05-14-2011, 07:27 PM | #1 |
Member#: 197764
NESIC
Vehicle:2002 Nissan Frontier buh bye WRX :( |
So... anyone else mount hellas behind their grille?
No, not the supertones
I've always loved the look of aux lighting on our cars, but unless its the winter time a light bar just wouldn't fit my typical equip. I figured there was still some hope to making something work, however. So following some old school Mustang styling queues I'm fond of, I tried something out this weekend with a set of Black Magic 500 Hella lamps. I photoshoped this a few times until I liked what I was seeing, then set out to make it a reality. The biggest problem with this kind of install is that there isn't a place to mount lights here. Zero, zip, nada, none. I must have stared into the front of my engine bay for at least an hour before I came up with this ghetto superstar solution. The first thing I needed was something sturdy and rigid to mount the lamps to, and thus I chose to use a box aluminum bar. Finding a place to hang/mount it to was difficult, though. I ended up cutting apart a piece of U shaped aluminum I was planning to use to reinforce the back of my splitter, pop riveted the whole thing together, and mounted it up to the top radiator bolts. It turns out to be quite a rigid setup. This was a convenient design as its very low profile behind the grille as well. (Yes, my engine bay is incredibly dirty. Sure ain't a show car!) Note also the mounts look a little tilted/skewed in respect to each other, but this is to clear the headlights (asymmetrical) I used some un-peeled weather stripping tape to protect the leads from grinding against the radiator over bumps, as well as protect the lamp backing. All things considered though, it takes a lot of force to move this thing. I know some other folks have done this before, but not that I've seen on a bug or in this way. And thus another aux lighting solution is born! Now I'm on the fence about cutting the grille and adding some ABS rings (partial rings) around the circumference of the lights. Of course, it must be photoshop approved first
05-14-2011, 07:31 PM | #2 |
Member#: 211395
South East
Vehicle:0000 4wfp Flintstone Mobile made of stone+wood |
I like ths a lot! I've been a huge fan of lightbars, but they break up otherwise clean lines. How's the output?
05-14-2011, 07:33 PM | #3 |
Member#: 197764
NESIC
Here's a couple lighting pictures as well (snapped them on auto, hence the dark pics)
05-14-2011, 07:35 PM | #4 |
Member#: 197764
NESIC
Thanks! I haven't been able to drive them in the dark yet, but I'll definitely report back and with pics. This is a another reason I'm thinking of cutting the grill up and adding some 'rings' around the lights, but I also don't want to ruin the subtlety
05-14-2011, 07:40 PM | #5 |
Member#: 172917
NESIC
Vehicle:2004 WRX WRB |
That looks like a BAMF
05-14-2011, 07:47 PM | #6 |
Member#: 222041
South East
Vehicle:2009 Impreza 2.5i PRP |
when i saw the thread title i was all like
then i saw the write up and then i was like And seeing the pics.... my opinion.... that looks ****ing sick Clean and nice install job oh and thanks for not putting in HID bulbs dood lol |
05-14-2011, 07:49 PM | #7 |
Member#: 92114
NESIC
Vehicle:03 WRX (NAVY Camo) in"Special Ed." Run Group |
I really like it, my only concern would be blocking cooling flow to the rad, etc...
05-14-2011, 07:53 PM | #8 |
Member#: 275630
SCIC
Vehicle:2016 WRX Spark Silver |
05-14-2011, 07:59 PM | #9 | |
Member#: 197764
NESIC
I've considered the cooling aspect and definitely plan to monitor heat for a while, especially getting into the summer. Frankly, I can't imagine it being any worse if as bad as putting an FMIC over the hole bottom section, which reduces flow to a more substantial portion of the radiator. Additionally, I believe this is less likely to inhibit cooling than putting fog lights just outside of the grille would, as this diverts air entering the grille around the lights and doesn't spoil air around the grille and hood (all super dooper hypothetical of course). Also, night shots incoming |
05-14-2011, 08:15 PM | #10 | |
Member#: 169556
AKIC
Vehicle:07' OPB STi BW S256 01' 2.5rs GM6 w/leather! |
I also clicked this thread to see the OP flamed... but had same reaction |
05-14-2011, 08:18 PM | #11 |
Member#: 197764
NESIC
Here are a few samples of the output. It also looks like I've got to lower my drivers side headlight a click or two, I must have knocked the bulb up at some point removing them.
