Old 06-03-2014, 01:24 AM   #676
tantric rex
Member#: 163064
14 wrx 5dr
dgm
@brycetron, did you see @gsrcrxsi post above? I'm thinking to try the rotated orientation after becoming familiar with readings using the standard orientation. Will update when I have more info
tantric rex is offline   Reply With Quote
Old 06-25-2014, 10:34 AM   #677
Galager
Member#: 95198
Installed my white racer gauge in my FXT last night. It dims when I turn on the headlights. But I have no control over the brightness. Is there any way to wire it so the gauge dims with the rest of the interior when I use the dial? I currently have it wired:
Orange(12v switched) = #3 3 IG2
Red (12v constant) = #3 Door Lock
White (illumination) = #16 ILM
Galager is offline   Reply With Quote
Old 06-25-2014, 11:24 AM   #678
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
i don't think there's a good clean way to make them dim with the dimmer dial.
gsrcrxsi is offline   Reply With Quote
Old 06-25-2014, 11:50 AM   #679
Galager
Member#: 95198
^^That sucks. Is it because it's LED?
Old 07-06-2014, 10:16 AM   #680
blind26
Member#: 60855
93 RX-7 R1
05 Colorado Xtreme
I've seen this done two ways:
Defi Red > Fuse #3 (Door Locks)
Defi Orange > Fuse #4 (IGN2)
Defi White > Fuse #16 (Illum)
or
Defi Orange > Fuse #26 (IGN2)
Which setup are people having less problems with (double sweeps), or is it the same results?
blind26 is offline   Reply With Quote
Old 07-06-2014, 06:06 PM   #681
arani rey
Member#: 346176
or
In either setup the orange wire is being connected to IGN2, it just depends on model year differences of fuse block layout.
Using this setup I have noticed that when I put my key to start while not pushing the clutch the gauges stay on, but when I actually start the car they turn off and sweep again. When its not so hot out I will do some investigating to see which of the two fuses is loosing power during cranking.
arani rey is offline   Reply With Quote
Old 07-08-2014, 03:24 AM   #682
Nichi
Member#: 315791
2012 WRX
Originally Posted by vision.dynamix View Post
Anyone have issues with the headlight stalk contacting the left side gauge, completely preventing the stalk from going into the High Beams - Locked On position?
I'm looking into purchasing this SMY cluster cover.
I was hoping someone could definitively address the issue raised in the quoted statement above? Or add to any other fitment concerns when installing this piece?
Not really interested in the SMY if it get's in the way of operating switches ect.
Many thanks.
Nichi
Nichi is offline   Reply With Quote
Old 07-08-2014, 09:12 AM   #683
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
Many thanks.
Nichi
I have had zero issues with mine. It most likely has something to do with how far out you telescope the steering wheel.
nmlittlebigman is offline   Reply With Quote
Old 07-09-2014, 07:57 PM   #684
Galager
Member#: 95198
If you telescope the wheel all the way in, it will contact. I don't think most people drive like that though. I have mine all the way out.
Old 07-10-2014, 07:01 PM   #685
Nichi
Member#: 315791
2012 WRX
nmlittlebigman & Galager,
Thanks for your input re my question above. I have ordered the piece. Hopefully it works out good.
Regards,
Nichi
Old 07-15-2014, 08:27 PM   #686
mooses
Member#: 375640
2014 WRX
Crystal Black Silica
I bought my SMY cluster a couple days ago, so I'm almost ready for the install. I got a 3/16" x 3/16" x 3/6" tee, so hopefully it fits properly. There were so many different sizes thrown around in this thread...
Anyway, I picked up some add-a-circuits, but I'm a total wiring noob. I get how the fuses work for them, but how do they attach to my wires? Is it a simple crimp and I'm good to go?
I'm only doing the boost gauge to start. I really want to do the oil pressure at the same time, but $250 for a new gauge is a tough pill to swallow so I'm waiting for a used one to pop up. I'll definitely try using the crows wrench someone suggested in here earlier so I don't have to remove the alternator.
mooses is offline   Reply With Quote
Old 07-30-2014, 09:49 PM   #687
mooses
Member#: 375640
2014 WRX
Well I got around to installing my SMY cluster and defi boost gauge last night. It was pretty straightforward overall. Going through the fender was simple - I had already done mudflaps months ago, so I had remembered how to get the liner off.
