Old 08-11-2011, 01:44 AM   #101
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
Originally Posted by turboman38 View Post
One thing I did notice was my gauges got brighter when you turned the lights on which is the way it's supposed to work but when you turn the lights off they did not go back to the dimmer setting.
Other way around. They should get dim when you turn the lights on, bright when you turn lights off. Clock and cluster and everything should all work that way.
2point0 is offline   Reply With Quote
Old 08-11-2011, 06:35 AM   #102
turboman38
Member#: 119306
2011 SWP WRX
I have the performance series Prosport gauges with the Amber needles. However, my gauges are 3 years old. I did notice that the prosport website has gauges that have white needles and that do the sweep just like the factory ones. They are much more expensive than the ones that I have and mine still look new and function flawlessly. I'm happy with the way they look.
I would of designed the SMY gauge pod a little differently. Maybe there is no room to do it so that's why it's designed the way it is but I would of pushed the pods back a little further, a little more to the outside of the bezel and angled them upward. Fit an finish are excellent and I am happy with how the entire setup looks.
2point0 thanks for the tip. I actually wired it up so that is bright all the time...went into the IG2 port on the fuse box.
turboman38 is offline   Reply With Quote
Old 08-11-2011, 11:44 AM   #103
wrxphantom
Member#: 128643
2013 STI Sedan
Well that explains why your gauges don't fit. They are the Performance Prosport gauges just like I guessed.
As for my cluster being redesigned. I tried what you suggested and spent a lot of money for that design work and it blocked the temp gauges to much. By moving it forward like it is it blocks the least amount as possible leaving enough room for the majority of gauges to fit. The angle can not be changed, that also was tried and did not pass the mold draw test. (would leave scratch marks on every pod when extracted from the mold. Each cluster has to be able to come straight out of the mold without resistance or they will scratch.)
As the technology gets better smaller parts are used, so gauges will only get less deep. Also the reason why there is 1/4 inch extra in the front so those with really short gauges can cut back the pods face and have their gauge sit further back.
The white needle gauges have one of the best price points out there for the high quality and technology that comes with them.
wrxphantom is offline   Reply With Quote
Old 08-11-2011, 12:06 PM   #104
turboman38
Member#: 119306
2011 SWP WRX
You certainly did the research. It's a good product and is definitely the best option out there for gauge pods. I am happy with it. I actually switched the sides the gauges are on last night. I was used to the boost gauge being on the right. The boost gauge fits fine but the oil pressure gauge was too long. I cut the gauge out where the pod angles down in the back and then took a dremel tool to the inside of the left pod. Took my time and everything fits tight now.
Thanks for your efforts with this project.
Have a great day!
Old 08-20-2011, 10:27 PM   #105
Gtikid98
Member#: 290742
2011 WRX Ltd 5dr
Satin Pearl White
Have to say thanks to O.C.D. great post and alot of helpful info, just finished it on mine...
figured i would hack the nav while i was at it.
Next week its downpipe, exhaust, intake...then off to the tuner!
Thanks again
Gtikid98 is offline   Reply With Quote
Old 08-20-2011, 10:36 PM   #106
gregroot198521
Member#: 280844
2006 STi
Thanks again
You realize an intake is kind of pointless, since the stock intake is fine till about 400hp IIRC...... Also you haven't even finished breaking in the car..... SMH.....
gregroot198521 is offline   Reply With Quote
Old 08-20-2011, 10:42 PM   #107
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
false(check out cobb's website) and so what?
Celery GT-5 is online now   Reply With Quote
Old 08-20-2011, 10:57 PM   #108
Gtikid98
Member#: 290742
2011 WRX Ltd 5dr
Satin Pearl White
intake(albeit debated) was recommended from the go to tuner in the area the New England forum guys told me to contact. As far as breaking in the car, ill have 1500 by wed, but i have a habit of adding parts right off the lot
intake under 500miles
still dont know what i was thinking with the rims
-exhaust in the first week
the truck got an exhaust on the way home from the dealership and the S got an intake and a few other parts in the first week as well lol...its a sickness
Old 08-21-2011, 08:59 AM   #109
veener79
Member#: 204304
2008 WRX 4D Stage 2
What did you hack on the nav?
veener79 is offline   Reply With Quote
Old 08-21-2011, 09:13 AM   #110
Gtikid98
Member#: 290742
2011 WRX Ltd 5dr
Satin Pearl White
The E-brake signal wire to allow phone and nav(video as well)inputs while moving. Its just a splice into the grey wire on the plug on the top driver side of the unit...just ground it out.
