Old 11-23-2011, 12:09 PM   #151
93.iMPREZA.oNE.eIGHT
Member#: 301850
nice gauges!
93.iMPREZA.oNE.eIGHT is offline   Reply With Quote
Old 11-23-2011, 03:44 PM   #152
Gregor91
Member#: 259434
2012 wrx sedan
SOLD :/
Originally Posted by O.C.D. View Post
Well, now your making me think. They are all over the web but I recall they were $.
I think the pressure was around $240 and the boost around $180 or so. Including the SMY cluster and the gauges it was near $700. Not cheap by any means as there are other cheaper options. I did not want cheap or mechanical gauges. Electronic for me, Defi had what I wanted in the closest color.
Glo-Crap is well, crap. Prosport I am mixed on as I have heard nothing good from anyone who has owned them. Maybe the new "WRX/STI" gauges with the white needles are built better?
alright cool i guess I'm going to go with the prosport gauges and follow your diy
thanks a lot OCD. i really appreciate the help and ill post up pics when I'm done.
Gregor91 is offline   Reply With Quote
Old 11-24-2011, 05:15 PM   #153
A2WREX
Member#: 292143
2010 WRX Premium
Silver PSM
wheres you ground point for under the dash? i got the SMY cluster and same gauges but couldnt find a decent ground underneath there
A2WREX is offline   Reply With Quote
Old 11-24-2011, 05:24 PM   #154
A2WREX
Member#: 292143
2010 WRX Premium
Silver PSM
also do you have to use the 10A fuses with the taps or can u stick with the stock 15A fuses?
Old 11-24-2011, 08:44 PM   #155
turboman38
Member#: 119306
2011 SWP WRX
I took the side cover off the drivers side dash board. There was a couple of screws that were easily accessible for grounding.
turboman38 is offline   Reply With Quote
Old 11-25-2011, 01:36 PM   #156
A2WREX
Member#: 292143
2010 WRX Premium
Silver PSM
really? i tried one but got nothing to illuminate but i think im gonna run the ground up to the radio ground and use a aligator connecter to easily tap in. i was using the stock 15amp fuses and i think that might have caused them not to work also, i swapped the 10amps in there like OCD described and see how that works, now that im at work ill try and see if i have success with the 10amp fuses and the radio ground.
Old 11-25-2011, 08:58 PM   #157
arf80
Member#: 125580
2011 WRX 5dr
How does the ground wire work, you can just wire it up to any metal screw behind the dash? Also, where did you buy the fuse taps and ground eyelet, home depot? I've never seen those anywhere.
arf80 is offline   Reply With Quote
Old 11-25-2011, 09:56 PM   #158
b1aze
Member#: 284003
2010 Alpine 135i
I grounded my gauges to bolts just behind the shroud. works fine. I got my fuse taps on ebay and they are the dual-fuse type, one that fuses the original fuse location and one that fuses the part you tapped into.
b1aze is offline   Reply With Quote
Old 11-25-2011, 11:19 PM   #159
turboman38
Member#: 119306
2011 SWP WRX
I got the dual fuse holders from Advanced Auto Parts. I went straight into the fuse box with my wiring. I tapped in to an ignition port on the fuse box. I forget witch one. Take a look at this thread: http://forums.nasioc.com/forums/show...ht=smy+install
It has a ton of pictures and tells you what ports in the fuse box were used.
Old 11-26-2011, 01:13 AM   #160
arf80
Member#: 125580
2011 WRX 5dr
Uh.. that's the thread we're posting in.
Old 11-26-2011, 09:32 PM   #161
pip757
Member#: 290221
2004 STI
Black/Gold rims
That is perfect
pip757 is offline   Reply With Quote
Old 11-26-2011, 09:33 PM   #162
pip757
Member#: 290221
2004 STI
Black/Gold rims
I have same setup with prosport gauges defy looks way hotter congrats
Old 11-26-2011, 09:33 PM   #163
pip757
Member#: 290221
2004 STI
Black/Gold rims
Default Wow
Kudos
Old 11-26-2011, 09:33 PM   #164
pip757
Member#: 290221
2004 STI
Black/Gold rims
Love at first sight
Old 11-26-2011, 10:16 PM   #165
DSRX2005
Member#: 271681
2013 WRB Subaru WRX
AJW Performance
Awesome write-up!