I took it for a test drive and it works perfectly. It's awesome punching it in 2nd and watching the gauge rocket to 15
The only issue I have right now is that my defi gauge is blue. I had thought I had bought a red one, but when I went and looked back, the color wasn't mentioned . **** me sideways. Does anyone want to trade a red 52mm for my blue? Does anyone sell just the gauge itself or do I have to buy the whole thing?
Old 07-30-2014, 09:57 PM   #688
bassler
Member#: 167544
'12 DGM STi sedan
'14 Audi S6, '16 XC90
SMY cluster with an SPT boost gauge and a Prosport premium wideband that isnt hooked up yet. Will probably sell both and buy a matched set.
bassler is online now   Reply With Quote
Old 07-31-2014, 08:34 PM   #689
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
beautiful!
IMPORTIMAGE is online now   Reply With Quote
Old 10-01-2014, 09:57 PM   #690
Kite991
Member#: 372878
2014 WRX Base
Just finished installing mine today, I ran into a few issues which were stupid of me to make. The first one was that I didn't realize that the 2014 fuse box was different than the 2011 fuse box and I tapped the wrong fuses. My last mistake was that I didn't buy extra 3 amp fuses to complete the circuit on my fuse taps.
Once I fixed all those, it works like a charm and I love it. It's mounted on the steering column.
also I had to buy a brass t fitting because the t fitting that came with the gauge didn't fit the vacuum tubing that I had to splice into from the BOV. I bought a 3/8 inch brass t-fitting from home depot for about $3.
Kite991 is offline   Reply With Quote
Old 10-02-2014, 01:41 PM   #691
dscounter77
Member#: 370497
2011 Subaru STI Limi
WR Blue
im looking to get Invidia catted DP W/ 2 bungs, gaskets/adapter, SMY cluster with Defi boost gauge and Innovate WB soon. Anyone know a good shop around Los Angeles OR know anyone willing to do it?
dscounter77 is offline   Reply With Quote
Old 10-06-2014, 11:20 AM   #692
benjamminWRX
Member#: 380879
2011 WRX
Quick question: if I'm using a wire tap to power by AEM wideband, do I use a 3 amp fuse or a bigger one?
Sent from my HTC One using NASIOC mobile app
benjamminWRX is offline   Reply With Quote
Old 10-06-2014, 08:55 PM   #693
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
I used a 10 amp since that's what the manual said to tap into but I'm sure a 3 or 5 amp would be fine.
Sent from my SCH-I545 using NASIOC mobile app
jester8798 is offline   Reply With Quote
Old 10-06-2014, 10:45 PM   #694
benjamminWRX
Member#: 380879
2011 WRX
Thanks! And that's what I meant. Tap into a 10 amp and then add a 3 amp one
Old 10-06-2014, 10:56 PM   #695
Dmurphyblatt
Member#: 331550
2013 WRX 5dr
That's what I did. I did all add-a-fuses with 3amps and it works great
Dmurphyblatt is offline   Reply With Quote
Old 10-07-2014, 11:51 AM   #696
DJLiquid
Member#: 368405
2013 WRX Hatch
I ran a wire from the battery to a new fuse box. Then used a fuse tap of 3 amps to drive a relay that grabs power from the new fuse box.
Over kill for a couple of gauges but cleans things up when adding a lot of extra things. (5 gauges, 3 amps, driving camera, some auxiliary lighting...)
DJLiquid is online now   Reply With Quote
Old 12-04-2014, 06:57 PM   #697
Jmhm17
Member#: 224097
2012 WRX Hatch - DGM
Stage 1 - Tuned by Bren
Can you fix the pics? this is the best write up and with out pics its useless. please fix!!
Jmhm17 is offline   Reply With Quote
Old 12-05-2014, 01:18 AM   #698
benjamminWRX
Member#: 380879
2011 WRX
https://www.dropbox.com/s/vruj83d1hm...0by%20ptak.pdf
There ya go.. a little reading through the thread and you woulda found it
Old 12-08-2014, 03:38 PM   #699
fastman
Member#: 333680
2013 STI Hatch
ISM
Thank you
fastman is offline   Reply With Quote
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 06:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 07:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 04:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 03:15 AM