Old 08-21-2011, 09:06 PM   #111
midwestmonster
Member#: 54390
2016 Sti w/nav
CWP
If I don't want the defy red racer to dim, where can I hook up the white wire? Thanks.
midwestmonster is offline   Reply With Quote
Old 08-21-2011, 10:08 PM   #112
b1aze
Member#: 284003
2010 Alpine 135i
Leave it unattached.
b1aze is offline   Reply With Quote
Old 08-21-2011, 10:17 PM   #113
midwestmonster
Member#: 54390
2016 Sti w/nav
CWP
Thanks!
Old 08-23-2011, 10:27 PM   #114
gregroot198521
Member#: 280844
2006 STi
FYI: You don't have to remove the wheel for this install method. Just lift the front right corner with the jack, and wedge your fingers around the wheel well plastic and pop it under the fender a little bit. It rests on 2 overhangs in the bottom outside of the fender. You pop it down a bit and it is flexible enough to just bend out of the way for a bit. Then just run your wiring through that plug that leads to the cabin.
Old 08-24-2011, 12:54 PM   #115
CJ8501
Member#: 59664
Looks good Gtikid
CJ8501 is offline   Reply With Quote
Old 08-24-2011, 05:39 PM   #116
Gtikid98
Member#: 290742
2011 WRX Ltd 5dr
Satin Pearl White
Originally Posted by CJ8501 View Post
Looks good Gtikid
thank you kindly sir
Old 08-24-2011, 10:16 PM   #117
bzbuzz
Member#: 116052
2011 STI ( Sold )
Originally Posted by CTSparky View Post
I think I've wired the defi boost gauge so that it does not do the double sweep during the ignition cycle.
To be totally honest it was by accident when I was fiddling with the illumination wire.
for reference:
2011 STi
Orange # 4
Red #24
White #14
I hope this helps...
BTW here is the youtube:
http://youtu.be/uxUkeY_po1w
http://www.youtube.com/watch?v=uxUkeY_po1w
I don't think yours functions correctly.
Red should be constant +12V but you connect it to non constant +12v, audio.
when you turn off your car your defi will not be reset properly.
bzbuzz is offline   Reply With Quote
Old 08-25-2011, 09:47 PM   #118
mann88
Member#: 289402
2008 WRX
Thanks for the great write up. I will definitely reference this thread when it comes time to install my gauges. Very clean install!
mann88 is offline   Reply With Quote
Old 08-26-2011, 10:14 AM   #119
b1aze
Member#: 284003
2010 Alpine 135i
Door lock works perfect.
Old 08-26-2011, 12:15 PM   #120
bzbuzz
Member#: 116052
2011 STI ( Sold )
yes thats what i use as well.
Old 08-26-2011, 04:36 PM   #121
O.C.D.
Member#: 19640
2003 WRX Sedan
What is with all the ProSport gauges in this Defi thread?!?!?
Glad this thread is still lingering around for those using the cluster. I truly think the SMY Cluster was one of the best aftermarket purchases I have ever made for any car.
Between the love of my car and everything I have done; the gauges at night make me most happy. Couldn't have done this in any shape or form without it.
Props again Yanev!!!
p.s. The shirt gets a ton of questions as well, lol.
O.C.D. is offline   Reply With Quote
Old 09-12-2011, 10:20 PM   #122
BrakeSTI
Member#: 291286
2008 STI
Spark Silver
for reference:
2011 STi
Orange # 4
Red #24
White #14
Video Link: http://www.youtube.com/watch?v=uxUkeY_po1w
I'm about to use this same set up my question is what did you do with the yellow wire did you just tape it off or something. Thanks
BrakeSTI is offline   Reply With Quote
Old 09-15-2011, 11:08 PM   #123
sl8anic
Member#: 263730
Now, fuse #16 is listed as Illumination. Is it the same PWM line that's used everywhere on 08+ MY's?
I'm trying to wire in an Omori boost gauge and they have special brigtness adapter that's supposed to cut down amount of illumination (too bright). My thought was that it must be a "carry-over problem" from previous gen cars since thouse used voltage variation.
Considering that foorwell lighting kit uses straight LEDs and they dim like champs I might be on the right track.
sl8anic is offline   Reply With Quote
Old 10-24-2011, 12:09 PM   #124
tbagsack
Member#: 281630
2008 STI
Hey so I have an 08 STI and the oil galley plug under the alternator has a sensor already coming out of it. I looked it up its the OEM Pressure sensor What do i do with it when removing it. I'm trying to place like OCD a Defi Oil Pressure gauge in its place.
Thanks
tbagsack is offline   Reply With Quote
Old 10-24-2011, 01:38 PM   #125
b1aze
Member#: 284003
2010 Alpine 135i
The sensor is just removed. The light will no longer be functional but functionality is covered by your gauge. The connector can just be routed out of the way.
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 06:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 07:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 04:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 03:15 AM