DSRX2005 is offline   Reply With Quote
Old 11-26-2011, 10:29 PM   #166
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
great write up and pics! hope you are enjoying your gauges/pod!
IMPORTIMAGE is offline   Reply With Quote
Old 12-03-2011, 05:14 PM   #167
arf80
Member#: 125580
2011 WRX 5dr
Well, I couldn't figure out the fender liner step.. the plastic screws come out easy enough, but no idea where to route the wire from the engine bay into the wheel well. Maybe I'll try going through the firewall behind the intercooler.
Also I apparently the fuse taps I bought are too big. FML.
Old 12-03-2011, 07:30 PM   #168
xEJ20x
Member#: 49362
2013 DGM STI
Cobb Stg 2
I used the Bussmann HHH type.
xEJ20x is offline   Reply With Quote
Old 12-04-2011, 08:23 AM   #169
5wheeldrive
Member#: 296981
2011 WRX
dgm
When you look up into your fender with the plastic cover out of the way, you'll see a big bundle of wiring running along a plastic support. Just follow it into the engine bay, it should come out right by the fuse box under the hood.
5wheeldrive is offline   Reply With Quote
Old 12-16-2011, 06:58 PM   #170
arf80
Member#: 125580
2011 WRX 5dr
I ended up removing the battery, then it was easy to feed the wire through.
edit: the gauge does dim
Old 12-19-2011, 12:23 AM   #171
KevinK
Member#: 231813
Candy Red Mettalic
Just what I needed. Thanks
Constant 12v - Fuse # 3 - DOOR LOCK
Switched 12v - Fuse # 26 - IG2
Illumination/Dimmer - Fuse # 16 - ILLUMINATION
KevinK is offline   Reply With Quote
Old 12-20-2011, 11:08 AM   #172
fenderpicks
Member#: 287694
2011 WRX
Jesus christ, after reading like thousands of write ups, i finally understand how to install a boost guage -_-.
I mean like when i first saw this i was confused as [email protected], so i went google and searched different ones, and started to understand how it works, and at the end of the day, i realize is just there are different ways for you to route it, so it confused me. And this is the most OCD write up i found.
OCD matches me too hahahha =]
fenderpicks is offline   Reply With Quote
Old 12-20-2011, 11:52 AM   #173
O.C.D.
Member#: 19640
2003 WRX Sedan
Thanks, lol.
I post like I think. I think like I mod - OCD.
I figure if you are going to take the time to do something and show others you might as well show them the whole thing.
My motorcycle build thread on another forum is like 14 pages and that is mostly me posting. Takes forever to post but hey, it helps.
O.C.D. is offline   Reply With Quote
Old 12-21-2011, 04:09 PM   #174
fenderpicks
Member#: 287694
2011 WRX
Btw one more thing i didnt get because u installed 2 guages in total...?
How many busman add a fuse thingie do i need?
Old 12-21-2011, 09:59 PM   #175
This Is Not Mike
Member#: 131737
2006 STI OBP
2013 Tacoma TRD OR
I was just looking at the gauges themselves and I noticed that you have silver rings, which differs from the pictures in the box, which show a black/silver alternating pattern ring.
Do you choose which trim ring you want?
The reason I ask is that I already have BFs on my MY2006 in a clock pod, but I was planning on running a console mounted dual gauge pod for a Innovate LC-1 with DB gauge and a 52mm Red Racer gauge. If the trim ring is silver, that would be ideal.
This Is Not Mike is offline   Reply With Quote
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 06:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 07:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 04:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 03:15 AM
