Old 07-21-2002, 10:03 PM   #1
THAITEA87
Member#: 21424
02 wrx soon
i want black
Default how 2 make 10s
wats the cheapest way 2 make a 2002 wrx run 10s????i was hopin under $12k.If sum peeps can run 12s wit only a Turboback and nos, runin 10s wont be 2 bad..........right???
PLEASE HELP!
THAITEA87 is offline   Reply With Quote
Old 07-21-2002, 10:06 PM   #2
cwb124
Member#: 15571
2006 06 Forester XT
I truly hope this is a joke. Please God let it be a joke!!
cwb124 is offline   Reply With Quote
Old 07-21-2002, 10:28 PM   #3
jimb
Member#: 9923
2005 Legacy GT
RIP MBP WRX
Running 10's is easy.. Sell your wrx, that should get you about 18 grand.. Combine the 12 grand you were willing to spend with your new found 18k, and you now have $30 thousand. With $30,000 in your pocket, it should be relatively easy to find a decent shop to build you a dedicated drag car that will run 10s.. It will certainly not be street legal, or even streetable for that matter. You might want to put about $150 of your $30,000 aside to pay for a bicycle or cheap moped to get you around town. Pretty simple if you ask me.
jb
jimb is offline   Reply With Quote
Old 07-22-2002, 12:13 AM   #4
Andrew
Member#: 1170
2005 STi
you can do it legally. just buy a pre-emissions car. like a 240z. stick a blown 350 with a two stage nitrous system in it and you are set. way below 10s with money to spare.
Andrew is offline   Reply With Quote
Old 07-22-2002, 01:54 AM   #5
NotoriousWRX
Member#: 9026
n00b
NotoriousWRX is offline   Reply With Quote
Old 07-22-2002, 09:04 PM   #6
TorsWRX
Member#: 21261
2002 Impreza WRX Sed
WR Blue Pearl
Cheapest way = yellow stickers. Low 5's for sure with these
TorsWRX is offline   Reply With Quote
Old 07-22-2002, 11:11 PM   #7
WRteXmeX
Member#: 13764
2004 WRX wagon*gone*
"radio flyer"
wont take much, well..probably will..but make sure you have a tranny and clutch that can handle the power. come down to houston, I know a few places around here
WRteXmeX is offline   Reply With Quote
Old 07-23-2002, 03:23 AM   #8
Hungtodafloor
Member#: 21234
1985 VW Fox
Rust
i am gona try and help you since most are makin fun of you.i know how it is to not have a wrx.
you are gonna need everything you have ever seen available(CAI,pullies,FMIC, etc) you are also gonna need to get eithre a 2.2 or 2.4 liter stroker kit and get a shop to bore out your cylinders and throttlebody. you will also need a full dog-box tranny and new clutch. you should also look into weight reduction(gut interior, cf everything,wheels and tires) another things is a custom hybrid turbo that would require a custom turbo-back exhaust. also improve aerodynamics with a cf body kit. you will need nos and alot of it. alot of forging of pistons.
basically you will need money and some good shops around you to do all of the custom boring, forging, exhaust, turbo. 12k is not reasonable due to your lack of expertise. expect to spend 12k alone on the tranny! hope i helped
p.s. sorry for my post being so scattered. also, people keep saying to sell the wrx and get a muscle car. i don't know whether you are trying to be funny or not but he asked for advice on the car this forum is about looking and expecting help. let's not turn into i-club! .... oh wait
Hungtodafloor is offline   Reply With Quote
Old 07-23-2002, 05:40 AM   #9
hotrod
Member#: 14141
2002 Impreza WRX
Default not cheap, not easy
To run 10.0 ET you need a power to weight ratio of about 5 to 1, so for a stock weight WRX, you'd need just short of 650 HP.
To just crack a 10.999, you'd need a power to weight ratio of about 6.75 to 1, or about 485 HP as a minimum.
I'd say double your cash in hand, and then give it a try.
Larry
hotrod is offline   Reply With Quote
Old 07-23-2002, 07:59 AM   #10
Wrex4Life
Member#: 21745
1998 Subaru WRX
Green
I have a 10 sec Rex. Best run is a 10.19 @ 141mph. But my street setup would do a 10.5 (approx)
You will need way more than 12K US. I spent AT LEAST 25K US, which down here in Australia is about $50,000. Probably more.
Hope this helps on the financial side. If you want to know about the mods. I posted them in the Newbie section.
Cheers.
Wrex4Life is offline   Reply With Quote
Old 07-23-2002, 09:05 AM   #11
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Re: not cheap, not easy
Larry
Larry,
Could you tell me how or show a link to how you came across what power to weight ratio you'd need to achieve a certain 1/4 mile time?
Going by what Larry said as far as power to weight ratio, here's what you'd need to do. *Goal 430hp*
1) You'd have to have an automatic....here's why: You would be using a totally beefened up tranny from Level 10. $4.5k or so, *Beefier parts, upgraded/higher stall torque converter, valve body, the works*
2) Lighten your car to approximately 2800lbs. Yeah, you better gut the hell out of it but you should be able to do it,
3) Upgrade your injectors to be able to use [email protected]% duty cycle,
4) Get manual boost controller to bring hp up to the most you can get with your stock turbo without too much added heat,
5) Add a direct port nitrous kit (not needed with upgraded injectors but helps) to achieve exactly 430hp.
