Old 05-17-2011, 02:44 PM   #1
subaru_sti293
Member#: 167288
07 STI 430HP 397TQ
FPred tuned Franz Diebold
Subaru Stars subaru_sti293 VIPEC v88 ECU with FP RED TURBO
It's about time to share my engine built with FP Red turbo 8cm-3" using VIPEC v88 Standalone ECU. Since I bought my car from the dealership August 2007, I started buying parts - modified to stage 2, tuned with 94 and 100 octane to get 2 maps on my AP Most of the summer weekends, I was usually on a 1/4 mile drag racing and hit 12.7sec with 110 Octane. I could get the same the same time using 94OCT when I wrapped my top mount with DEI gold heatshiled sticker plus grimmspeed A/O separator. Up to the extent that I decided to get into serious and joined the time attack circuit racing with my Honda friends. Consequently, I started to notice a problem like this - a lot of black residue in my reservoir. Yet, i just ignore those...I only changed my zero sport thermostat and reflush the blue coolant and went back to the track for how many laps. Out of curiosity though, I opened my hood and surprised to find a lot of bubbles mixed with black oil in my reservoir. Just said to myself "motherfather my headgasket is gone"! First lesson is: Do not put a 110 Oct in your car esp. on summer time. No regrets though.
Mods list:
Exterior:
JDM STI Front Lip Spoiler
Nukabe Tow Hooks
04-05 rear tail lights
Hella Supertone horns
PERRIN Performance License Plate Delete
Interior:
JDM STi Shifter Trim
JDM Auto Intercooler Switch
JDM Red Hazard Switch Subaru STi
Prosport Subaru Aluminum Dead Pedal
ATI Triple Gauge Pod for 02-07 STI
-AEM Boost gauge 35 PSI
-AEM WIDEBAND 02 Air/FUEL UEGO GAUGE KIT
-AEM Oil Pressure Gauge
Wheels/brakes/suspension:
Volkracing CE28N FLAT BLACK 17 x 8.5 , 0ffset 40
Project Kics R40 Neo chrome lug nuts
Yokohama ADVAN Neova AD08 245/40/17
Goodridge Stainless Braided Brake Lines
HP PLUS BRAKE pads front & rear
TiC Impreza Master Cylinder Brace
TiC HTS:Bearing Titanium Bearing Shims front and rear
Motul RBF-600 brake fluid
Group N top mount Front and Rear
RCE yellow spring
Race alignment (-3.0F -2.5R)
Tic Saggy Butt Shims - .25" on the rear
Cusco Front strut bar
GTSPEC Rear strut bar
Whiteline Anti_lift kit
Whiteline Adjustable Swaybar 24mm front
Whiteline Adjustable Swaybar 24mm Rear
Whiteline steering rack bushings
Kartboy endlink
Engine/head specs:
STI_07 EJ257 STOCK BLOCK:
-Manley pistons are machined of high strength 2618 material.
