Old 10-24-2011, 02:20 PM   #126
tbagsack
Member#: 281630
2008 STI
Originally Posted by b1aze View Post
The sensor is just removed. The light will no longer be functional but functionality is covered by your gauge. The connector can just be routed out of the way.
Ok Thank you very much.
tbagsack is offline   Reply With Quote
Old 10-28-2011, 10:04 AM   #127
masterforce
Member#: 221580
2011 WRX STI
Satin White Pearl
good DIY. i have a Defi blue racer boost gauge that i will be installing this weekend. all i need is to buy fuse adapters.
masterforce is offline   Reply With Quote
Old 10-29-2011, 01:34 PM   #128
BoboTheMonkey
Member#: 224615
2004 WRX
San Remo Red
Thanks for this write up. I am going to buy an AEM boost and uego wideband and wanted to see how to other people were wiring them. Those fuse extensions are an awesome help! I was going to hard wire it all like a dummy! This will make it sooooo much easier to wire. This way I can set it all up before hand and then I don't need to be messing around in the car for so long, just prep it all and connect it up!
BoboTheMonkey is offline   Reply With Quote
Old 11-01-2011, 01:48 PM   #129
tbagsack
Member#: 281630
2008 STI
Question to anyone. has anyone done this install and upon completeion had the tire pressure warning light come on? Also the gauges dim and my back lighting for my a/c wont light up anymore. what setup did youguys tap into on the fuse box and what size fuses did you run?
Old 11-01-2011, 02:55 PM   #130
badmeat
Member#: 213680
2004 STI
Constant 12v - #3 door locks
Switched 12v - #26 IG2
Illumination/dimmer - #16
10 amp fuses for every fuse tap on the gauge circuit.
My gauges have been in for over a week and no issues. They work great!
FYI- AEM Uego afr gauge and STRI boost gauge.
badmeat is offline   Reply With Quote
Old 11-01-2011, 05:13 PM   #131
tbagsack
Member#: 281630
2008 STI
Tried that setup and it didn't work. Anybody got any suggestions im running defi oil and boost?
Old 11-01-2011, 07:50 PM   #132
badmeat
Member#: 213680
2004 STI
Are you sure you have the correct wires on your gauges hooked to the right fuses?
Old 11-02-2011, 10:31 PM   #133
tbagsack
Member#: 281630
2008 STI
Yes im sure I'm going to check the fuse size again?
Old 11-08-2011, 02:38 PM   #134
Blinden
Member#: 122993
Ex's WRX
02, 04 Sti, 12 Hatch
O.C.D. you have inspired me!
Ordered all the parts for this, going to try to get this to a point that when I finally take delivery on my car I can install it very quickly. Also followed your audio install thread, definitely took some good info out of that.
I had a nice install of DEFI BF's in my old STi, but I just don't have the $1500 budget for gauges this time around!
Blinden is offline   Reply With Quote
Old 11-21-2011, 01:28 PM   #135
Gregor91
Member#: 259434
2012 wrx sedan
SOLD :/
So did te sending unit come with the defi gauges? I would like to run a similar setup so I don't have to run lines all the the way through the wall to the gauges
Gregor91 is offline   Reply With Quote
Old 11-21-2011, 03:39 PM   #136
O.C.D.
Member#: 19640
2003 WRX Sedan
Yes, the sending unit comes with the Racer series Oil Pressure Units.
O.C.D. is offline   Reply With Quote
Old 11-21-2011, 03:39 PM   #137
Blinden
Member#: 122993
Ex's WRX
Defi comes with all sensors and wiring required, but you will still have to run wires from the sensors to the gauges. I'm not clear on what you are asking here.
