Old 02-16-2013, 08:20 PM   #426
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Originally Posted by 5.56x45 View Post
Yup that's what going on right now. So I guess I wired it right. BTW, do you why it won't dim with the dimmer switch?
if you click your interior switch down ONE from full brightness, it's an almost 100% match in brightness.
that's how i've been rolling with mine.
only the SPT mechanical boost gauge will dim with the dimmer switch. i had one before i went to DeFi.
-hope that helps.
ChesterWRX is offline   Reply With Quote
Old 02-16-2013, 11:49 PM   #427
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
-hope that helps.
one down only? I'll have to check but I thought I had a better match a few more clicks down.
SenorDucK is offline   Reply With Quote
Old 02-17-2013, 06:05 AM   #428
SpongeBobSquarePants
Member#: 296048
2011 STI
Blurple
No it does not
SpongeBobSquarePants is offline   Reply With Quote
Old 02-17-2013, 10:30 AM   #429
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Originally Posted by SpongeBobSquarePants View Post
No it does not
i'll try to get pics tonight. of course, this is subjective.
try it for yourselves. head lights or parking lights ON, dim switch to one or two below full brightness.
Old 02-18-2013, 08:05 AM   #430
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
One down from full brightness will make the OEM gauges match the Defi's in both the headlights on and headlights off condition.
xluben is offline   Reply With Quote
Old 02-19-2013, 08:54 AM   #431
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
This morning I noticed my red wire had popped out from the add-a-circuit I had installed. Despite that, my gauges were still working properly. What exactly does that wire power... because it seems like it wasn't needed at all. The back LED worked, gauges read all parameters correctly, and they dim correctly when the headlights are on/off
Mr Wrex is offline   Reply With Quote
Old 02-19-2013, 08:06 PM   #432
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
Iirc. The red wire is the constant 12v needed to return the gauge to the "zero" position when the car is off.
gsrcrxsi is offline   Reply With Quote
Old 02-20-2013, 11:35 AM   #433
MancinosUn4gvn
Member#: 345410
2008 Impreza WRX
Installed this today, I usually keep my headlights on, and my brightness on the gauges up, I've noticed since the headlights are on the gauge dims, is there anyway to hook up so the gauge doesn't dim, and is at full brightness at all times?
MancinosUn4gvn is offline   Reply With Quote
Old 02-20-2013, 11:48 AM   #434
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Refer to this post. I asked the same thing.
http://forums.nasioc.com/forums/show...&postcount=398
Old 02-20-2013, 11:48 AM   #435
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
I assume if you hooked the illumination wire to a switched 12v source, that the gauge would stay illuminated at full brightness.
BUT. CHECK FIRST!!! Don't just take my word for it. I am not positive. I do not know for sure if the gauge needs a 12v for illumination. Again. DO YOUR RESEARCH BEFORE ATTEMPTING THIS!!! Check things out with a multimeter if you have to.
Old 02-20-2013, 11:51 AM   #436
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Mr. Wrex,
Can you confirm that the gauge does not return to the zero position without the red wire attached? With my boost gauge, for example, with the red wire attached, the gauge returns to the "zero" position of 30inHg. With the red wire disconnected, the gauge sticks at 20psi and does not perform a proper sweep startup sequence on the next startup.
Old 02-20-2013, 11:54 AM   #437
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
I needed an excuse to go take my smoke break at work, so thank you for that I'll go check for you now mang.
EDIT:
The red wire is needed to put the needle to zero, aka -30inHg
Old 02-20-2013, 12:07 PM   #438
MancinosUn4gvn
Member#: 345410
2008 Impreza WRX
Yeah I contacted one of the techs at RSD and they said the same thing, just make sure it isn't constant because then it'll be on all the time. I'll mess with it on lunch and post a picture if I can figure it out.
Thanks!
Old 02-20-2013, 12:59 PM   #439
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Originally Posted by Mr Wrex View Post
You need to put fuses in both slots. Here's a diagram explaining how the power is sent through it:
FALSE. If with just a fuse in the accessory slot, you plug it in and see if you get power. If you don't, flip it around.
Old 02-20-2013, 01:40 PM   #440
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
You still need a fuse. Read through my posts about that.
I had flipped the fuse tap upside down in a few of these because certain orientations did not give power at all.
Added the fuses fixed the issues I had of the factory accessory no longer working. Fuses in both are needed.
Old 02-20-2013, 01:45 PM   #441
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Oh, correct. The factory accessory has its own circuit, so yes, it needs its own fuse still. But saying the add-a-circuit needs 2 fuses is incorrect.
The purpose of the add-a-circuit is to create 2 fused circuits. Else you could just use a fuse tap.
Old 02-20-2013, 01:55 PM   #442
blackstidriver123
Member#: 183188
2007 Sti
ASPEN
Man, that Defi gauge sensor looks beefy, but ya it looks really nice
blackstidriver123 is offline   Reply With Quote
Old 02-20-2013, 02:25 PM   #443
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Not really sure what you mean. I tried both orientations and swapping the fuse between both slots and it wouldn't work. The only way I got the car accesories to work at the same time as the gauge was with 2 fuses. Now lets assume that some magical unicorns were just trying to f*** with me... what slot would you put the fuse into (just 1 fuse) so that both the car accesories AND the gauges functioned properly?
Old 02-20-2013, 04:04 PM   #444
MancinosUn4gvn
Member#: 345410
2008 Impreza WRX
So I tried using the fuse tap on the radio and cigarette lighter and it's still dimmed, not sure what else I should try. Any other ideas?
Old 02-20-2013, 04:20 PM   #445
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Use a multimeter to test out the different fuse slots before you blow your gauge.
Old 02-20-2013, 04:29 PM   #446
MancinosUn4gvn
Member#: 345410
2008 Impreza WRX
Okay, the multimeter should read 12 when the car is on and nothing when off right?
Old 02-21-2013, 08:43 PM   #447
jaxx4k
Member#: 232010
Love out the OP wiring is so clean... OCD does pay off.
jaxx4k is offline   Reply With Quote
Old 02-21-2013, 09:15 PM   #448
Bizborky
Member#: 337362
2013 WRX
Followed your DIY To the T. I used a different mounting solution, but it worked great!
Bizborky is offline   Reply With Quote
Old 02-22-2013, 10:40 AM   #449
Stanley072.5i
Member#: 204266
2011 WRX
I'm sorta confused? I tried to wire up my prosport guages last night and hit the same fuses you said you hit and when I connected my Batt they all turned on before the key was in the ignition...how is it that your guages don't turn on with the key out of the ignition if you have them hooked up to a 12v constant??
Stanley072.5i is offline   Reply With Quote
Old 02-22-2013, 10:44 AM   #450
Stanley072.5i
Member#: 204266
2011 WRX
Sorry found the answer!! I'm a tard!
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 06:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 07:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 04:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 03:15 AM