-Manley Turbo Tuff I-Beam Rods
-Sti 08 Nitrided Crank
-ACL rod and main bearings
-ARP "L19" Headstud Kit: Subaru WRX/STi (2.5L)(#ARP-L19-WRX)
-COSWORTH High Performance Head Gasket - 2007+ Subaru EJ257B 101mm - .78mm thick (#20010706)
-OEM STI_08 11mm oil pump kit
N.V.AUTO Oversized heads:
-Kelford 272/272 Race Camshafts : 07 Subaru STi Model Number: R-199-C
-Custom Machine porting work
-Ferrea endurance dual valve springs
-Ferrea titanium retainers
-Ferrea Seat Locator
-Ferrea Steel Valve Locks
-Ferrea +1mm oversized intake and exhaust valves
Engine/turbo/dress up:
FP RED TURBO 8cm 3" + oil inlet
Grimmspeed 44 EWG V-Band
internal wastegate bracket
Tial 44mm wastgate
FP 3" inlet FP RED TURBO
Perrin equal length headers
Kstech MegaMAF 73mm Cold Air Intake - with Perrin FMIC
VIPEC V88 ECU
Perrin FMIC KIT
-Front Bumper Support Beam
-Intercooler Piping Kit
-Silicone Couplers and Clamps
-Silicone Radiator Overflow Bottle
-Fuel Line Hose
Grimmspeed Electronic Boost Control Solenoid 3-Port
RST-0507 Spec C TGV Delete Set (top feed)
Koyo Radiator
Perrin Lightened Crank Pulley
Crucial Racing thermostat
COSWORTH Kevlar Timing Belt (#20004953)
COSWORTH Air Pump Delete (#20004539)
Invidia Catless Downpipe
HKS hi-power exhaust
Crawford Air / Oil Separator V2 - Front Mount Intercooler
Optima Red Top Battery
Beatrush Forged Pitch Stop
Samco radiator hoses
ARC titanium radiator shroud
SPT oil cap
SPT battery tie down
Greddy magnetic oil drain plug
TiC Giuyngmyo Fender Cowl Braces
Tein hood dampers
Fuel system:
-DW1300 DeatschWerks 1300cc Injector
-Perrin Fuel Rail Top Feed
-DeatschWerks Fuel Pump
-NGK one step colder spark plug
Drivetrain:
ACT Xtreme Clutch Kit
ACT Streetlite flywheel (13.9lbs)
75w 90 Extra S Subaru gear oil
Kartboy Front Shifter Stay Bushing
Kartboy Rear Shifter Stay Bushing
Kartboy exhaust hangers
GTSPEC Rear Differential Tie Brace
Beatrush subframe
TiC Transmission Crossmember Bushings
Beatrush WRX/STi Rear Diff Mount Spacers
Beatrush Propeller Shaft Mounts
Beatrush transmission mount sti
Special Thanks to the best vendors for helping me through my build:
http://www.importimageracing.com/ ( JosH )
http://www.iaperformance.com/ ( STEPHEN )
http://www.extremepsi.com/store/home.php ( Niu Do )
http://www.rallispec.com/product.htm (DAVE)
http://www.subaruofbrampton.ca/index.htm ( John Wedley )
http://altechautomotive.com/default.aspx (Pat)
Standalone ECU VIPEC v88 :
subaru_sti293 is offline   Reply With Quote
Old 05-17-2011, 02:50 PM   #2
JDM_OBP
Member#: 105409
'05 HTA68'd WRX
327/310
pics?
JDM_OBP is offline   Reply With Quote
Old 05-17-2011, 02:51 PM   #3
sc00ter
Member#: 117767
2007 WRX Limited
OBP - VF48
Where are the pics?!?!
sc00ter is offline   Reply With Quote
Old 05-17-2011, 03:05 PM   #4
Kovs04sti
Member#: 257085
07 Sti SWP
Lol too funny ^^^ but I agree
Kovs04sti is offline   Reply With Quote
Old 05-17-2011, 03:09 PM   #5
Gfunk720
Member#: 42549
E92 BMW M3 Wht/Blk
2011 VW TDI Wagon
What's wrong with putting 110oct in your car during summer?
Seems to work for everyone else
Gfunk720 is online now   Reply With Quote
Old 05-17-2011, 03:19 PM   #6
subaru_sti293
Member#: 167288
07 STI 430HP 397TQ
Taking engine out:
Old 05-17-2011, 03:35 PM   #7
oceanwalter
Member#: 282431
2003 Wrx wag
Very nice build
oceanwalter is offline   Reply With Quote
Old 05-17-2011, 03:42 PM   #8
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
WE MAKE'EM FASTER!
www.ImportImageRacing.com
great project there, let us know the results of the power on this beast
IMPORTIMAGE is online now   Reply With Quote
Old 05-17-2011, 03:42 PM   #9
subaru_sti293
Member#: 167288
07 STI 430HP 397TQ
Originally Posted by oceanwalter View Post
Very nice build
Thanks man.
Ferrea 1mm oversized intake and exhaust valves:
Old 05-17-2011, 03:50 PM   #10
subaru_sti293
Member#: 167288
07 STI 430HP 397TQ
Thanks josh. I'm still waiting for N.V.AUTO to install my Vipec v88 , install my gauges and Bosch o44 fuel pump. Franz Diebold he will tune a base map for break in period and let see how it goes.