Regular lights Regular + lower fogs (PIAA bulbs) Everything on |
05-14-2011, 08:20 PM | #12 |
Member#: 92858
turn lights on for 10 minutes. Place hand near lamp.
Hott Ouch. That hot air is going directly around the lights into your radiator. cooling will be not efficient anymore. if it melts your grille some, you will also see how hot they get. |
05-14-2011, 08:27 PM | #13 | |
Member#: 197764
NESIC
Again, temp readings will determine everything, not hypothesis. AFAIC, lights off during day, on at night --> high air temp during day = low air temp at night + increase in air temp due to lights. This is all more than likely negligible anyway. |
05-14-2011, 08:41 PM | #14 |
Member#: 62408
South East
Vehicle:2002 wrx w/ STi guts 174k miles on Mobil 1 |
I like it. You also could have saved a few bucks and used a piece of angle aluminum instead of square tubing, and you wouldn't have had to cut the holes to tighten the nuts =]
Did you wire them to their own switches, or do they come on with the fogs? I have a box full of Bosch relays I've been dying to use. |
05-14-2011, 11:13 PM | #15 |
Member#: 226246
Vehicle:2005 Impreza 2.5 RS Silver |
sick. creative, clean, different, love it.
05-15-2011, 12:01 AM | #16 |
Member#: 250954
BAIC
Vehicle:2006 Forester XT SGM |
Looks good. I can't imagine that the lights would block much more airflow than a pair of super tones. Besides the aforementioned heated air from the lamps.
05-15-2011, 01:03 AM | #17 |
Member#: 207826
Vehicle:85k 2002 WRX Correct Fitment Crew #034 |
I like it!
05-15-2011, 01:59 AM | #18 |
Member#: 277987
W. Canada
looks really mean
edit-could i also get a rear shot of your car? i was looking at doing a wrx with with roof vane. Last edited by Rapier46; 05-15-2011 at 02:23 AM. |
05-15-2011, 02:03 AM | #19 |
Member#: 180514
Vehicle:2004 Sti WRB |
A night shot pls.
05-15-2011, 12:47 PM | #20 |
Member#: 249794
Vehicle:02 WRX wagon atomic orange pearl |
Very cool idea, might have to replace my supertones with a set of driving lights! lol I know off topic, but what hood scoop are you running?
05-15-2011, 12:53 PM | #21 |
Member#: 233604
NESIC
Vehicle:2011 WRX P. SWP |
Looks sick. and besides the lights, nice bigeye!
My first thought was that they might hurt airflow into the radiators or melt something. They'd probably be fine with cooler temps/ winter..but I would be worried to rock them on a 90 degree day (though why would you) |
05-15-2011, 01:10 PM | #22 |
Member#: 150248
SCIC
Vehicle:08 FXT Sports WRB |
Holy rusted bolts, Batman!! lol
That looks awesome, though. I'm a 'Stang fan as well so I can appreciate where you're coming from! |
05-15-2011, 01:14 PM | #23 |
Member#: 261910
Vehicle:2004 WRX PSM |
Looks great! I love it.
05-15-2011, 02:13 PM | #24 |
Member#: 276710
Vehicle:2010 Impreza 2.5i Dark Grey Metallic |
nice!
05-15-2011, 02:41 PM | #25 | ||
Member#: 197764
NESIC
Thanks for the feedback all!
Also, all the lights are now independent so as long as at least parking lights are on, everything can come on separately. And use those relays!! The scoop was actually made out of a WRX stock scoop by one of the NESIC members. Its a super clean job! |
So. Anyone else going to be packing their colon full of meat this weekend? | UberWilhelm | Off-Topic | 9 | 01-29-2009 11:14 AM |
So anyone else upgrade their PSPs to 2.0? | SlickWRX | Off-Topic | 13 | 08-01-2005 08:37 AM |
Does anyone else have issues with their H3 foglight bulbs? | obyone | Interior & Exterior Modification | 9 | 11-08-2002 09:55 PM |
mounting lights behind the grille | tdxflex | Interior & Exterior Modification | 9 | 10-26-2002 12:49 AM |
