Old 01-21-2014, 04:23 PM   #626
WRB13WRX
Member#: 341786
2013 WRX Ltd. Hatch
i dont have a gauge in that pod, but i do have the blank, and mine works fine.
WRB13WRX is offline   Reply With Quote
Old 01-21-2014, 04:24 PM   #627
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
Telescope your wheel out a bit lol
Celery GT-5 is offline   Reply With Quote
Old 01-21-2014, 04:26 PM   #628
WRB13WRX
Member#: 341786
2013 WRX Ltd. Hatch
lol, yeah and mine is all the way in, still with no issues
Old 01-21-2014, 05:19 PM   #629
Dougbo9807
Member#: 371409
2006 WRX TR
Is it me or are the pictures broken?
Dougbo9807 is offline   Reply With Quote
Old 01-21-2014, 05:34 PM   #630
RSD Performance
Member#: 346602
2013 Subaru WRX
www.rsdperformanceinc.com
Originally Posted by vision.dynamix View Post
Anyone have issues with the headlight stalk contacting the left side gauge, completely preventing the stalk from going into the High Beams - Locked On position?
Yes. I had to the lower the steering wheel as far as I could on my '13 to engage the high beams but could no longer take the wheel rubbing against my leg so decided to switch to a dash pod.
James
RSD
RSD Performance is offline   Reply With Quote
Old 01-22-2014, 04:31 PM   #631
Scoobers
Member#: 341693
2013 Subaru
13 WRX SWP
Just finished installing mine... Few things ya might wanna know.
The T fitting that comes with the boost gauge DOES NOT FIT. If you are using zipties, that is super sketchy. There was so much play in it I don't know how anyone could use zip ties. Also, I used worm clamps instead of zip ties.
-I bought a t fitting assortment bag from advance auto parts and used a T out of there. I have an extra one because it came with 2. I plan on giving it to my buddy when he does his. The previous size in this thread is inaccurate.
-Also, why is everyone cutting their line? Go get another one from autozone/advance/etc. and use that so you can revert back to stock if needed. They are like five dollars.
-You need 20 amp fuse taps if you plan on using fuse taps. One of the taps will be 15amp + 3amp.
-You should really be using yellow teflon tape, not white for the oil pressure sensor.
-When running through the fender wall, you DO NOT need to remove the wheel... Just turn it a little to the left
-I used RED 3, ORANGE 4, WHITE 16. I grounded behind the deadped. This lit up the first time.
-If you try to rush through the install, you're gonna have a bad time
Scoobers is offline   Reply With Quote
Old 01-23-2014, 01:28 PM   #632
ckrp25
Member#: 375112
2011 WRX Sedan
Satin Pearl
Not just you, anyone still have the pictures that could repost?
ckrp25 is offline   Reply With Quote
Old 01-26-2014, 12:33 PM   #633
stierzy34
Member#: 92113
2013 Mini Cooper S
"Martha"
Bump for this. I used the guide when I installed defis on my 2011 and would love them to do the new install on my 2005
stierzy34 is offline   Reply With Quote
Old 01-28-2014, 05:22 PM   #634
Darkhorse85
Member#: 303734
2012 WRX Hatch
I, too, grabbed the Tee Fitting assortment from Advanced Auto but didnt find one in there that I liked.
Dont forget about McMaster-Carr
http://www.mcmaster.com/#standard-ba...ttings/=qgac08
Darkhorse85 is offline   Reply With Quote
Old 01-30-2014, 05:09 PM   #635
Scoobers
Member#: 341693
2013 Subaru
13 WRX SWP
I found one in there that was the perfect size... This is for the DEFI gauges though... although the tube size shouldn't matter :/
Old 02-15-2014, 10:43 AM   #636
DeadGeneration
Member#: 313753
2012 WRX
Dark Gray Metallic
Suck! Where the pictures go!
