Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 05-13-2011, 09:47 PM   #1
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Default Burrs for aluminum?
Where is a good place to get burrs for aluminum? I want to do some porting and smoothing of various pieces I am making and a few nice burrs would make the job much easier.
Thanks.
speedyHAM is offline   Reply With Quote
Old 05-13-2011, 10:19 PM   #2
JH02WrxWag
Member#: 246743
02 Impreza WRX
platinum
Really?? Who suggested you need burrs? Make sure you kick em in the nuts.
A burr is a ragged edge, it defeats the purpose of a port and polish.
JH02WrxWag is offline   Reply With Quote
Old 05-13-2011, 10:51 PM   #3
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
A burr is just one of the many tools that are useful for porting and polishing.
I already have sources for sanding drums and polishing wheels. I need something that will take off more material quickly, something a burr does quite nicely.
Have any decent sources?
Old 05-13-2011, 11:11 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Thanks.
I have ground mountains of aluminum with die grinders and burrs.....and there are many places on line that you can order from
http://www.carbidebur.com/nfburs/nfall.htm
there are many different kinds and cuts and shapes depending on what you are wanting to do.
harbor freight used to have a nice set of burrs in a wooden box....dunno if they still have them
Old 05-13-2011, 11:14 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
a 'burr' is a rotary cutting tool that attaches to a rotary motor of some sort....these are used to remove and shape metal from a work piece
a proper burr used in a proper way can leave a very nice surface that can be easily polished to a mirror finish if needed
Old 05-13-2011, 11:25 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
you could also buy rotary files...but they are usually $$$
Old 05-13-2011, 11:29 PM   #7
JH02WrxWag
Member#: 246743
02 Impreza WRX
platinum
Ok, I was wrong, use to be called a reaming bit.
http://american-carbide.com/Burs/ABProducts.php
But I wouldn't use it with hand held rotary tool. Their ment for lathes and mills or cnc machines that use programs. For a hand held rotary tool your best finish would be from a stone and buffing wheel, your less likely to cut a chunk from a soft alloy.
Old 05-13-2011, 11:59 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
d000000000000000d.....this is preposterous
burrs and rotary files have been used in die grinders for WAY longer than you have been alive by millions of people to grind and shape countless aluminum(and other metal) aircraft parts(and all sorts of other things) all over the world....by hand
I promise
Old 05-14-2011, 02:48 AM   #9
JH02WrxWag
Member#: 246743
02 Impreza WRX
platinum
I promise
Thanks for the history lesson and continuous effort to belittle me. But towards porting and polishing a large diameter there isnt a hand held rotary tool powerful enough to turn that size bit. Ream all the sheet metal and bolt holes you want but don't run that bit along a larger diameter. Trust me I don't know what I'm talking about. Lol
Old 05-14-2011, 05:26 AM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
whatever
I guess an air die grinder wont spin one of those
then you tell me I cant use one on a large casting
man...I dont know where you have worked....but it isnt where I have
I have ground on LOTS of stuff that you wouldnt believe....of all sorts of different kinds of aluminum and other metals, soft and not....dunno if I'd put 7075-T6 in the 'soft' category or not....but....well anyway
jeez....I wonder what I've been doing with the dozen or so 1/4 inch shank carbide burrs that I have in my tool box....and the 3 or 4 air die grinders that I have
must not have been grinding on any airplane parts, 'cuz you say it just 'aint done
oh yeah...ya usually ream fastener holes with a reamer, not grind 'em
Old 05-14-2011, 08:52 AM   #11
AREA1320
Member#: 112508
We use a combination of carbide burs drums and flapper wheels when we port heads. Ball and cone burrs are NEEDED when doing this to remove material. If you are worried about taking large chunks out then i suggest you STOP and let a professional do the work.
Stones will do nothing but clog up and should never be used on aluminum.
Mcmaster has an amazing selection of burrs
AREA1320 is offline   Reply With Quote
Old 05-14-2011, 11:18 AM   #12
JH02WrxWag
Member#: 246743
02 Impreza WRX
platinum
You put a 2 - 4 inch+ bit on an die grinder that thing must have some serious power. I'm not worried, I won't try to bore out more than 1" hole with de-burring bit.
You guys also need to consider most people on here asking about stuff don't have the same tools used in industrial manufacturing. You really think it's smart to let some run that bit through their engine block, I don't.
