Notices
Old 03-31-2013, 03:42 AM   #476
peekeesh
Member#: 316476
12 WRX
Originally Posted by TryHonesty View Post
Just installed this on my 2013 WRX. It's a snug fit for me (the cluster).
Ill try to remove mine again and check. There could be something that gets squeezed in between the dash and cluster.
peekeesh is offline   Reply With Quote
Old 03-31-2013, 08:38 AM   #477
Jay C
Member#: 318234
2012 WRX
On mine it seems like the top 2 clips aren't fully clipping in no matter how hard I push it, is yours the same?
Jay C is offline   Reply With Quote
Old 04-01-2013, 02:55 AM   #478
peekeesh
Member#: 316476
12 WRX
^^ yes, mine does that too and it isn't tight fit.
Old 04-02-2013, 10:59 PM   #479
Jswansti
Member#: 239623
2006 Impreza STi
Do the DEFI gauges come with interchangeable bezels/rings? It looks like they are all black on websites and I want silver to match the stock trim like the one in the OP's. Thanks for any info!
Jswansti is offline   Reply With Quote
Old 04-02-2013, 11:06 PM   #480
peekeesh
Member#: 316476
12 WRX
It looks like you can easily remove the black bezel/trim to expose the silver trim like the op's.
Old 04-05-2013, 08:18 AM   #481
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
^ this ^
the black caps are just "for show"
ChesterWRX is offline   Reply With Quote
Old 04-05-2013, 10:26 AM   #482
ptr149
Member#: 330952
2005 STI
OCD, thanks for this write up. It was really useful when I installed my Defi boost gauge and SMY cluster last night. Getting the fender liners off was definitely interesting lol
ptr149 is offline   Reply With Quote
Old 04-05-2013, 05:41 PM   #483
peekeesh
Member#: 316476
12 WRX
What did you guys do with the fabric that fills the gap between the steering column and cluster? Did you transfer it to the SMY cluster?
Old 04-05-2013, 05:56 PM   #484
Jay C
Member#: 318234
2012 WRX
Nah left it on the original, don't think it does much
Old 04-06-2013, 06:52 AM   #485
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
^ this ^
As for those with the gap, make sure there isn't anything concluding the SMY. Wiggle wiggle wiggle.
Otherwise, I'd be asking for a replacement / refund. That would drive me nuts know I have a gaping hole like that. But I'm OCD (ish) as well. Lololololol
Old 04-06-2013, 06:19 PM   #486
J.biz
Member#: 191825
2009 WRX Hatch
Question? If the steering wheel tilt is all the way up does it block the view of the gauges at all??
J.biz is offline   Reply With Quote
Old 04-06-2013, 06:27 PM   #487
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
Nope...at least not for me. I just checked for ya.
nmlittlebigman is offline   Reply With Quote
Old 04-06-2013, 06:28 PM   #488
nmlittlebigman
Member#: 321409
2003 Big Effing Van
Does your's wobble or is it tight fit?
thanks for your reply...
No wobbles...no worries.
Old 04-06-2013, 06:39 PM   #489
Jay C
Member#: 318234
2012 WRX
It does for me, not the right gauge but the left one, even with the wheel dropped a bit, the directional stalk still blocks the bottom quarter of my pressure gauge. I also had to telescope the wheel out a drop so it wouldn't hit the gauge when I turned on my high beams give me 15 minutes, I'll go take a picture of the different wheel positions for you.
Old 04-06-2013, 07:07 PM   #490
nmlittlebigman
Member#: 321409
2003 Big Effing Van
I have an A.E.M. wideband with digital readings in the left pod and my pressure gauge on the right. I guess that's why its not an issue for me.
Depending on what you have you could swap the gauges to see if it improves visibility.
Old 04-06-2013, 07:46 PM   #491
Jay C
Member#: 318234
2012 WRX
Yea that probably why.
J.Biz
Sorry for the ****ty cell pics, but it was faster.
I took these pics at about eye level.
Here is the wheel all the way up
And here is the wheel tilted down pretty much to the point where the top of the wheel is right above the tach, you can see that the bottom corner of the pressure gauge is blocked just a drop.
Old 04-06-2013, 08:35 PM   #492
J.biz
Member#: 191825
2009 WRX Hatch
J.Biz
Thanks for the pics!! I have my wheel just about all the way up and telescoped all the way out. Not a fan of the gauges being block or having to worry about the high beam stock hitting the gauge??