Old 05-17-2011, 04:42 PM   #11
subaru_sti293
Member#: 167288
07 STI 430HP 397TQ
Here's my FP RED TURBO 8cm 3"
Old 05-17-2011, 04:54 PM   #12
subaru_sti293
Member#: 167288
07 STI 430HP 397TQ
Rallispec RST-0507 Spec C TGV Delete:
Grimmspeed 44 EWG V-Band:
Old 05-17-2011, 08:23 PM   #13
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Bernard - the build looks like it is coming along nicely. I look forward to seeing it back on the road and at the circuit this summer.
Stephen
IA Performance is offline   Reply With Quote
Old 05-17-2011, 08:55 PM   #14
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Good Luck B, hope it all goes well for ya. At least your at the right place now!
waynoSTI is offline   Reply With Quote
Old 05-17-2011, 09:05 PM   #15
subaru_sti293
Member#: 167288
07 STI 430HP 397TQ
Stephen
Thanks stephen . This is a serious build up for circuit racing and hopefully they will install my vipec soon.
Old 05-17-2011, 09:09 PM   #16
subaru_sti293
Member#: 167288
07 STI 430HP 397TQ
Thanks wayne. I'm happy i saw your car in the shop too... we're in the right shop . Thanks to Nam and Dov -they're a great guy!
Old 05-17-2011, 09:41 PM   #17
subaru_sti293
Member#: 167288
07 STI 430HP 397TQ
Ready to ship to oversize the valve :
Picked up some ferrea valves
Old 05-17-2011, 10:52 PM   #18
MASTERMIND65
Member#: 124539
2005 Hybrid, PPGs
I am job
Looks like it is coming together nice.
MASTERMIND65 is offline   Reply With Quote
Old 05-17-2011, 11:49 PM   #19
subaru_sti293
Member#: 167288
07 STI 430HP 397TQ
Thanks man.
Old 05-17-2011, 11:58 PM   #20
subaru_sti293
Member#: 167288
07 STI 430HP 397TQ
My Perrin FMIC KIT
Old 05-18-2011, 12:00 AM   #21
YZ86
Member#: 188705
GD Widebody STI
Lexus Pearl White
Nice project, lots of good parts!
Hope everything goes well in the end.
YZ86 is offline   Reply With Quote
Old 05-18-2011, 12:41 AM   #22
russgt
Member#: 256322
Nice build.
Be careful of those "titanium" retainers though. Sometimes they are titanium alloy and can be soft allowing the springs to walk past them and drop valves.
russgt is offline   Reply With Quote
Old 05-18-2011, 09:40 AM   #23
subaru_sti293
Member#: 167288
07 STI 430HP 397TQ
Originally Posted by russgt View Post
Nice build.
Really....I never heard they have a problem.
Old 05-18-2011, 10:51 AM   #24
subaru_sti293
Member#: 167288
07 STI 430HP 397TQ
APS TURBO INLET KIT
Old 05-18-2011, 11:06 AM   #25
O.C.D.
Member#: 19640
2005 RBP LGT 5T WAG
Cryotuned Stage 1
Type of thread I love to see! Thanks for all the pics.
What are you looking at for specs out of this setup?
O.C.D. is offline   Reply With Quote
*** Phatbotti Tuned 2002 WRX: 2.5L FP Red KSTech 83mm 16 Bit ECU 450whp E85 *** PhatBotti Tuning TKR Proven Power Bragging 34 11-22-2010 12:43 PM
FP Red Turbo wanted scooby-stu Private 'Wanted' Classifieds 4 11-19-2006 04:15 PM
Anybody using FP red Turbo! 305wrxPIMP Factory 2.5L Turbo Powertrain 11 08-16-2006 10:15 AM
Fp Red Turbo SURPRISE_TR South West Impreza Club Forum -- SWIC 3 07-06-2006 06:56 PM
WTB: FP Red Turbo Imprezzive STi Private 'Wanted' Classifieds 0 06-03-2006 06:06 PM
Message Board Statistics All times are GMT -4. The time now is 11:02 AM.