Even then they do decide to port and polish it themselves w/ either bit then still won't know they f'd it up till their car don't work.
Yes, leave machining work to professionals was the point. Scotty if your working on turbines I'm never flying again. I am joking, but I don't think GE or any other turbine manufactur die grinds their engine ports.
Old 05-14-2011, 11:44 AM   #13
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
I don't think I've ever seen a 2-4" bit with a 1/4" shaft for a hand grinder.
That's why they make endmills.
NitroTrike is offline   Reply With Quote
Old 05-14-2011, 02:19 PM   #14
jesterjames
Member#: 252663
your a moron,
those carbide burrs have a shank length of 2-6 inches. notice the cut diameter of .125, .25, .375,...
set the crack pipe down...
jesterjames is offline   Reply With Quote
Old 05-14-2011, 03:08 PM   #15
JH02WrxWag
Member#: 246743
02 Impreza WRX
platinum
Originally Posted by jesterjames View Post
your a moron,
Shut up, .124 to 1" isn't gonna port a 2-4" diameter.
Old 05-14-2011, 03:18 PM   #16
JH02WrxWag
Member#: 246743
02 Impreza WRX
platinum
When you go to port something that has to seat against another part you will more than likely lose the seal. The seal that was made by a machine that makes precise and level cuts.
Old 05-14-2011, 05:13 PM   #17
NitroTrike
Member#: 62408
You DO realize that the ports aren't "made" by machine into the heads, and that they are cast aluminum?
Old 05-14-2011, 05:35 PM   #18
JH02WrxWag
Member#: 246743
02 Impreza WRX
platinum
I know it is cast aluminum, but most parts still undergo a machined finish. The casting process leaves burrs and other protrusions.
Old 05-14-2011, 05:53 PM   #19
NitroTrike
Member#: 62408
Ok, explain to me what the machine finish has to do with cleaning up (burrs and other protrusions as you call them), slightly enlarging, or polishing HOLES that are already there? You're not using the cutting tools ON the gasket mounting surfaces themselves.
I think I'm starting to see why Scotty gets frustrated...
Old 05-14-2011, 05:55 PM   #20
jesterjames
Member#: 252663
which are taken out by hand because machining is too ****in expensive.
now shut up before you hurt yourself
Old 05-14-2011, 06:01 PM   #21
JH02WrxWag
Member#: 246743
02 Impreza WRX
platinum
Valve seats and other parts that need to seat. There is nothing wrong with refinishing the inside of the manifold. Just shouldn't use a de-burring bit unless it's on the proper diameter hole.
Old 05-14-2011, 06:07 PM   #22
NitroTrike
Member#: 62408
You don't port the valve seats, you dope.
This is hopeless.
Old 05-14-2011, 06:08 PM   #23
JH02WrxWag
Member#: 246743
02 Impreza WRX
platinum
Take a Vicodin, it's about using a de-burring bit not whether or not you or I think car manufactures pay to have their engines machine finished or by hand.
Old 05-14-2011, 06:10 PM   #24
JH02WrxWag
Member#: 246743
02 Impreza WRX
platinum
I'm not trying to dope, the original person still hasn't responded towards what they are actually trying to re-finish. They sitting back in amusement of they babble we've been writing.
Old 05-14-2011, 06:18 PM   #25
NitroTrike
Member#: 62408
They asked where to get burrs for aluminum, not what they are trying to de-burr, which is completely irrelevant.
I seriously have no idea why I am responding to someone who has obviously never stepped foot in a machine shop.
Oh yah, I'm just that bored.
Which carbide burrs for a port/polish job? upjeeper Built Motor Discussion 9 10-02-2007 10:56 AM
looking for aluminum chargepipe for v2 slanty i/c rockethound NWIC Private Classifieds 0 08-07-2007 04:55 PM
Looking for aluminum shifter trim for GC8... Where to find? Siper2 Interior & Exterior Modification 32 03-04-2002 11:53 AM
local source for aluminum tube and silicone connectors? Craig W Bay Area Impreza Club Forum -- BAIC 11 07-21-2001 02:52 AM
Looking for Aluminum Dash Kit 97+ DJIMPREZA Interior & Exterior Modification 6 12-28-2000 03:35 PM
