Old 02-08-2013, 05:13 PM   #401
Aprice24
Member#: 231892
2007 Impreza WRX
I would love to take this task on, but and pretty intimidated. How long did it take you guys to get this done? 07 WRX.
Aprice24 is offline   Reply With Quote
Old 02-08-2013, 06:22 PM   #402
scx89
Member#: 269388
2011 Impreza WRX
obp
Its easy. Only thing ive ever done was hella horns. Prob 4 hrs
scx89 is offline   Reply With Quote
Old 02-10-2013, 06:41 PM   #403
5.56x45
Member#: 305538
So I'm having trouble installing my Defi gauge on my '12. Everything works fine except for the dimmer mode. If I turned it on high everything works fine but if I lower the dash's illumination the Defi gauge starts flashing. I've tried wired it different ways but they either turned out with the same result or the gauge won't dim at all .
5.56x45 is offline   Reply With Quote
Old 02-10-2013, 07:18 PM   #404
SpongeBobSquarePants
Member#: 296048
2011 STI
Blurple
Sounds like you might have the illumination wire hooked up incorrectly. Where did you hook up the orange illumination wire?
SpongeBobSquarePants is offline   Reply With Quote
Old 02-15-2013, 07:18 AM   #405
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
I'm also having a weird problem.
Red - fuse 3 - door locks.
Orange - fuse 26 - IG1
White - fuse 16 - Illumination
Gauge works perfectly. Sweeps on startup (double sweep). And returns to the "zero position" of 30inHg on shutdown.
However, my door locks don't work. Doors won't lock with the key fob or button. As far as I can tell, the gauge uses the constant 12v (door lock) to return the gauge to zero on shutdown. And since that's happening, I'm going to assume that there's still power there.
Thoughts?
gsrcrxsi is offline   Reply With Quote
Old 02-15-2013, 08:08 AM   #406
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Most fuse taps will have two fuses. One for the original circuit and one for the one you're adding. I would check both fuses. It's possible one is blown. That would cause the exact situation you're describing.
xluben is offline   Reply With Quote
Old 02-15-2013, 08:12 AM   #407
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
Thoughts?
Check your fuse tap and primary fuse in it otherwise pull the tap and put the original fuse back in the slot to verify whether or not the locks work. If they work then I'd say its a bad fuse tap.
nmlittlebigman is offline   Reply With Quote
Old 02-15-2013, 08:13 AM   #408
Member#: 296048
2011 STI
Blurple
^^ assuming he used a fuse tap.
You did use an add a circuit fuse tap right?
Old 02-15-2013, 09:36 AM   #409
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
no i just jammed a wire lead into the fuse box and put the fuse in on top of it. thats what youre supposed to do right?
yes, i used fuse taps that i picked up from advance auto. These taps DO have a spot for 2 fuses, however, i just re-used the stock fuse from its respective location and put it in the top location on the tap. the other circuits are working fine (IG and illumination) with one fuse, not sure why it would need to be different for the door lock.
also, the windows do not work either. which is strange because i thought that was a separate circuit than the door locks.
ill check the fuses and take some pics at lunch.
Old 02-15-2013, 10:52 AM   #410
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
You need to put fuses in both slots. Here's a diagram explaining how the power is sent through it:
Mr Wrex is offline   Reply With Quote
Old 02-15-2013, 11:22 AM   #411
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
ah! i see. curious though. how are the stock illumination and IG circuits still working then? lol. because they all have just 1 fuse.
Old 02-15-2013, 12:24 PM   #412
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Is your fuse in the red path of picture above? Plug in 2 fuses to each add-a-circuit and you should see everything working now.
Old 02-15-2013, 12:44 PM   #413
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
in all three taps, the fuses are in the "yellow" top path.
Old 02-15-2013, 01:02 PM   #414
Member#: 296048
2011 STI
Blurple
Well then you have removed the fuses for those respective factory accessory circuit. Install 3 fuses and call me in the morning
Old 02-15-2013, 01:10 PM   #415
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
I understand that. What I'm asking is HOW the illumination is still working on the dash like this? Lol. It's just strange.
Old 02-15-2013, 01:33 PM   #416
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Yup. Missing those fuses was the problem. Everything works now
Old 02-15-2013, 02:57 PM   #417
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Glad you got that all figured out
Old 02-15-2013, 05:52 PM   #418
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Yeah I'm glad it was something simple.
Old 02-16-2013, 12:33 AM   #419
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
I think I'm finally going to pick one of these up because I'm getting an AEM wideband to try to diagnose my 2zz mr2 which I'll throw in the WRX when I'm done
Celery GT-5 is online now   Reply With Quote
Old 02-16-2013, 07:28 PM   #420
5.56x45
Member#: 305538
Well I finally got my dimmer to work but the gauge only have full light or dim. I can't adjust the brightness on the gauge. Does the Defi gauge have adjustable dimmer? Thanks a bunch.
Old 02-16-2013, 07:42 PM   #421
punkNdrublic04
Member#: 273621
2013 WRX Limited
SWP Hatch
No it doesn't dim with the dimmer switch. It only does full bright with lights off or dim when the headlights are on
punkNdrublic04 is offline   Reply With Quote
Old 02-16-2013, 07:48 PM   #422
5.56x45
Member#: 305538
Yup that's what going on right now. So I guess I wired it right. BTW, do you why it won't dim with the dimmer switch?
Old 02-16-2013, 07:51 PM   #423
punkNdrublic04
Member#: 273621
2013 WRX Limited
SWP Hatch
They aren't meant to. I know a few other brands like maddad and prosport have dimming systems built into the gauges but the Defi racer series doesn't.
Old 02-16-2013, 07:58 PM   #424
5.56x45
Member#: 305538
Gotcha. Thanks man!
Old 02-16-2013, 08:04 PM   #425
punkNdrublic04
Member#: 273621
2013 WRX Limited
SWP Hatch
Gotcha. Thanks man!
Np dude.
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 06:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 07:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 04:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 03:15 AM
