Old 05-31-2011, 03:50 PM   #51
O.C.D.
Member#: 19640
2003 WRX Sedan
Originally Posted by Phat Korean View Post
Man, that looks like crap. Had you just waited an hour, I could have helped you and got it done correctly. j/k. It looks sweet bro. Sorry i couldn't stay to the end, but you did finish it out nicely. I wish i could have taken a pic of you crying when you pulled off the fender liner. That was AWESOME!!!
"You call him Docta Jones Lady!!!"
And yes, it was crying. Damn car is brand new!!!
O.C.D. is offline   Reply With Quote
Old 05-31-2011, 05:12 PM   #52
slimfit
Member#: 90597
2011 WRX Premium
Would it be worth it to use a sandwich block adapter as opposed to the stock location? Is this a better spot? I want a oil pressure gauge but I also want to keep my dummy light as a redundant safety.
slimfit is offline   Reply With Quote
Old 05-31-2011, 05:21 PM   #53
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Replacing the stock sensor is a much better location to read oil pressure.
xluben is offline   Reply With Quote
Old 06-02-2011, 09:49 AM   #54
O.C.D.
Member#: 19640
2003 WRX Sedan
And more efficient. Sandwich adapters can be great but are usually a pain. Running off the stock input gives you consistent and (hopefully) a leakproof connection as long as it will be there.
Plus taking apart a new car is fun - even when you cry (phat Korean).
Old 06-02-2011, 10:17 AM   #55
rattlesnake18
Member#: 276710
2010 Impreza 2.5i
Dark Grey Metallic
Great job!!! Looks clean.
rattlesnake18 is offline   Reply With Quote
Old 06-03-2011, 05:21 PM   #56
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Super useful write-up, thank you kindly and awesome idea with the longer bolt for a 'stiff' mounting spot.
Gonna do the same for my '11 STI
Tyrial is offline   Reply With Quote
Old 06-29-2011, 05:34 AM   #57
wongjonsilver
Member#: 262683
2011 WRX base
Thank you so much for the tutorial! I have the exact same setup. I didn't have the foresight for the fuse extensions. I couldn't wait, so I did the lamebrain stick-the-wire in w/ the fuse method. Functionality-wise it does work, but that shall be a temporary solution.
You can actually use the existing allen socket head cap screw and the lock washer/nuts that come in the package with the gauges to hold the boost gauge sensor attachment to the hose. That, and I was too lazy to take drive to the hardware store. .. . haha
wongjonsilver is offline   Reply With Quote
Old 06-30-2011, 08:27 AM   #58
TeeJayHoward
Member#: 286449
2011 WRX
Dark Grey Metallic
Originally Posted by O.C.D. View Post
1) Where does the wire coming out of this box go? What does it connect to?
2) Is this box included with the boost gauge? Or is it purchased seperately?
3) I assume that this box takes the boost/vacuum reading and sends it out electronically to the gauge. Is this correct?
4) The only wires coming out of the gauge appear to be a ground, constant, switched, and dimmer wire. Where is the gauge getting the actual boost signal from? Is there a plug or something on the back of the gauge like in the BF series?
5) Where did you get your Defi Red Racer gauges from? (And would you recommend getting mine from the same place?)
6) Is there any place in particular you found to be an easy, out of the way location to mount the ground wire to?
TeeJayHoward is offline   Reply With Quote
Old 06-30-2011, 08:52 AM   #59
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
  1. Connects to the gauge.
  2. Included with the gauge.
  3. Correct.
  4. There are two plugs going into the gauge. The one with the wires you mentioned, and the other plug with the signal from the pressure sensor.
  5. I got mine from RallySportDirect. Their prices aren't always the lowest, but their service is MUCH better than the "PM for a price, I'll beat anything, and then drop ship it to you" online retailers.
  6. I used a bolt near the fuse box.
Old 06-30-2011, 05:50 PM   #60
BillRo
Member#: 19081
2011 WRX 5 Door
Great writeup OCD. This is what I was planning to do anyway except have Oil Temp and your instructions are helpful. Does Defi do a those gauges with white needles to match the Subie instruments more perfectly?
