Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 10-23-2012, 02:56 PM   #301
mr shickdance
Member#: 328229
thank you, book marked for future reference
mr shickdance is offline   Reply With Quote
Old 10-24-2012, 05:06 PM   #302
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
i got my Defi oil pressure gauge today.
everything looks good and i'm fairly confident in tackling this install.
my only questions is regarding the 3amp fuses.
1. The orange and red lines have inline fuzes on then. Do I use these IN ADDITION TO the 3amp mini-blade fuses at the fuse-taps? or use ONE of the two?
-much appreciated.
ChesterWRX is offline   Reply With Quote
Old 10-25-2012, 04:28 PM   #303
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
okay, so it appears you do need the 2nd fuse on the fuse taps.
i wired it just like the instructions in the OP. the interior wasn't difficult because i already had my SPT boost gauge in the SMY cowl.
from under the hood, i did just like the OP. i removed the alternator and the intercooler to run the wire from the oil pressure sending unit. *again, i'd already ran my boost vacum line through one of the plugs, so this one was actually easier because you didn't need a coat hanger.
if i could do it again, i would have just ONE of the two plugs to run both the vaccum line and wire for both gauges. i could see this being a LOT easier to just use Defi Gauges and going through the firewall vs. the fender well. YMMV.
another thing, i like the little fake limiter bezel ring that the Defi Gauge came with, i'm going to try and find one for the SPT to run it for "target" boost...
sorry for the crappy phone pics...
Left side plug: vacum line
right side plug: oil pressure sender wires / line
sending unit
gauges
Old 10-25-2012, 05:36 PM   #304
Shackletown
Member#: 314629
2012 STi sedan
Fender well was easier than firewall
Shackletown is offline   Reply With Quote
Old 10-25-2012, 05:43 PM   #305
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Old 10-29-2012, 03:51 PM   #306
turbosny24
Member#: 328866
2013 WRX
looks good
turbosny24 is offline   Reply With Quote
Old 11-07-2012, 04:24 AM   #307
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
freaking gauges gave me a run for my money. i have then half installed now.
once again, followed the instructions in the OP. not without pain. Joy and Pain, DJ Rob Base and EZ Rock.
i'll finish it later.
Old 11-07-2012, 04:25 AM   #308
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Old 11-07-2012, 04:28 AM   #309
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Old 11-07-2012, 04:45 AM   #310
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Old 11-07-2012, 01:49 PM   #311
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
How hard is it to get into the radio harness for the constant, keyed and illumination? I'm considering changing the stock head unit and when I do I can wire up nice and neat into the "middle man" harness between the stock radio harness plug and the plug for the head unit.
I may delay getting the head unit for a little bit, so in the meantime i'd probably hook into the fusebox... I'm just not a fan of it. I'd rather run into the radio area and pick up there. Is this path not ideal? Is there any reason nobody wired their gauges this way?
SenorDucK is offline   Reply With Quote
Old 11-08-2012, 12:26 AM   #312
JRCrutc
Member#: 309978
2012 WRX hatch
Ice Silver Metallic
Duck, The radio would be fine from an electrical point of view. I think most people either don't know about the radio harness or they want a nice new clean path for the power (not that the gauges draw much). New fuses are also better from a troubleshooting point of view, if something happens later (i.e. a fuse blows) and you have things on separate circuits then it is a lot easier to figure out what area needs attention.
JRCrutc is offline   Reply With Quote
Old 11-08-2012, 01:09 AM   #313
SenorDucK
Member#: 327511
13' WRX 6 Speed
new fuses? or the add a fuse/circuit that kind of piggybacks onto another fuse?
I'm not too sure how the add a fuses work, are there two slots, one for existing fuse slot and the other for the new circuit?
Old 11-08-2012, 08:46 AM   #314
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Its just easier to tap the fuse box. I have a breakout harness hooked up for my sound processor and amp so the head unit was not an option for me.
Old 11-09-2012, 01:53 AM   #315
JRCrutc
Member#: 309978
2012 WRX hatch
Ice Silver Metallic
Duck, The two slots on top of the fuse tap are two different circuits. The power going into the hot prong gets split out to form a new circuit. Here is a quick picture I threw together in MS Paint. If you have any more questions please let me know.
Old 11-12-2012, 02:11 PM   #316
SenorDucK
Member#: 327511
13' WRX 6 Speed
I installed my Defi gauge last Friday and I knew going in that everyone said it was a great match. I did plenty of research and decided on this gauge for a few reasons, the match being one of the bigger reasons. It really does fit well! If only that needle was white
I left the other side of my SMY plugged with a silver trimmed plug for the time being, I'll likely put oil pressure in it at a later date. I'm undecided but knew the boost was priority before further modification!
Old 12-01-2012, 05:29 PM   #317
scx89
Member#: 269388
2011 Impreza WRX
obp
I cant find the fuse taps! How do you get them where you can attach wires to them
scx89 is offline   Reply With Quote
Old 12-02-2012, 12:29 AM   #318
Blak Out
Member#: 272173
2007 Imprezza 2.5i
Looks good and def factory
Blak Out is offline   Reply With Quote
Old 12-02-2012, 02:30 AM   #319
SenorDucK
Member#: 327511
13' WRX 6 Speed
autozone carries them, along with plenty of other stores I'm sure.
Old 12-02-2012, 03:15 PM   #320
scx89
Member#: 269388
2011 Impreza WRX
obp
Where is xkubens thread on alternator removal?
Old 12-02-2012, 03:25 PM   #321
SpicyPeaNut
Member#: 43310
1978 Brat
Are you saying the gauges can get their power directly from the fuse panel in the dash?
SpicyPeaNut is offline   Reply With Quote
Old 12-02-2012, 05:07 PM   #322
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I don't think I have one...
xluben is offline   Reply With Quote
Old 12-02-2012, 05:24 PM   #323
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
http://lmgtfy.com/?q=2012+WRX+Alternator+removal#seen
Its pretty cut and dry. Look at the op in this thread too
Old 12-02-2012, 05:27 PM   #324
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Yes. The OP in this thread has excellent pictures. You tap the fuses to get power and illumination for the gauges.
Or you can tap the radio - the fuses are easy and safe.
Old 12-02-2012, 06:03 PM   #325
SpicyPeaNut
Member#: 43310
1978 Brat
Thank you for making the already clear info, crystal clear. I want to be sure I have no questions before I rip my brand new car apart
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 07:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 08:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 05:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 04:15 AM