Easy enough?
Kevin Thomas is offline   Reply With Quote
Old 07-23-2002, 10:57 AM   #12
Mariano
Member#: 56
Chapter/Region: PRSIC
1999 RS-T (Stage V)
2005 LGT LTD
Talking
First yu habe too learn how to spel; then yu myght be able to an logikaly orginice yur grandmar 4 beter comunikation......
I'm just fooling around..... no hard feelings Better listen to Kevin....
Mariano
(12.52 @ 112 mph)
Mariano is offline   Reply With Quote
Old 07-23-2002, 10:20 PM   #13
stiguy555
Member#: 11190
1992 Lexus SC400
1998 Forester - Green :D
AHH! All of these numbers strike fear and confusion into me!
stiguy555 is offline   Reply With Quote
Old 07-24-2002, 03:16 PM   #14
Akirasoft
Member#: 2973
2015 X3 35i M-Sport
Thats pretty easy....
2.5 block, 100 bucks
Machineing for block, 1000 or so
Forged pistons, 800
Forged conrods, 800
STi heads, used from jp, 500
TD07-25G from Fuso in junkyard, 20 bucks
Fuso front mount (same as Trust core) 20 bucks
turbo rebuild, 300
end tanks and pipework for FMIC, 300
1150cc injectors, 500
2 warlbro fuel pumps, 400
fuel rails, 200
standalone 2000
used dogbox from japan, 500
That puts you at about 7k, give or take. With that you can run a 10, figure about 500-600hp at the crank
The car won't idle for $h1t and be a PITA to drive around, but it will run 10s
Akirasoft is offline   Reply With Quote
Old 07-25-2002, 12:44 AM   #15
Wrex4Life
Member#: 21745
1998 Subaru WRX
Green
Are you for real Akirasoft. Those prices are extremely cheap.
Forgies for $800, dont think so.
Anyway, I am going to give you the benefit of the doubt and come to the conclusion you are being sarcastic.
Old 07-25-2002, 01:06 AM   #16
Hungtodafloor
Member#: 21234
1985 VW Fox
Rust
kevin,
you would not have to run an auto. if anything run a full dogbox which can run 8-12k!
you can get the wrx way lower than that weight wise. if you are gonna race this beast then get it down to 2500lbs. the rally is 2500 with a full cage and spare+parts.
definitely injectors!either bigger or get more of them. some say more is better and shows less work on each injector. go for some 800cc
if you are gonna spend this $ then buy an ebc. that way you can master tweak your boost. and get afc to sort out thos rich injectors.
Nitrous is a must. with forged internals and a 2.5 block along with injectors and rails you can run a 100-125 shot. it would be risky but would fly!
oh and to akirasoft: those prices are ludicrous! also, who wants to buy vital internals used from japan. you are obviously making this up! a dogbox for 500 bucks? i would maybe quadruple your estimate and add some nitrous and slicks and maybe you can come close.
i don't mean to disagree with ya kev but i am just trying to add some advice.
Old 07-25-2002, 01:09 AM   #17
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
theres a shop here that will make a set of forged pistons for any 4cyl to your specs for $500, and rods for $400, so i doubt $800 was being sarcastic.
akirasoft, is the fuso you were referring to a mitsubishi fuso? the intercooler is the same as the trust? my friend is looking for a cheap intercooler upgrade for his talon...
jasona is offline   Reply With Quote
Old 07-25-2002, 02:27 AM   #18
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Trade it in for a Supra
Old 07-25-2002, 09:36 AM   #19
Kevin Thomas
Member#: 110
1989 1989 XT6
Default Re: how 2 make 10s
PLEASE HELP!
"kevin,
you would not have to run an auto. if anything run a full dogbox which can run 8-12k!"
Hungtodafloor (Funny name....Lol! Cool!),
I was making my suggestions based on his price range (under 12k). Just throwing stuff up in the air in good fun. I don't think most people trying to achieve 10 second or single digit 1/4 mile times from their scoobies would consult this board. They'd probably already have a game plan.
Old 07-25-2002, 12:48 PM   #20
Akirasoft
Member#: 2973
2015 X3 35i M-Sport
Jasona, yeah, the intercooler is the same core that trust uses. Buddy of mine is putting it on his Laser along with a TD07-25G...
Those prices are all real. You just have to find a way to get the parts into the US.
EVERYONE FIND/MAKE JAPANESE FRIENDS!
Old 07-25-2002, 06:10 PM   #21
hotrod
Member#: 14141
2002 Impreza WRX
Default Power to weight from ET
Kevin:
I just worked one of the how much power from ET calculators backwards.
http://www.ihonk.com/h/speedcalculators/racing.html
Larry
how 2 make fogs run whenever nwrDRIVER Interior & Exterior Modification 11 12-24-2008 12:57 AM
2 eclipse 10s subs in ported box! javikris Interior/Dressup/Audio & Security 2 08-12-2008 11:49 PM
2 eclipse 10s subs in ported box! javikris NESIC Private Classifieds 1 08-12-2008 11:49 PM
How 2 make o3 rs faster..? Subey03 Newbies & FAQs 18 11-06-2007 03:15 AM
How to make a warble on a 2.5NA wagons_ho! Normally Aspirated Powertrain 42 02-14-2006 05:57 AM
