Old 05-18-2011, 06:25 AM   #26
101101
Member#: 260658
2011 STi 4-Door
What did you do with the stock oil pressure sender? Do you have to put it in a different plug or do you get no lights when you disconnect it from the harness?
101101 is offline   Reply With Quote
Old 05-18-2011, 07:51 AM   #27
foolycooly
Member#: 260545
2011 WRX Limited 4dr
What (if any) additional hardware did you require outside of what came with the cluster/gauges?
Great write-up!
foolycooly is offline   Reply With Quote
Old 05-18-2011, 09:43 AM   #28
O.C.D.
Member#: 19640
2005 RBP LGT 5T WAG
Cryotuned Stage 1
The stock oil sending plug is a signal wire only (I believe) so it just sits there now. No CELS, no lights, nothing. It basically just wont do its job but it doesn't matter cause it cant now, lol.
Other than large and small zipties, I bought the 25 or 30mm (length) 4mm (width) bolt and nuts/screws. That was to mount the sending unit to the hoseclamp.
Of course there are the fusetaps (3) and they require 3 amp fuses. There are two kinds I have seen, one without fuses for $8 and then one with multiple fuses for $11. I bought the pricey ones cause fuses are good.
I did so much research that it basically made me mad. Apparently you cannot get them to stop flickering and they will not stay on during startup unless you hardwire them and they will be on all the time.
I like the way they flicker and double sweep. Makes it look cool IMO.
O.C.D. is offline   Reply With Quote
Old 05-18-2011, 09:47 AM   #29
O.C.D.
Member#: 19640
2005 RBP LGT 5T WAG
Cryotuned Stage 1
Originally Posted by Izero View Post
I always thought you had to use Yellow Teflon tape for Oil Pressure Fittings? Anyways nice write-up def. like the look!
Uh-oh, did I do a no-no?
I thought it would be questionable as well. Dang.
Old 05-18-2011, 10:41 AM   #30
bzbuzz
Member#: 116052
2011 STI
yep the stock pressure sensor is there to detect when the oil pressure is too low. other than that it doesnt do anything.
bzbuzz is offline   Reply With Quote
Old 05-18-2011, 10:49 AM   #31
xluben
Member#: 261612
2011 WRX 5 Door
NF Performance Stage 1
They are meant to flicker. See video at the bottom:
http://www.defi-shop.com/product/rg/rg_top.html
xluben is online now   Reply With Quote
Old 05-18-2011, 10:58 AM   #32
Bruins1982
Member#: 240365
2011 WRX Premium
Sedan WRB
Looks great. Nice job.
Bruins1982 is offline   Reply With Quote
Old 05-18-2011, 11:15 AM   #33
BoostinChick
Member#: 218971
2007 WRX
Very clean install! I actually ran the tubing and wiring through the firewall behind the TMIC. I also have MY07, so there is a convenient grommet right there by the brake booster.
BoostinChick is offline   Reply With Quote
Old 05-18-2011, 12:11 PM   #34
Maudlin
Member#: 206124
2011 WRX 4-door
Satin Pearl White
Great!! In for when i do gauges! Thx
Maudlin is offline   Reply With Quote
Old 05-18-2011, 12:29 PM   #35
O.C.D.
Member#: 19640
2005 RBP LGT 5T WAG
Cryotuned Stage 1
Anyone else notice the right side (when looking at the dash) gauge is not symmetrical? I saw this during the install and it is driving me nuts. I looked all over for a reason while installing but could find nothing as to why?
Look at the left gauge and how close it is to the base and then look at the right side?!?!?!
Old 05-18-2011, 12:57 PM   #36
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
Jinkies! That would drive me bonkers. It looks exactly the same on their web gallery.
I'm wondering if there's something in the way behind that part of the hood? I'd call SMY and ask what's up. I want one of these, but damnit I want it symmetrical!
Also, someone pointed this out to me and I need to share. If you want more than just two gauges, this seems like a pretty spiffy solution for the 08+ cars:
http://www.fastwrx.com/widugapod20w.html
Just have to run some long wires, and probably a tricky spot for a mechanical gauge.
2point0 is online now   Reply With Quote
Old 05-18-2011, 01:06 PM   #37
O.C.D.
Member#: 19640
2005 RBP LGT 5T WAG
Cryotuned Stage 1
jinkies, lol. Never heard than one.
Nice option for the other pod. I have not seen that one either.
Yup, the symmetry is something that I noticed and has since bothered me. What can you do?
I'll bet SMY has a reason.
Old 05-18-2011, 01:17 PM   #38
foolycooly
Member#: 260545
it was pointed out in another thread that the assymetry is intentional, as the left gauge would block too much of the temp. gauge if it was at the same level as the right one. (or something like this). If you browse the original thread for the cluster when it was going through concept you would see the incredible thought and care that was put into designing and manufacturing this piece--I can assure you that the different level pods was not a mistake.
