Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 05-14-2011, 10:59 PM   #1
Tglazed
Member#: 231216
Default Turbo install
I am getting ready to install a fp 18g and was just curious if I should know or buy anything in advance. Specifically oil lines.
Tglazed is offline   Reply With Quote
Old 05-14-2011, 11:26 PM   #2
ammo0000
Member#: 175401
2007 VF39'd OBP WRX
2008 Blue Kawi ZX-10R
Gaskets for both sides of the turbo and coolant for when you spill it immediately come to mind. It's not a bad idea to pick up some heat wrap, turbo blanket and heat reflecting tape(or any combination of the 3 to help underhood temps and to keep the IC cool.
ammo0000 is offline   Reply With Quote
Old 05-15-2011, 12:23 AM   #3
azn2nr
Member#: 35276
dust collector
just make sure you dont have an oil restrictor in the turbo side banjo. if you have a pre 05 swap non sti you should be fine. i went with a fp line to be safe as its longer and pretty much garunteed to fit.
if you order the fp line, call them dont do it on their website. youll save some money on at least shipping
azn2nr is offline   Reply With Quote
Old 05-15-2011, 01:50 AM   #4
bhhamblin
n00b Moderator
Member#: 99397
'13 BRZ, '13 STi
SRs13 '83 Skyline '93 GTR
If this is my old turbo you bought the stock oil line and banjo will fit just fine.
bhhamblin is offline   Reply With Quote
Old 05-15-2011, 12:26 PM   #5
Tglazed
Member#: 231216
It is your old turbo. Also it's an 03 Wrx swap sorry for not clarifying that. Can anyone clarify which line goes where I just dont want to mess up
Old 05-15-2011, 12:37 PM   #6
bhhamblin
n00b Moderator
Member#: 99397
'13 BRZ, '13 STi
the lines on the turbo will look just like the factory lines. so just make sure you hook them up like factory and you will be good to do. also dont forget about the oil return line on the bottom of the turbo. it can be kinda pesky sometimes. if its not connected, prepare to lose tons of oil.
Old 05-15-2011, 01:55 PM   #7
Tglazed
Member#: 231216
I'll make sure to pick up an extra quart of oil and some coolant first
Old 05-15-2011, 04:19 PM   #8
Mush04
Member#: 191705
2004 White WRX
Cleverly Tuned Stage ????
yeah you should be fine, you probably wont really lose any oil, I don't think I did on either of the swaps I've done, but couldn't hurt to have a little extra of course. the only thing I would say to remember is your line with the restirctor haha I had mine backwards at first and couldn't build much boost. but sounds like you'll be fine. have fun!!
Mush04 is offline   Reply With Quote
Old 05-15-2011, 04:26 PM   #9
Tglazed
Member#: 231216
Well if you get some extra time mush04, you can always stop by Saturday morning early. It's getting tuned at 5 pm on Saturday night so I have to have it all done by then
Old 05-15-2011, 06:14 PM   #10
Tglazed
Member#: 231216
Also I am installing injectors and am more nervous about this then the turbo any advice on this?
Old 05-15-2011, 06:17 PM   #11
subiewrx001
Member#: 193591
2004 wrx
When I do the banjo bolt I hand tighten it then prime the system with oil and make sure a little bit of oil comes out the banjo then snug it down, this way you know your turbo has oil before startup.
subiewrx001 is offline   Reply With Quote
Old 05-15-2011, 06:19 PM   #12
subiewrx001
Member#: 193591
2004 wrx
Here's a good write up with pics.
http://www.google.com/m/url?client=m...y8oe9YVTnHxzcQ
Old 05-15-2011, 06:26 PM   #13
subiewrx001
Member#: 193591
2004 wrx
I always change my oil on a turbo install, I plugged my coolant lines the first time which will get coolant all over, the second time I changed my oil and coolant which makes it much easier in my opinion.
Old 05-15-2011, 08:17 PM   #14
Tglazed
Member#: 231216
A little bit more on this. I'm new to this what's the banjo bolt, how do I prime it?
Old 05-15-2011, 08:32 PM   #15
subiewrx001
Member#: 193591
2004 wrx
On the passenger side in the trunk under the trunk liner is your fuel pump module which I unplug to ensure no fuel gets to the engine, I usually crank the engine for 10 seconds like 3 or 4 times to prime your turbo. The banjo bolt is the bolt that threads into the port directly ontop in the middle of the turbo. In my opinion the turbo and injectors are some of the easiest things to replace.
Old 05-15-2011, 08:50 PM   #16
Tglazed
Member#: 231216
cool thanks for all the help guys. If your bored friday night saturday morning your welcome over haha.
Old 05-16-2011, 01:34 PM   #17
Mush04
Member#: 191705
2004 White WRX
Hey sorry man didn't check nasioc either time, did you get it all installed and tuned just fine though?
Old 05-16-2011, 11:30 PM   #18
Tglazed
Member#: 231216
sorry for the confusion its getting installed and tuned friday and saturday of this week.
Old 05-17-2011, 12:38 PM   #19
Mush04
Member#: 191705
2004 White WRX
oh haha I did get pretty confused there, but that's cool if you do run into any problems let me know, I'll PM you my cell.
Old 05-20-2011, 09:04 AM   #20
Tglazed
Member#: 231216
I pulled the old turbo of last night and the very bottom line sprayed some coolant in the up pipe before i got it plugged, do i need to worry about anything?
Old 05-20-2011, 09:39 AM   #21
bhhamblin
n00b Moderator
Member#: 99397
'13 BRZ, '13 STi
no, itll burn off.
Old 05-20-2011, 09:54 AM   #22
Tglazed
Member#: 231216
It was inside the up pipe though am I still good
Old 05-20-2011, 10:07 AM   #23
RicersWetDream
Member#: 245581
2009 WRX
Spark Silver Metallic
Yeah, it'll just burn off. If you dumped a gallon maybe drain it out but a quick spray will just be a few seconds of white smoke.
RicersWetDream is offline   Reply With Quote
Old 05-20-2011, 12:05 PM   #24
Mush04
Member#: 191705
2004 White WRX
yeah I spilled some in my uppipe too, no issues. haha I lost quite a bit cause I didn't think about shoving something in the hose to plug it.
Old 05-20-2011, 06:23 PM   #25
Tglazed
Member#: 231216
Cool thanks guys.
Change Turbo Inlet with Turbo Install? Coop1103 Factory 2.5L Turbo Powertrain 25 07-26-2010 10:56 PM
Help: Clutch Install and Turbo Install evo8asti New England Impreza Club Forum -- NESIC 2 05-23-2006 09:07 PM
is turbo install harder than up pipe install? VajraTLR Factory 2.0L Turbo Powertrain 18 12-12-2005 09:18 PM
anyone with turbo install experience have time to help finish VF34 install in SD? JohnW Southern California Impreza Club Forum -- SCIC 9 02-11-2004 02:27 PM
Legacy Turbo/WRX Turbo install on 2.5 blaster88 Factory 2.0L Turbo Powertrain 3 03-21-2001 10:23 AM
Message Board Statistics All times are GMT -4. The time now is 09:18 AM.
