Old 09-11-2013, 10:18 PM   #576
Bill_S
Member#: 199214
Excellent post.
I am going to install a defi turbo boost gauge in my spec b. Did the gauges work well with lighting during day and night. Does it dim with the dimmer switch?
Assume Red wire for constant to the door lock, orange to the IG2 and White to the illumination/dimmer.
Thx.
Bill_S is offline   Reply With Quote
Old 09-12-2013, 06:30 AM   #577
Siphodyas
Member#: 368131
2004 STI
Looks great! I might have to pick one up myself.
Siphodyas is offline   Reply With Quote
Old 09-12-2013, 07:27 AM   #578
ATranz
Member#: 342944
2013 wrx sti
67 degrees where your at? Looks nice.
ATranz is offline   Reply With Quote
Old 09-14-2013, 02:43 PM   #579
SErwin88
Member#: 344504
2013 Impreza WRX
Do the Defis dim with the lights? Or are they full blast all the time?
Thanks
SErwin88 is offline   Reply With Quote
Old 09-14-2013, 05:28 PM   #580
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Thanks
they do NOT dim with the dash / interior lights. they are slightly dimmer.
you can get them to match almost perfectly by dimming your interior one notch or two (for some people 2 or 3).
i'll try to dig up a pic or just look back further in this thread.
ChesterWRX is offline   Reply With Quote
Old 09-14-2013, 05:43 PM   #581
Nexson
Member#: 231742
looks great!!!
Nexson is offline   Reply With Quote
Old 09-14-2013, 08:08 PM   #582
SErwin88
Member#: 344504
2013 Impreza WRX
Thanks! Would love to see what they look like. Is it possible to get them to dim?
Old 09-14-2013, 08:26 PM   #583
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
I did mine last year (check earlier posts on this thread) and i think someone posted about adding a resistor???? i'll let someone more saavy answer that.
again, all you have to do is turn down your OEM dimmer down to your flavor / taste profile.
ROFL. not sure why, they look good almost match the OEM brightness perfect for me.
i had the SPT mechanical boost gauge originally and that one DOES dim w/ the interior, but you have to wire it to the clock and head unit. it was a PITA. plus it was annoying, as most mechanical gauges are because they bounce...
Old 09-14-2013, 08:27 PM   #584
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
ETA: i'm out of bandwith on photo bucket so i can't even repost pics. time for a troll account.
Old 09-25-2013, 08:39 PM   #585
Shadow Rex
Member#: 340458
2013 WRX
@Bill_S:
Yes, fuse taps on my '13 wrx go to:
- Red=DoorLocks
- Orange=IG2
- White=Illumination
Shadow Rex is offline   Reply With Quote
Old 09-25-2013, 08:44 PM   #586
Shadow Rex
Member#: 340458
2013 WRX
Thanks ATranz, I'm located in North Cali.
Old 09-25-2013, 08:48 PM   #587
Shadow Rex
Member#: 340458
2013 WRX
Yep, they dim initially with switching on the headlights. On MY13 they match perfect dimming the dash 1 click down. Personally, I like to keep the dash at full and let the gauge be slightly dimmer, as I mounted the gauge on top of my cluster hood - never distracts me when I'm driving and still looks classy. Although after initial install I was staring at it while at WOT
My post @ bottom of pg 23 has 3 final product pics. Caption on the top one is w/ headlights off, second one is with headlights on. In fact the top one appears more yellow, but iPhone cameras don't capture bright light well, it's actually just brighter than the second one. Defi does not allow for more than 2 variables: Bright and dimmed.
Old 09-26-2013, 09:52 AM   #588
revolvedspecv05
Member#: 141837
04 impreza
aspen white
Good job !
revolvedspecv05 is offline   Reply With Quote
Old 09-26-2013, 10:25 PM   #589
mikeyj
Member#: 364766
2013 WRX
Pearl White
Why did you use 3 amp fuses in the fuse taps. Power in the glass fuse is only 0.3 amp. Also what amperage fuse taps did you use? Going to do the install and my roommate who wires cop cars says a 3 amp is too big. I don't know what this dude is talking about.
mikeyj is offline   Reply With Quote
Old 09-27-2013, 01:36 AM   #590
JRCrutc
Member#: 309978
2012 WRX hatch
Ice Silver Metallic
3 amp fuses are fine. I would think that you should be fine to use a 5, 10 or 15 amp fuse as well. The point of the fuse is to protect both the car wiring and the fused product (the gauge in this case) from a short circuit. It really comes down to the sensitivity of the product and the size (diameter) of the wires in question, but long story short, 3 amp is not too big.
JRCrutc is offline   Reply With Quote
Old 09-27-2013, 05:17 AM   #591
OceanLong
Member#: 369431
2010 WRX
very nice setup, exactly what i want on my car but unfortunately SMY don't make rhd versions
OceanLong is offline   Reply With Quote
Old 09-27-2013, 06:10 AM   #592
00camaro16
Member#: 334291
2013 WRX Limited
Dark Grey Metallic
How ever 15 amp is too big for the fuse tap. 10 amps is the max on those, they have a problem catching fire if used for more. There was a zo6 that used one for a fuel pump and it burned his car down, its one of the first one after I googled "30amp fuse tap" since what I was doing required me to tap into that.
00camaro16 is offline   Reply With Quote
Old 09-27-2013, 06:39 AM   #593
mikeyj
Member#: 364766
2013 WRX
Pearl White
So what is the solution? I'm having trouble finding taps larger than 10 amp
Old 09-27-2013, 12:33 PM   #594
mikeyj
Member#: 364766
2013 WRX
Pearl White
Old 09-27-2013, 12:40 PM   #595
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Youre an idiot if you use a fuse tap to power a fuel pump.
Old 09-27-2013, 01:02 PM   #596
00camaro16
Member#: 334291
2013 WRX Limited
Dark Grey Metallic
It was an example of what I found while seeing if there was an option out there for larger then 10 amps. Cause well I think your a idiot if you don't read the box and see the limit is 10 amp. And it caught on fire because the wires in those taps are too small of gauge. It was located under the dash (you know, where the fuse box is) not by the fuel cell, so that fact that it was for a fuel pump is irrelevant to the point I was making.
Old 09-27-2013, 01:07 PM   #597
00camaro16
Member#: 334291
2013 WRX Limited
Dark Grey Metallic
I couldn't find one either. Ever though I didn't want to (why I was trying to see if I could find a larger fuse tap) I wired another fuse into a blank space, I was doing something completely different, I would just hate to see someone car burn down cause I didn't want to explain what I found during my research for my project. If you find one let me know.
I guess another option is that they just make plane jumpers off of a fuse, just make sure you wire in an online fuse with it... I didn't like that option either.
Old 09-27-2013, 01:13 PM   #598
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
I wasnt calling you an idiot. I was stating a point.
The correct way to do it would be to run a fused 10 gauge line from the battery to a relay next to the fuel pump, triggered by an add-a-circuit.
Old 09-27-2013, 01:15 PM   #599
00camaro16
Member#: 334291
2013 WRX Limited
Dark Grey Metallic
OK then I got way too aggressive and defensive my apologies. As for a fuel pump I would have no idea how to run it the correct way.
Old 09-27-2013, 02:31 PM   #600
mikeyj
Member#: 364766
2013 WRX
Pearl White
The link I posted just prior to the fuel pump discussion will take you to where to get 15 amp fuse taps.
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 06:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 07:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 04:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 03:15 AM