Old 05-18-2011, 02:55 PM   #39
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
Obviously you never watched Scooby Doo!
Thanks for the heads-up. I remember seeing that thread a while back but didn't notice this phenomenon.
Old 05-18-2011, 03:13 PM   #40
O.C.D.
Member#: 19640
2005 RBP LGT 5T WAG
Cryotuned Stage 1
I never stated it was a mistake. But I also did not say that I read the entire thread and process since the beginning. That was months ago so I apparently forgot?!
Thank you for clearing this up.
Old 05-18-2011, 05:14 PM   #41
101101
Member#: 260658
2011 STi 4-Door
I was asking because I read somewhere the stock sender basically is a switch for when the pressure is too low. Only having one wire go to it pretty much confirms this. I wasn't sure if the switch went closed or open when the pressure was low (so if it was open or closed in normal operation). Based on what you're saying I suspect it closes at low pressure, so you could probably disconnect the stock unit and not have that extra weight up there bouncing around.
Old 05-18-2011, 05:18 PM   #42
O.C.D.
Member#: 19640
2005 RBP LGT 5T WAG
Cryotuned Stage 1
The stock sensor is completely removed and all that is left is the pigtail connector. Move it an inch back and to the left and it will never bother you. Nothing really to flop around.
Old 05-18-2011, 07:26 PM   #43
NJ_wrx
Member#: 268855
2009 WRX
red
OCD, this was very nicely done. I have an A pod pillar in my 09 WRX but one thing that's driving me up a wall is only my oil pressure gauge is flickering during the closing ceremony. My other defi boost and defi oil temp gauge isnt doing it when I shut my car off. And to make matters worse, the needles stays where it's at when I shut my car off instead of going back to zero. Oil pressure gauge is the only one closing out flawlessly and they're all defis.
NJ_wrx is offline   Reply With Quote
Old 05-21-2011, 11:42 AM   #44
SamuraiLincoln
Member#: 274670
2011 WRX Premium
Satin White Pearl
Would love to order an SMY setup ... if only Defi made a gauge with a white needle to match. I have a little while to wait being that I plan to get an AP first. Hopefully in the meantime they come out with one
I think I'll try and contact Defi to see if they do have any plans for a white needle.
Awesome writeup by the way
SamuraiLincoln is offline   Reply With Quote
Old 05-21-2011, 07:49 PM   #45
Bruins1982
Member#: 240365
2011 WRX Premium
Sedan WRB
FWIW, Maddad does. They match the factory very well. Didn't stop me from using Defi though.
Old 05-24-2011, 04:06 PM   #46
wrxphantom
Member#: 128643
2012 WRX Sedan
Guys for those who think my cluster is not symmetrical I would like to chime in.
The cluster design had so much time invested to keep from blocking as much as the OEM gauges as possible.
The gauges are not at the same level. Also designed that way, cost me $1500 in design to find that out that that the temp gauge was being blocked to much for my liking by leaving the two pods at the same height. So I dropped the left one down just a tad.
Everything in this design had to be able to be drawn out of the mold without causing scratches to the texture when removed from the mold. Symmetry is as perfect as it could get.
The texture was applied to the mold by the same company Subaru uses for their textured surfaces here in the USA. For everyone who purchased the cluster thank you and I do appreciate all the nice things you have said.
If you have any other questions or problems please email me anytime wrxphantom23@gmail.com or call me 9174176454 (thats my mobile #) I always have time to answer your questions. I stick by my product 100%
wrxphantom is offline   Reply With Quote
Old 05-24-2011, 04:48 PM   #47
aleeann
Member#: 255913
2011 WRX Premium
Love mine! Wouldn't have done gauges without it.
aleeann is offline   Reply With Quote
Old 05-24-2011, 05:24 PM   #48
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
I have no doubt that a lot of time and consideration was put into that cluster. I do appreciate the explanation, though! Knowing why it's made that way makes a big difference. My earlier post was me shouting just to shout. Pay no mind, though I am a big stickler for symmetry (probably won't even notice once installed).
Big bummer on the new cars, nowhere to put anything. The GDs have that great clock pod location and switch blanks all over the damn place.
This is definitely on my list of future parts.
Old 05-31-2011, 12:05 PM   #49
Phat Korean
Member#: 226069
Man, that looks like crap. Had you just waited an hour, I could have helped you and got it done correctly. j/k. It looks sweet bro. Sorry i couldn't stay to the end, but you did finish it out nicely. I wish i could have taken a pic of you crying when you pulled off the fender liner. That was AWESOME!!!
Phat Korean is offline   Reply With Quote
Old 05-31-2011, 12:19 PM   #50
stiferko
Member#: 261366
1997 STiR
looks amazing, great write up!
stiferko is offline   Reply With Quote
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 06:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 07:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 04:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 03:15 AM
Message Board Statistics All times are GMT -4. The time now is 10:01 AM.