BillRo
BillRo is offline   Reply With Quote
Old 07-07-2011, 10:01 AM   #61
wrxphantom
Member#: 128643
2013 STI Sedan
BillRo
Prosport will have gauges that match very soon. I think in a week or two max.
MadDad also has gauges that match but not a full line like Prosport.
Friend me on Facebook for updates.
smyclustermaker
wrxphantom is offline   Reply With Quote
Old 07-09-2011, 04:26 PM   #62
cooldude117
Member#: 267906
'11 STi Hatch
You could go super spendy and get the JDM Subaru Meter set (H5017FG011). They are basically Defi Racer gauges with white needles, no flashing on startup and no shutdown "ceremony". They aren't cheap but match perfect. Only downsides is that they are only available in boost (kPa - metric) and oil temp (degrees C - metric).
cooldude117 is offline   Reply With Quote
Old 07-09-2011, 04:49 PM   #63
TeeJayHoward
Member#: 286449
2011 WRX
Dark Grey Metallic
Holy... 57000 yen!? That's over $700USD! Does it sweep at start like the other gauges? Dim correctly? Is the boost sensor external or internal to the gauge?
Old 07-09-2011, 06:33 PM   #64
SamuraiLincoln
Member#: 274670
2011 WRX Premium
Satin White Pearl
$ 706 ... I hope that includes shipping
Weird ... it doesn't bother me so much that the needles don't match
SamuraiLincoln is offline   Reply With Quote
Old 07-25-2011, 11:30 AM   #65
b1aze
Member#: 284003
2010 Alpine 135i
For anyone looking for those fuse taps, i think i found them on Ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
I just got a set of 5 for $17 shipped, assuming they are the mini size and not the larger size.
b1aze is offline   Reply With Quote
Old 07-25-2011, 11:37 PM   #66
blackmamba11
Member#: 266458
2011 WRX sedan
black
nice setup..anyway you can throw me the part number or the exact specs of those fuse taps? Thanks
blackmamba11 is offline   Reply With Quote
Old 07-28-2011, 08:53 PM   #67
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
thanks a lot! this thread was extremely helpful
Celery GT-5 is offline   Reply With Quote
Old 07-29-2011, 01:36 PM   #68
veener79
Member#: 204304
2008 WRX 4D Stage 2
Great write up.
veener79 is offline   Reply With Quote
Old 08-01-2011, 09:44 PM   #69
O.C.D.
Member#: 19640
2003 WRX Sedan
Right on, glad someone could use it!
Anyone thought of crackin a Defi apart and throwing a white needle in there?
I am almost tempted.......
Almost
Old 08-01-2011, 10:47 PM   #70
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
Just get the jdm spt gauges or w/e
Old 08-03-2011, 11:10 AM   #71
wrxphantom
Member#: 128643
2013 STI Sedan
ProSport White Needle Gauges
Old 08-03-2011, 12:39 PM   #72
O.C.D.
Member#: 19640
2003 WRX Sedan
Could it be irony that I am wearing my SMY shirt today and then see this?! Hmmmmm.
Old 08-03-2011, 12:45 PM   #73
wrxphantom
Member#: 128643
2013 STI Sedan
hmmmm maybe
Old 08-03-2011, 02:09 PM   #74
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
is it normal for the boost to spike to around 15 and then drop down a bit stock? anyone have a stock acceleration vid with a boost gauge?
Old 08-04-2011, 12:52 PM   #75
CTSparky
Member#: 282204
2011 5 Door STi
Plasma Blue Pearl
Default I think I did it
I think I've wired the defi boost gauge so that it does not do the double sweep during the ignition cycle.
To be totally honest it was by accident when I was fiddling with the illumination wire.
for reference:
2011 STi
Orange # 4
Red #24
White #14
I hope this helps...
BTW here is the youtube:
http://youtu.be/uxUkeY_po1w
CTSparky is offline   Reply With Quote
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 07:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 08:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 05:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 04:15 AM
