Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 07-21-2002, 08:14 PM   #1
tmaler13
Member#: 1992
Default What did i do?
Okay..on my last install job, i had to tap into the ecu wire that sends the throttle position. I accidentally grounded it while the car was running and did not relize it until about 5 miles down the road. I corrected this problem and everything went back to normal....Now sometimes my idle is a 1700 and then it settles down to its normal 700...what did i do...did i fry the sensor???
any please help.
I'm already throwing a code CEL for a bad front o2 sensor which is getting replaced next week.
-Terry
tmaler13 is offline   Reply With Quote
Old 07-22-2002, 10:38 AM   #2
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
If your front o2 sensor is bad the car won't idle right. When mine went bad it was the heater core that heats up the sensor to get a proper reading when exhaust gasses are still relatively cold. My car would barely idle and wouldn't run properly at all during partial throttle. I think I shaved about 25,000 miles off my clutch trying to slip it off the line while trying to remain at WOT to engage open loop mode which ignores that sensor. It wasn't fun.
Front o2 sensor should fix your idle problem.
Brad
MY99 2.5GT is offline   Reply With Quote
Old 07-22-2002, 10:39 AM   #3
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
By the way I hope the sensor was either covered under warranty or ordered from www.subaruparts.com. They are the absolute cheapest I could find them.
Brad
so what did you do in this heatwave today? this is what i did... shukes24 Mid West Subaru Owners Club Forum -- MWSOC 44 07-17-2006 03:39 PM
My Photographer comrades. what did i do wrong?? 56k do not enter!! D-I-Z-Z-L-E Off-Topic 17 01-13-2004 11:45 AM
('93-'01) What did you do tonight? me? I got carjacked.. Prog Impreza Forum 111 05-13-2001 04:22 PM
('93-'01) POLL..what did you do with your letters after you debadged your trunk SuBaRu-ImPrEzA_RS Impreza Forum 42 04-27-2001 08:39 AM
What did I do?! MrX Mid West Subaru Owners Club Forum -- MWSOC 5 09-21-2000 08:12 AM