Old 04-09-2013, 10:30 PM   #493
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
finally installed my cluster...but I forgot my downpipe only had one O2 bung..so I'l have to live with a hole for a little while
it was a pain in the ass to get it to snap in but it seems to fit fairly flush
Celery GT-5 is offline   Reply With Quote
Old 04-11-2013, 04:19 AM   #494
subi400
Member#: 216984
1996 Impreza outback
Green
So, it seems there's no importance what so ever for the older cars like gc's, gf8's cars like that, but I'll post this any way. Since my car has a cable operated clutch I pulled the rubber plug where the clutch master cylinder would go and put a little hole in the plug and pulled the wire through and then pushed the plug back in. Right now you almost can't tell I have a larger wire going from the oil pressure sendor unit to inside the car.
I had bought a Defi racer series white LED oil pressure gauge for the build in my 96 obs wagon. I finally had the chance to wire this gauge up in my car. I went over the instructions in the first post and it looked pretty simple...
So, I go out and by the 3 fuse taps that I would need. Get back and I need the larger fuse taps so back to the store.... I then get the right fuse taps wired up to the wires to the harness and then proceed to put the fuses where they belong. For the black wire or ground, I found a bolt on the underside of the dash crash beam thingy and grounded it there. I ran both wires up through this crack between the dash and rubber weather stripping next to the door and you can't tell it is even there. Probably going to mount the gauge and pod just at the left edge of the dash for now. I connected the battery and turn the key on and the gauge does it's sweep once, goes off then on and sits at zero like it should, so I guess I did it right for now... Going to start the car later today sometime to see how the gauge works with the engine on.
The information strictly about the Defi racer series oil pressure gauge and what I needed was a big help. Yeah I don't have a newer wrx or sti, but the pictures really helped with the install. Can post pictures if anyone wants a few...
subi400 is offline   Reply With Quote
Old 04-11-2013, 03:23 PM   #495
Double_Rs
Member#: 345305
2007 STI
CGM
I'm not sure if this was asked already, but if I'm doing this mod on an 06' with using the fuse taps, what fuse would be the substitute for #26 IG2? I'm guessing that is an ignition wire, but on an 06 there isn't a fuse for that in the cabin. Any suggestions??? Sorry kinda noobish when it comes to electrical. I also have three fuse taps already, but if I have to tap into an actual line that works too (just need the color code of the wire I need). Thanks guys
Double_Rs is offline   Reply With Quote
Old 04-11-2013, 07:42 PM   #496
subi400
Member#: 216984
Green
Could you post a picture of your fuse box from inside the car on the drivers foot wall?
Old 04-12-2013, 01:36 AM   #497
Double_Rs
Member#: 345305
2007 STI
CGM
Not mine, but this is the same fuse diagram for 02-07 WRXs.
http://istargazer.ca/sti/fog_mod/sti-fuse-panel.jpg
As you can see, I have the door lock and illumination fuses, but not the IG2.
After some digging, I found this thread for gauge install
http://forums.nasioc.com/forums/show....php?t=1036365
But that is mounting it in the clock position. I'm just not sure where and if I can tap a wire (i.e. if the wire has an inline fuse, don't know if I can tap into it) under the dash that has the same ignition wire that he used.
Old 04-21-2013, 04:05 AM   #498
Bradrcr
Member#: 276382
2005 SaaBeeru
Been following this thread for a while for my wife's 2011. She hasn't pulled the trigger on gauges yet, so here's my version for the GD hatch, installed Maddad Ultra basic gauges:
Backlighting is a little bright, need to look into if a potentiometer works on these:
And here's the wiring for anyone wondering how to set them up:
Bradrcr is offline   Reply With Quote
Old 04-21-2013, 10:45 AM   #499
themaus
Member#: 321211
Does anyone remember what size T connector they used when they installed the gauge? I replaced mine when I originally installed it because the one that came with the Defi was too small for the line that goes to the top of the BPV
themaus is offline   Reply With Quote
Old 04-21-2013, 11:19 AM   #500
punkNdrublic04
Member#: 273621
2013 WRX Limited
SWP Hatch
+1 ^^^^
I didn't know the one that came with the Defi gauges is too small. Good thing I saw this because I'm installing mine tomorrow.
punkNdrublic04 is offline   Reply With Quote
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 06:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 07:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 04:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 03:15 AM
