Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 07-21-2002, 11:07 PM   #1
STEALTH-WRX
Member#: 7822
Multi layer snot green
Default what jets sizes to use on my nitrous oxide wet kit
what size just do i use for fuel and for nitrous oxide. what are other people using. what jet sizes equate to what horsepower. also if i boost more should i use a little bittle larger fuel jet to compensate so it will not be lean, since i dont have injectors. any help would be great.
STEALTH-WRX is offline   Reply With Quote
Old 07-22-2002, 12:59 AM   #2
STEALTH-WRX
Member#: 7822
no one knows? i have done various searches and no one seems to know.
Old 07-22-2002, 10:29 AM   #3
zeke79
Member#: 17981
2002 wrx
black
i am pretty sure the proper jet to choose would be relative to the fuel pressure you are running. the wrx runs on a 1:1 ratio. for example if you see 35 psi fuel pressure at zero boost then you should see 50 psi at 15lbs boost. what i am trying to say is i feel that you should not have to change jets for higher boost due to the fact that the stock pump will raise pressure according to boost, thus providing more fuel through the nitrous fuel jet. i used the standard 50hp fuel jet with my nos wet kit (#50132 i think). i have not seen any high egts or lean conditions. just be aware that you will see a boost spike of about 2-3psi with the nitrous engaged. i used a turbo xs dual stage boost controller and keep my low setting at 13-14psi for nitrous use and usually see around 16 psi on the bottle. i hope this helps.
zeke79 is offline   Reply With Quote
not sure what tire to use on my 06 STi gilly20 Tire & Wheel 10 08-20-2009 02:55 PM
what paint to use on my console/radio bezel hookedontronics Interior & Exterior Modification 5 07-26-2009 03:09 PM
Whats the best paint to use on my washer bottle??? madmax02 Interior & Exterior Modification 10 03-16-2009 05:59 PM
What color paint to use on gauge pod Starkiller Interior & Exterior Modification 12 08-28-2005 11:20 AM
What gear oil to use on a 01' 2.5 RS? ommmjido Transmission (AT/MT) & Driveline 2 05-26-2003 09:04 PM
