Old 02-02-2012, 05:23 PM   #51
meifert
Member#: 301676
2009 Forester XT
Originally Posted by cheizy View Post
looks good merfert! what hellas are you running? also did you route them to make it your DRLs?
they turn on with a switch mounted by by the fuse panel. Hella 500 Black Magic. the brack is a piece of flatbar bolted to the radiator support.
meifert is offline   Reply With Quote
Old 02-02-2012, 06:42 PM   #52
yeos
Member#: 133855
2009 STi SparkSilver
Dom Tuned @ MPS
Looks good meifert. I'm in the process of making a light bar for my STi mainly for a pair of Hella 500FF fogs. After seeing this thread, I may end up going with a pair of driving lights behind the grille.
yeos is offline   Reply With Quote
Old 02-03-2012, 06:04 AM   #53
j555hks
Member#: 292289
02 impreza STI
WHITE
Originally Posted by con10der8 View Post
thanks for the inspiration...
new intercepter for remake of mad max movie ...awsome.
j555hks is offline   Reply With Quote
Old 02-18-2012, 08:21 PM   #54
moltenbykes
Member#: 260372
2012 OBP STI 5-Door
Did anyone do this to an STI?(my 2012 is on order) Any issues with cooling/airflow to the radiator? Would I need to remove them before going to the track/autocross?
moltenbykes is offline   Reply With Quote
Old 02-18-2012, 08:49 PM   #55
meifert
Member#: 301676
2009 Forester XT
I rebuilt my mounting bracket for more to make them more adjustable. picked up a set of heavy duty agle brackets at Home Depot, a 36 inch piece of flat bar, redrilled the mounting bracket, measured and drilled the flatbar, mounted the lights. I want to order the sport grill but not sure if it will fit. I also need to redrill the brackets and move the light bar back about an inch.
Old 02-22-2012, 03:10 PM   #56
blown ION
Member#: 301307
2011 WRX sedan
^^ very nice job on the brackets. I'm going to begin tackling this soon with a set of piaa 510's. Do you get any light bounce with the newer style brackets above?
blown ION is offline   Reply With Quote
Old 02-22-2012, 03:21 PM   #57
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Any pics with the grille in place?
phenryiv1 is offline   Reply With Quote
Old 02-22-2012, 04:44 PM   #58
meifert
Member#: 301676
2009 Forester XT
a little bit.....but it's from the Hella mounts. my bracket is stupidly stiff.
old grill
lights on at night....still seeing spots.
Here is a pic with the new Subaru Mesh grill in. looks about 1000x better.
Old 02-22-2012, 04:48 PM   #59
bc9235
Member#: 307333
2011 Impreza 2.5i
SSM
Looks good! Is it just me, or is the driver side a little lower than the passenger side light though? Could just be me haha
bc9235 is offline   Reply With Quote
Old 02-22-2012, 04:51 PM   #60
meifert
Member#: 301676
2009 Forester XT
i think it's the angle of the picture that really shows it. the right light is 1/8 of an inch higher and i can't find a 1/16 inch spacer to fix it....FML.
Old 02-22-2012, 05:16 PM   #61
2004wrxy
Member#: 237136
2003 WRX 6MT
JBP
Really? You can't find anything? I have a 10 mm washer right here that is 1.7mm thick , 2 tenths of a mil bigger than you 1/16 you need....
Im sure any washer will do...
looks good btw, I'm going to steal your bracket idea. Thanks!
2004wrxy is offline   Reply With Quote
Old 02-22-2012, 05:20 PM   #62
meifert
Member#: 301676
2009 Forester XT
the issue is i can find one that is the right height but the hole is too small. when they are anyone who tries to notice would be blinded anyways...LOL
Old 02-22-2012, 07:48 PM   #63
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Hey I did this!
Digital Dillon is offline   Reply With Quote
Old 02-22-2012, 07:52 PM   #64
meifert
Member#: 301676
2009 Forester XT
Originally Posted by Digital Dillon View Post
Hey I did this!
what lights?
Old 02-22-2012, 08:04 PM   #65
Digital Dillon
Member#: 288727
2008 WRX premium
what lights?
Hella 500FF's
Old 02-22-2012, 08:22 PM   #66
PlasticFoamMan
Member#: 197764
2002 Nissan Frontier
buh bye WRX :(
Love seeing this being done now!
I saw a few question on measurements from a little while back. When I have my front end taken apart next I'll make sure to spec out the dimensions of the original, although I plan to build a less-ghetto, welded second version to better place a transmission cooler.
Keep up the awesome work guys!
PlasticFoamMan is offline   Reply With Quote
Old 02-22-2012, 08:30 PM   #67
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
I put a set of hella micro FF's behind the grill on my old outback.
Mounts attached with the radiator bolt and along the "pinch" seam on the back of the bumper beam. SOLID, never jiggled at all.
(The wiring got cleaned up and hidden, I think this pic was kind of a test fit "here's my progess so far" shot)
here they are with the regular headlights and Hella ff1000's that replaced the stock foglights.
aerosaaber is offline   Reply With Quote
Old 02-22-2012, 08:35 PM   #68
bbun
Member#: 184554
02 ghettoFABness
bugeye rolling.
hmm... have some hella 530s just laying around.
wonder how it would look under the bottom grill.
bbun is offline   Reply With Quote
Old 02-22-2012, 08:59 PM   #69
meifert
Member#: 301676
2009 Forester XT
I want some square Black Magics for the lower grill if they make them.
Old 02-22-2012, 09:46 PM   #70
STGuy
Member#: 262734
2004 STI
Meifert. What bulbs are you running in your black magic's? You and the op have the same lights but yours almost look like they have hid's
STGuy is offline   Reply With Quote
Old 02-22-2012, 09:53 PM   #71
meifert
Member#: 301676
2009 Forester XT
they came with them. I dont know if they are HID or not but they are bright.
Old 02-22-2012, 10:30 PM   #72
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
They would have external ballasts if they were HIDs.
Old 02-22-2012, 10:33 PM   #73
meifert
Member#: 301676
2009 Forester XT
they aren't HIDs then.
Old 02-23-2012, 10:25 PM   #74
Stoned_Llama
Member#: 205049
2008 WRX
I paint matched mine and have them tucked behind a blue sports grill :-P
Also got the paint matched bezels around my TSX projectors.
Stoned_Llama is offline   Reply With Quote
Old 02-23-2012, 10:28 PM   #75
dan3d
Member#: 169807
2011 WRX Hatch
^^umm wrong thread Bro
dan3d is offline   Reply With Quote
So. Anyone else going to be packing their colon full of meat this weekend? UberWilhelm Off-Topic 9 01-29-2009 11:14 AM
So anyone else upgrade their PSPs to 2.0? SlickWRX Off-Topic 13 08-01-2005 08:37 AM
Does anyone else have issues with their H3 foglight bulbs? obyone Interior & Exterior Modification 9 11-08-2002 09:55 PM
mounting lights behind the grille tdxflex Interior & Exterior Modification 9 10-26-2002 12:49 AM