Old 11-21-2011, 06:51 PM   #138
Gregor91
Member#: 259434
2012 wrx sedan
SOLD :/
Like I have cheap gauges that have no sending unit so I have wires and hoses running up to the back of the gauge. Like instead of the vacuum hose going to the sending unit to read boost it runs to the back of the gauge. I want to do a sending unit
Old 11-21-2011, 06:53 PM   #139
Gregor91
Member#: 259434
2012 wrx sedan
SOLD :/
So does the boost gauge have a sending unit or does your hose plug into the back of the gauge like my 30 dollar glowshift gauge? Haha
Old 11-21-2011, 06:55 PM   #140
b1aze
Member#: 284003
2010 Alpine 135i
If its a mechanical boost gauge it will plug into the back of the gauge no matter the brand.
b1aze is offline   Reply With Quote
Old 11-21-2011, 07:44 PM   #141
Gregor91
Member#: 259434
2012 wrx sedan
SOLD :/
Alright gotcha thanks. Now say I buy a glowshift oil psi to match my boost gauge an it doesn't come with the sending unit like yours did how would I hook it up. I don't have Much gauge experience at all sorry for all the dumb questions.
Old 11-21-2011, 07:46 PM   #142
b1aze
Member#: 284003
2010 Alpine 135i
Contact glow shift or prosport for a sending unit. You need a sender for an electronic gauge.
Old 11-21-2011, 08:37 PM   #143
Gregor91
Member#: 259434
2012 wrx sedan
SOLD :/
alright cool thanks for the help is there any gauge brand you recommend that isn't expensive like 100 for each gauge would be my limit
Old 11-22-2011, 10:56 AM   #144
O.C.D.
Member#: 19640
2003 WRX Sedan
The Defi has a sending unit that runs a physical tube to the BPV. That sending unit then runs a small wire to the gauge. There is no routing of a tube to the back of the gauge like most brands for less money, aka GloShift.
Old 11-22-2011, 11:16 AM   #145
b1aze
Member#: 284003
2010 Alpine 135i
That's because it is an electronic gauge. Any mechanical gauge will have a tube to the back of the gauge.
Old 11-22-2011, 12:50 PM   #146
Gregor91
Member#: 259434
2012 wrx sedan
SOLD :/
See that's what I want to do so I don't have to run the tubes thought the fire wall. How watch we're your defi gauges if you don't mind me asking?
Old 11-23-2011, 09:53 AM   #147
O.C.D.
Member#: 19640
2003 WRX Sedan
Well, now your making me think. They are all over the web but I recall they were $.
I think the pressure was around $240 and the boost around $180 or so. Including the SMY cluster and the gauges it was near $700. Not cheap by any means as there are other cheaper options. I did not want cheap or mechanical gauges. Electronic for me, Defi had what I wanted in the closest color.
Glo-Crap is well, crap. Prosport I am mixed on as I have heard nothing good from anyone who has owned them. Maybe the new "WRX/STI" gauges with the white needles are built better?
Old 11-23-2011, 10:47 AM   #148
turboman38
Member#: 119306
2011 SWP WRX
I have had the same Prosport Boost gauge for 6 years. Even took it from my Legacy and installed it on my 2011 WRX. I have had no issues at all with it and it still looks great. I also have the Prosport Oil pressure gauge in my car that I installed a couple of months ago. No issues with it other than it was a little too deep to fit into the SMY gauge cluster so I modded the gauge a little.
turboman38 is offline   Reply With Quote
Old 11-23-2011, 10:59 AM   #149
trigger_fish
Member#: 220937
2006 Evo SE GG
FP Red 340/335
I just bought the SMY cluster, along with a prosport "White needle" boost and oil pressure gauge. Once they get to me, I'm going to install them following your diy. I have faith that the prosport gauges will work properly haha. But ill let you all know how it goes.
trigger_fish is offline   Reply With Quote
Old 11-23-2011, 11:19 AM   #150
turboman38
Member#: 119306
2011 SWP WRX
Here is a link to the Prosport Performance series gauges that are in my car: http://prosportgauges.com/amber_whit...ce_gauges.aspx
I have the boost and oil pressure gauges. The performance series allows you to light up the gauges in white or Amber or a combination of the two. For instance you can light them up in white during the day and amber at night if you choose to. Depends on how you wire it. Mine are amber all the time to match the dash color.
I think there gauges are priced well. I took a picture of mine installed already but have not had a chance to post it yet. I will try to post it tonight.
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 06:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 07:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 04:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 03:15 AM