DeadGeneration is offline   Reply With Quote
Old 02-15-2014, 04:51 PM   #637
ScoobieNoob
Member#: 267079
2011 WRX HB
Is there another write up anywhere else on the net for this install? Tried searching, couldn't find much
ScoobieNoob is offline   Reply With Quote
Old 02-15-2014, 08:28 PM   #638
lukev
Member#: 271645
2008 STi
im going throught this right now, trying to get the wires through the firewall but its a PITA. ill take some vids/pics when i figure it out
lukev is offline   Reply With Quote
Old 02-15-2014, 10:16 PM   #639
DeadGeneration
Member#: 313753
2012 WRX
Dark Gray Metallic
I followed this guide today:
http://forums.nasioc.com/forums/show...&postcount=573
Thanks Shadow Rex!
Old 02-16-2014, 06:30 PM   #640
WRB13WRX
Member#: 341786
2013 WRX Ltd. Hatch
so much easier to go through the fender there is a rubber grommet there you poke a hole in and feed the wires though
Old 02-17-2014, 02:47 AM   #641
rontruong
Member#: 381956
aw all the pics are broken.
So many pics haha
rontruong is offline   Reply With Quote
Old 02-27-2014, 12:37 AM   #642
Shadow Rex
Member#: 340458
2013 WRX
Thanks Shadow Rex!
You're welcome! That's why we post how to's
Enjoi!
Shadow Rex is offline   Reply With Quote
Old 04-14-2014, 12:01 PM   #643
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
maybe this isnt the best place to ask. about the Defi oil pressure sensor
isnt the Defi thread 1/8 NPT
where stock is 1/8 BSPT
these are not the same. are you just shoving the NPT threads into the BSPT hole with some teflon and saying "meh, close enough" ??
I'm thinking about remote mounting the sensor with a short SS line with the appropriate adapters on each end.
thoughts?
gsrcrxsi is offline   Reply With Quote
Old 04-14-2014, 04:39 PM   #644
Josias
Member#: 170727
2003 Impreza Wrx
Rally Blue
Did the oil pressure sender come with the gauge?
Josias is offline   Reply With Quote
Old 04-29-2014, 01:18 AM   #645
dlj2
Member#: 374146
Default Repost Please
In the middle of the same project (SMY Cluster and Delfi Red Racer gauges. Looking for a little help with routing the wires out of the SMY Cluster as well as which fuses to use to wire gauges.
Can you re-post pictures or can someone help?
Thanks
dlj2 is offline   Reply With Quote
Old 04-29-2014, 10:20 AM   #646
mikeyj
Member#: 364766
2013 WRX
Pearl White
Did anyone experience a cel after installing boost gauge? Soon after I installed I got P0451 evap emission pressure sensor range. I saw a service manual that says check for vacuum leaks. Wondering if tapping the vacuum line on bov could have resulted in small leak and tripped cel.
mikeyj is offline   Reply With Quote
Old 05-02-2014, 12:10 AM   #647
ptak
Member#: 355012
2013 STI sedan
Hey all, so after a lot of hunting, typing, editing, etc I found most of the pictures from O.C.D.'s install. I have everything saved in PDF format. I don't post a lot on here so a quick way to post the PDF would be great (currently rules say I, "may not post attachments" =/), like I said probably because I never post and mostly just read. Sorry I couldn't find all the pictures, but I made a valiant effort at it. I'm betting I need to be more active on here to post attachments?
Edit: I took his install steps and paired up the pictures accordingly as best I could.
ptak is offline   Reply With Quote
Old 05-05-2014, 11:02 AM   #648
mugentheman215
Member#: 356317
Did you end up finding pictures of this, mainly looking at the fuse tap setup and where things are hooked up.
mugentheman215 is offline   Reply With Quote
Old 05-05-2014, 04:29 PM   #649
resu
Member#: 78288
2006 Subaru STi
CGM
thanks for hunting all of that down!
resu is offline   Reply With Quote
Old 05-05-2014, 06:13 PM   #650
Brycetron
Member#: 373392
2011 STI
Good tips. Just did this and was going to use this thread as a guide only to see the pics gone. They also make T fittings that allow you to cut off ends until you get to the size you need. Basically, an adjustable fitting. Thats what I ended up using. Bought some line as well so I didn't have to cut anything.
I just don't know what size fuse to protect the gauges. I think I threw 10a fuses in each fuse piggyback.
Brycetron is offline   Reply With Quote
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 06:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 07:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 04:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 03:15 AM
