Old 05-15-2011, 01:54 PM   #1
Kamikaze531
Member#: 96347
2003 WRX Sedan
Default Leaking refrigerant at compressor
My A/C system is leaking refrigerant where the high pressure line attaches to the compressor. I looked at the online diagrams, and it looks like there's an o-ring or crush washer there to seal it, but I can't find one that lists a part description or number. Does anyone know what this one is?
Edit: It's an '03 WRX Sedan if that makes a difference.
Kamikaze531 is offline   Reply With Quote
Old 05-15-2011, 02:05 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
its an o-ring
you can get a variety pack of o-rings for ac systems for cheap...and the proper size should be fairly easy to determine
but to fix the issue properly you will need a vac pump and gauges and freon
EWG UP leaking again at 2bolt Mactizen Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 06-29-2007 12:19 PM
dl trans leaks oil at rear drive line connection bobgreer 'Old School' Subaru Forum 4 05-24-2006 01:47 AM
help uppipe leak look at 2.0 forum thank you tsubaru02 Newbies & FAQs 4 04-26-2005 12:03 PM
Leaking fuel at both fuel rails!! WS6toWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-24-2004 10:55 AM
Power Steering Leak, where at those loose fittings? 275Performance Service & Maintenance 0 05-03-2003 11:46 PM
