Old 05-17-2011, 06:24 AM   #1
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Default Custom Rotated Kit?
Anyone have any details on how to go about building my own rotated set
up? What measurements to take? What kind of bends I might need to
make and at what degree? Which way is most efficent? What angles can
and can't I place the turbo at? My current set up is FP green with Tomei
up pipe and Indivia downpipe. My new turbo that I will be purchasing is
the GTX3076R/0.82 V BAND. Any pointers or help would be great.
Thank you.
Garrek11 is offline   Reply With Quote
Old 05-17-2011, 11:30 AM   #2
AREA1320
Member#: 112508
if you are going to attempt to build your own rotated kit and you don't have any idea of what measurements are needed and what bends are needed then I suggest you do a whole hell of a lot of reading about fabrication in general. Or just buy a pre-made rotated kit and save yourself the headache
AREA1320 is offline   Reply With Quote
Old 05-17-2011, 01:32 PM   #3
06njsti
Member#: 150986
06 #001 LSB STi
good luck!
06njsti is offline   Reply With Quote
Old 05-17-2011, 01:59 PM   #4
SiFlyBy
Member#: 250910
I'm going to have to agree with AREA1320. If you have ask such questions, then you surely do not have the correct fabrication equipment to complete the project.
That said, I always place turbo first and build in all directions from there. Generally speaking, turbo oil drain angles should be kept to about 10-15 degrees max. Angles of pipe cuts cannot be determined until turbo placement is decided on.
SiFlyBy is offline   Reply With Quote
Old 05-17-2011, 06:01 PM   #5
TIGWERKS
Member#: 256615
Position turbo, now connect point A(exhaust manifold) to point B(turbo). Do the same with the downpipe now. Fairly cut and dry process.
Garrett website will have do's and dont's on turbo angles,etc...
TIGWERKS is offline   Reply With Quote
Old 05-17-2011, 08:16 PM   #6
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Thanks guys. Just lookin for some advice, my family member is a proffesional welder so I figured why not take the time to build a rotated set up.
Pictures of custom rotated kits? 240sxguy Custom Fabrication, Welding & Tools 331 08-11-2015 10:45 PM
WTT - custom ROTATED 35r kit for your kit!!!!! BuggeyEYED Engine/Power/Exhaust 13 09-16-2009 10:41 AM
WTT - custom ROTATED 35r kit for your kit!!!!! BuggeyEYED Tri-State Area Private Classifieds 11 09-15-2009 11:07 PM
Custom Rotated Mount Kit plus lots more stock and after market 100s of parts!!! scooby03man Engine/Power/Exhaust 16 11-03-2008 09:53 AM
FS: WRX/STi Custom rotated mount turbo kit. XS_WRX Engine/Power/Exhaust 8 08-11-2006 06:52 PM
