Vancouver Impreza Club
Old 07-09-2011, 02:02 AM   #26
mikkeman77
Member#: 287893
Default hi
hello guys! How are you?
mikkeman77 is offline   Reply With Quote
Old 07-09-2011, 08:37 PM   #27
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
I don't see how removing the air pump and installing the block off plates will affect idling. I would have thought all you need to do is to disable the CEL? At least that is what I have done.
minifreak is offline   Reply With Quote
Old 07-10-2011, 12:33 AM   #28
HRCboy
Member#: 167075
08 STI & 999R
I'll have to speak with Pat about this. This is what Onur has told me. From what I read the air pump is only activated during cold starts for about 20 secs. So if it's the case I don't see why it would need a 2hr retune either. But I'm no expert.
HRCboy is offline   Reply With Quote
Old 07-15-2011, 08:18 PM   #29
HRCboy
Member#: 167075
08 STI & 999R
Cleared the 2441 now 2440 popped up. The airpump has got to go.
Old 07-15-2011, 08:54 PM   #30
cp77
Member#: 237464
2009 WRX STI
Dark Metallic Grey
Same thing happened with mine. I have deleted all the codes in my Cobb map for the time being and my car is running great.(Except for it being on a Cobb map). Maybe RR will cut us a break on a Group Pump Delete Tune session?
cp77 is offline   Reply With Quote
Old 07-16-2011, 04:22 PM   #31
HRCboy
Member#: 167075
08 STI & 999R
Was talking to alcoolaid last night at the meet about this and he found this for us. Doesn't look too bad.
http://www.iwsti.com/forums/how-inst...p-removal.html
This is for a 07 STI, apparently the 08 STI only has one valve so it's even easier. We took a look under the hood and everything is seem more accessible on the GR.
Old 07-16-2011, 06:42 PM   #32
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Actually the 08 sti does have 2 valves
alcoolaid is offline   Reply With Quote
Old 07-16-2011, 09:36 PM   #33
(98)RSti
Member#: 266726
1998 RS Coupe
black
do 2004 + 2005 sti's have this air pump???
(98)RSti is offline   Reply With Quote
Old 07-17-2011, 12:21 AM   #34
alcoolaid
Member#: 134949
'07 SWP STi
Nope.
Old 07-18-2011, 12:43 PM   #35
raska
Member#: 175595
2008 STi
I replaced my RH valve. The seal inside on the poppet valve was pretty destroyed - makes sense it was sticking. Opened up the other valve and it looked mint.
raska is offline   Reply With Quote
Old 07-18-2011, 01:55 PM   #36
HRCboy
Member#: 167075
08 STI & 999R
How much was the valve?
Old 07-18-2011, 03:03 PM   #37
onur
Member#: 99005
dyno tuning isn't required with the removal of the pump. just "tuning" time, including couple of tweaks and deleting of the codes from the ECU.
onur is offline   Reply With Quote
Old 07-18-2011, 03:05 PM   #38
alcoolaid
Member#: 134949
'07 SWP STi
RH Valve: 14864AA030
LH Valve: 14864AA020
VALVE AIR SUCTION
Quantity:
Subaru
List Price:$313.20
Your Price:$229.26 (Subaru Genuine Parts)
Old 04-02-2012, 08:22 AM   #39
Laxcrazy23
Member#: 258087
09 STi
I have an 09 STI that just had this code come up. I was told 900 for labor and 600 for parts. Im out of warranty but calling SOA but is there a bypass for the 09?
Laxcrazy23 is offline   Reply With Quote
Old 04-02-2012, 09:04 AM   #40
HRCboy
Member#: 167075
08 STI & 999R
Just remove it end of story! Seriously funny how these air pumps fail just after warranty have expired. They serve no purpose at all except for dealers charging ridiculous amount of money for a useless part.
Old 04-02-2012, 10:48 AM   #41
slowguy
Member#: 4326
It came up for me on my stock 07 Forester XT. LOL. stupid POS 2441 code!
slowguy is offline   Reply With Quote
Old 04-02-2012, 10:50 AM   #42
alcoolaid
Member#: 134949
'07 SWP STi
Remove and delete code. Replacement will eventually fail too until Subaru designs new replacement
Old 04-02-2012, 11:50 AM   #43
slowguy
Member#: 4326
I can reset ECU, but that's about it. AFAIK, only open source maps and certain Cobb race/tuning maps(?) will let me delete the code. Otherwise, I'm stuck with it..
but someone please prove me wrong!
Old 04-02-2012, 12:41 PM   #44
HRCboy
Member#: 167075
08 STI & 999R
All I know is I paid rocket 2hrs to install block off the plates and another hr for the map tuning.
Hell of a lot cheaper then fixing a reoccurring problem.
Old 04-02-2012, 02:00 PM   #45
alcoolaid
Member#: 134949
'07 SWP STi
You can disable it on the stock map too
Old 04-02-2012, 03:26 PM   #46
slowguy
Member#: 4326
DETAILS MANG
Pls and thanks
Old 04-02-2012, 08:34 PM   #47
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Originally Posted by slowguy View Post
DETAILS MANG
Pls and thanks
Download your stock map, open it in RomRaider, check disable P2441 and flash back to your ECU.
But if the valve(s) is stuck open you will need to either replace it or install block off plates.
Old 04-02-2012, 09:21 PM   #48
RE3Rotor
Member#: 162465
04 Forester XT
12 Outback 2.5i
How I love the slightly more low tech 04s :P
RE3Rotor is offline   Reply With Quote
Old 04-03-2012, 09:32 AM   #49
Laxcrazy23
Member#: 258087
09 STi
Where can i get this block off? And is there a how to?
Old 04-03-2012, 10:07 AM   #50
slowguy
Member#: 4326
http://www.kstech.biz/servlet/the-10...e-block/Detail
and yesh, I am jealous of all non airpump subbies
0136 CEL w/ Pony Express CEL "fix" lstepnio Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-17-2003 04:26 PM
Anyone with Borla header and CEL, did the ECU recall fix the CEL? Suba_Roo Normally Aspirated Powertrain 14 01-25-2003 12:53 AM
gutted uppipe, cel or no cel? recursian Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-17-2002 03:57 PM
Wierd Cel after ECU Reset, installed TurboXS TMI, No Cel in Log DiMensionX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-13-2002 08:19 PM
CEL or no CEL? chuglobal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-25-2002 03:23 PM
