Old 05-18-2011, 02:34 PM   #1
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
Default How full to fill fuel tank for HPDEs?
Should I start full and keep it above half all day, or try to stay at half, or what?
Its easy to top off between sessions at the track i use.
Thanks
mmiller2002 is offline   Reply With Quote
Old 05-18-2011, 02:58 PM   #2
WebMasterP
Member#: 121062
2006 STi [STU Trim]
World Rally Blue
If I'm on street tires, I can run below a quarter tank in my STI (if it's raining I can run to empty). If I'm on R-comps doing an HPDE I start to get fuel cut as I approach the quarter tank marker. Doing autocross on Hoosier A6's I have to keep it right around 1/2 a tank or I get fuel cut coming out of sharp turns. That being said, you're in an older WRX, so the fuel tank and pumps may be different.
WebMasterP is offline   Reply With Quote
Old 05-18-2011, 03:05 PM   #3
Rokkit
Member#: 84181
NASA #530 GTS2
depends on the grip level mostly... tanks are pretty much all the same.
On my RS with 245 r's i get fuel starve around 1/4 but i put in a home built surge system to help
Rokkit is offline   Reply With Quote
Old 05-18-2011, 04:52 PM   #4
sureshot007
Member#: 142405
#716 G2 OBS
If you aren't racing, what's the difference? Fill it up and have fun.
sureshot007 is offline   Reply With Quote
Old 05-18-2011, 05:15 PM   #5
red5001
Member#: 33942
04.5 STI
wrb
agreed and you won't have to worry then
red5001 is offline   Reply With Quote
Old 05-18-2011, 05:57 PM   #6
delongedoug
Member#: 124113
and beyond!
Bingo. You're not gaining any discernable advantage by running as little as possible and having to fill up numerous times throughout the day.
delongedoug is offline   Reply With Quote
Old 05-18-2011, 06:53 PM   #7
law
Member#: 36842
2008 2007 Exige S
AW, Black
Fill it all the way up. I usually get fuel cut below half a tank in some spots, sometimes not until 1/4 tank but for an HPDE that doesn't take long to burn half a tank.
law is offline   Reply With Quote
Old 05-18-2011, 07:11 PM   #8
spdracerut
Member#: 269226
Exactly.
spdracerut is offline   Reply With Quote
Old 05-18-2011, 09:40 PM   #9
HoChiMinh690
Member#: 72645
04 Blue WRX
UGM STi Limited. #748
Not true, every point by you get gives you 5 exp. OP, I take a dump before every session too
HoChiMinh690 is offline   Reply With Quote
Old 05-18-2011, 09:53 PM   #10
d3v0
Member#: 225692
2015 WRX
Dont want to be in too much of a hurry to get your fuel in and get back on track...
d3v0 is offline   Reply With Quote
Old 05-18-2011, 09:54 PM   #11
d3v0
Member#: 225692
2015 WRX
Old 05-25-2011, 03:12 AM   #12
The Database
Member#: 225192
2008 BMW E92 M3
Bat Mobile Black
If you are really persitent on having as little gas as possible (gallon ='s 6 lbs), just find out how much your car runs through in a session and just give it a gallon or two more. (Mine kills a half tank on a fast track.) The penelty for most HPDE's for running out of gas on track is you being done for the day. So don't run out
The Database is offline   Reply With Quote
Old 05-31-2011, 06:07 PM   #13
newclutch
Member#: 222415
03 WRX
W R BLUE
On really hot days we prefer a full tank of fuel. you do not have to go fill it up as often. I just hate it when my beer gets warm and flat back in the paddock because I am waiting in line at the gas pumps.
newclutch is offline   Reply With Quote
Old 06-01-2011, 09:08 PM   #14
Four vs Two
Member#: 243712
My thoughts exactly. Why even risk fuel starvation if you aren't racing?
Four vs Two is offline   Reply With Quote
Anyone drives great distance to fill up tank at Shell? gopsu General Community 87 05-14-2009 01:54 PM
Best Way to Drain Fuel Tank? beaviscih Texas Impreza Club Forum -- TXIC 13 09-03-2007 06:26 PM
How much to fill up your car sc0013z Texas Impreza Club Forum -- TXIC 63 05-21-2007 12:04 AM
99RS: How much to fill up on freon? Snoopy Normally Aspirated Powertrain 7 05-31-2006 01:08 PM
$80.07 to fill the tank jasper New England Impreza Club Forum -- NESIC 13 08-27-2005 08:35 PM
