete Car Part-Out
Closed Thread
Old 05-13-2011, 07:13 PM   #1
prince3o
Member Sales Rating: (7)
Member#: 130301
1999 RSTi
Default '99 Rs/sti
1999 Subaru Impreza RS (2 door, black, stock black leather interior)
For sale, trade, or part out (if the price is right)
The Good
Car runs and has been reliable since owning it the past three years. Great project to pick up considering Ύ of the headache is done.
The Bad
- The vehicle as is does not pass emissions because it has a Hydra EMS ECU
- Doesn’t always idle, but if primed twice it will
- Ignition switch needs to be replaced soon (at times it takes a few turns of the key to start)
- Turbo leaks oil
- The usual Subaru rattles
- Drive shaft knocks on HEAVY take offs, not on normal starts
MODS
- Crawford S2 block (USDM 2.5l STI short block, cast semi-closed turbo block, forged crank - 79mm, forged rods)
- Garrett AiResearch T3/T4 Turbo (rotated setup)
- Custom fuel injectors, 650 cc
- Converted to parallel fuel rails
- Manual boost controller
- NGK BRK7E spark plugs (gapped at .32 for turbo application)
- HKS SSQV Blow of valve
- Lightweight pulley system
- Complete ’05 STI 6-speed transmission swap with manual DCCD controller, axles, driveshaft, and Brembo brakes.
- External wastegate
- Front mount intercooler
- 3” turbo back exhaust
- Unequal length headers
- 17” Rota SDR rims (3 gold, 1 anthracite)
- Hydra EMS ECU (I HAVE THE LAPTOP FOR TUNING)
- Carbon Fiber trunk (has cracks)
STILL STOCK
- ’99 RS heads (SOHC, valves, springs, and retainers)
- ’99 RS intake manifold and throttle body
- ’99 RS oil pump and stock water pump
RECENTLY REPLACED
- Starter ’04 STI (7 months ago) Subaru genuine part
- Master cylinder, slave cylinder, metal lines, and rubber hose (6 months ago) Subaru genuine part
prince3o is offline
Old 05-14-2011, 12:13 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you are selling the car complete, please use the Vehicles for Sale section. If/when you decide to part it out, then you can post it here.
Mulder is offline
Closed Thread
So I got my '99 RS in Aug of '99. I still have the same battery. Snoopy Off-Topic 20 10-19-2005 02:15 AM
Direct swap? ver4 STi into '99 RS fragment Subaru Conversions 3 07-21-2005 01:33 AM
is it possible to get the '99 RS look for my '99 OBS? kaisersouse Interior & Exterior Modification 4 07-18-2005 01:35 PM
Will sti timing belt fit on '99 RS? Cusco Service & Maintenance 2 04-28-2003 02:05 AM
'99 silverthorne rs... sti/p1 susp. Takashi Member's Car Gallery 12 10-09-2002 11:51 AM
