Old 07-21-2002, 08:22 PM   #1
Mancini
Member#: 20726
Post High RPM's
Is bouncing off the rev limiter "bad" for the car...say while autox'ing or running hard every now and then. Also I keep reading that redline is 6250, but it seems like on my 98 RS it cuts out at 6500. Can the valvetrain handle this stress or should I play more gently...
Thanks
PS: I know there is not much power above 6k.
Mancini is offline   Reply With Quote
Old 07-21-2002, 09:30 PM   #2
obyone
Member#: 16523
Default Re: High RPM's
Thanks
As for the rev limiter...it shouldn't be too bad if you bounce off it every so often, just don't hold it there for an extended period of time.
Edit a moronic statement.
obyone is offline   Reply With Quote
Old 07-21-2002, 10:03 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Don't chalk it up to the innaccurate tach, chalk it up to the fact that your '98 has a DOHC 2.5L with a higher rev limiter than the later SOHC engine. I've heard the DOHC rev limiter is anywhere from 6500rpm to 6750rpm, so I'm not sure what is the truth. I've seen over 6500rpm - up to maybe 6650rpm - without hitting the rev limiter.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 07-21-2002, 10:08 PM   #4
fast tech
Member#: 15219
Default rpm rateing
I have a autometer memory tach in my sohc rs so it saves the highest point which is 5,400 but remember this is ran off of the stock computer wire so the only way to get a accurate reading is to run on of the coil wire.....
fast tech is offline   Reply With Quote
Old 07-21-2002, 10:10 PM   #5
dsj
Member#: 10333
2002 Impreza 2.5 RS
Midnight Black Pearl
Not that I ever take my car to redline , but if I did, I would be able to tell you that my '02RS tach regularly passed 6250 rpm during spirited driving. I would tell you (if I ever actually revved the engine high enough) that it had made it to 6400 or so on the tach before I shifted. I would attribute this to accuracy errors in the tach reading. Later.
dsj is offline   Reply With Quote
Old 07-23-2002, 02:19 AM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
My 6000 redline sucks
Old 07-23-2002, 01:53 PM   #7
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
I think COBB tested the stock engine and said it can safely rev to about 7 grand. You should be fine bouncing it off the rev limited after all its there so you donít blow your engine up.
Burnout is offline   Reply With Quote
Old 07-23-2002, 02:04 PM   #8
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Kostamojen: 6000rpm redline? So the 1.8 liter is not only weak but it cannot rev as high either?
Old 07-23-2002, 04:43 PM   #9
Merdock777
Member#: 21256
2002 Impreza 2.5RS
BlindYoAssPlatinumSilver
My 02's redline is marked 6250, I'll go all the way up to about 6400 if I want to move, and twice I've hit the limiter at 6500 RPM's. hope that can help a little.
Merdock777 is offline   Reply With Quote
Old 07-23-2002, 06:30 PM   #10
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
I would assume that SOA would design the rev limiter to cut in before anything "bad" happens. Think of it as a saftey device...this is as high as you can go before you f something up. It would make sense to have the rev limiter cut in BEFORE and not after you do real "beyond the capabilites of the motor" damage to the car.
I could be totally wrong though...so don't take my word on it!
NC
Reciprocity is online now   Reply With Quote
Old 07-23-2002, 06:31 PM   #11
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Originally posted by DoinkMobb
The part I like the best about the 1.8L is when you floor it...and nothing happens.
We need cams
Old 07-23-2002, 10:04 PM   #12
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Originally posted by Kostamojen
We need cams
... or a 39% increase in displacement.
Pat
Old 07-23-2002, 11:34 PM   #13
obyone
Member#: 16523
Pat
He needs a good dose of Turbonium.
Old 07-24-2002, 03:28 AM   #14
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Pat
Naw, I just want a 7000 redline and some stiffer valve springs with cams that put the power up 1000rpms ala cobb's cams... Screw it if the engine blows, ill just get an EJ25 then I just want something unique!
very weird noise @ High RPM's DEALBATONY Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-07-2010 10:50 PM
Loud "Chunk" when shifting at high RPM's chadwich Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-15-2002 04:01 PM
High RPM's monicarich1 Transmission (AT/MT) & Driveline 8 12-21-2001 12:10 AM
Help: Gear crunching 3rd to 4th @ high rpm's (02 wrx) Blackskull Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-31-2001 12:00 AM
