Old 05-18-2011, 03:56 PM   #1
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
Built Motor and all. WRB
Default DIY Rear subframe lockdown bolts.
Ok, so this DIY is very simple, and not expensive. It makes a huge difference in how the car handles, and i haven't noticed any more road noise than before.
Parts List:
2 - M12x1.25 Bolts 50-60mm long (must be grade 8.8 or higher! I recomend 10.9 if you can find them.)
2 - 3/4" OD x 1/2" ID Bronze Flange Bearing
And here you have what your finished product should look like:
Now for the installment:
1: Make sure the threads in the capture nut are clean, if they have any rust on them, then you need to run an m12x1.25 tap through them to clean out any debris. ***(Skipping this step can cause huge headaches!!)*** Some people have also cleaned the threads with PB blaster and a small wire brush, or a pipe cleaning brush in a drill with PB blaster. WD-40 will also work a little bit, but PB blaster is 10x better. when the threads are clean, the bolt should thread in with almost no resistance.
2: Loosen all four subframe mounting bolts in order to let the bushings align correctly.
3: Apply anti seize to threads on the new subframe lock bolts. (a little dab should do it) Install one side bushing and bolt, but do not tighten up yet.
4: Install the other side and snug up the bolt. (To get the second one to line up, you might need to shift the subframe some. If the subframe is shifter to one side or the other, an alignment should be done following this install.)
5: Tighten all four of the original subrame mounting bolts.
6: Tighten up the two subframe lock bolts.
*More detailed instructions can be found on this post*
http://forums.nasioc.com/forums/show....php?t=1752267
And a couple pictures of them installed on my car:
Everyone should be able to do this, and it takes only a few minutes.
total cost for me was $9 for the hardware.
I hope this helps some people out.
chet.wrb is offline   Reply With Quote
Old 05-18-2011, 04:15 PM   #2
Splinter888
Member#: 215962
2006 Wrx
SGM
Thats pretty cool. Any increase in NVH? Or what your experience is so far?
Splinter888 is offline   Reply With Quote
Old 05-18-2011, 04:21 PM   #3
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
The rear end is alot more connected to the car now, and like i said, i can't hear any more NVH than before. but i also have Group N motor and tranny mounts which added a little bit of NVH.
In my opinion, EVERYONE should do this little DIY.
Old 05-18-2011, 04:36 PM   #4
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Very cool. Nice work.
Everyone should do this besides 04-05 sti owners. They don't need them.
Old 05-18-2011, 04:39 PM   #5
Boxer4u
Member#: 115149
07 STI
Murdered & Loud
^^^ are these already in place on the 04/05 sti? I was gonna pick up kartboys version of these but may just go the DIY route
Boxer4u is offline   Reply With Quote
Old 05-18-2011, 04:39 PM   #6
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
yea, its nice because the hole is already there and threaded for you. it couldnt be any simpler.
Old 05-18-2011, 04:53 PM   #7
kpluiten
Member#: 120273
06 WRBWRXWGN
The 04-05 STI's have solid steel subframe mounts. All other Imprezas have rubber isolated mounts.
Old 05-18-2011, 04:57 PM   #8
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
Nice to know, kpluiten. i never knew that. i wonder if you can just take the rear subframe from an 04-05 sti and put it on any of the 02-05 WRX's..... but i guess theres no reason to because these bolts do almost the same thing.
Old 05-18-2011, 05:09 PM   #9
kpluiten
Member#: 120273
06 WRBWRXWGN
They can be swapped. I did it on my wagon.
Old 05-18-2011, 05:16 PM   #10
Boxer4u
Member#: 115149
07 STI
Murdered & Loud
07 sti has rubber mounts? I never really looked
Old 05-18-2011, 05:26 PM   #11
kpluiten
Member#: 120273
06 WRBWRXWGN
As far as I know. Take a look and let us know.
Old 05-18-2011, 05:40 PM   #12
ogboot
Member#: 170906
psm
I'm a fan, someone enlighten this noob on 02WRX fitment.
ogboot is offline   Reply With Quote
Old 05-18-2011, 05:52 PM   #13
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
Where did you get the bronze bearings?
The Satch is offline   Reply With Quote
Old 05-18-2011, 06:11 PM   #14
krauser2
Member#: 153751
2002 Mazda Miata
The Darkness
subscribed...you just saved me $25 good sir
krauser2 is offline   Reply With Quote
Old 05-18-2011, 06:44 PM   #15
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
I got the bronze bearings (or bushings if you want to call them that) at my local ACE hardware. They get them through servalite. And you can also get them through mcmaster.com
Old 05-18-2011, 07:36 PM   #16
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
pretty cool, i have kartboys from years ago, never notice the difference but then again i had the outrigger bushings
feint05 is offline   Reply With Quote
Old 05-18-2011, 07:55 PM   #17
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
Yea, one big thing I just realized that I left out is that you need to make sure the threads are clean and run a tap through there first if there is any rust or corrosion in there. The bolts thread in tight, but they should not have to be forced at all. Not doing this can cause big headaches down the road... Seriously the raddleing of a broken capture nut will give you a headache... Haha
Old 05-18-2011, 07:57 PM   #18
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
And they are grade 10.9 bolts. The equivalent of a grade 8 in standard. They should be plenty strong for this application.
Old 05-18-2011, 08:39 PM   #19
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
you dont quite understand the issue, here
lotsa d0000ds gonna snap off the captured nuts in the subframe tryin this.....lots and lots
and this is one of those things that is NOT easy to fix....but REAL-REAL easy to **** up because of rust in the threads of the captured nut....and once the captured nut snaps off...ya cant get the bolt out without dropping the subframe...even if ya cut the bolt head off....and then it will rattle
have fun
Old 05-18-2011, 09:02 PM   #20
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
Its the same deal with any other brand name rear subframe lock bolts. Unless they happen to come with a tap to clean out the threads, but I'm pretty sure they don't. I thought it was pretty simple as far as if its not going in how it should, don't force it.
So everyone doing this, if you don't know how to clean out the threads first, don't do this DIY.
Old 05-18-2011, 10:04 PM   #21
krauser2
Member#: 153751
2002 Mazda Miata
The Darkness
^ or with aftermarket either, I don't think they come with taps, just the hardware
Old 05-19-2011, 02:25 AM   #22
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
They dont, if the dooooods mess up doing this they would have just done the same but spent more cash too get there. So if you buy the bling "whiteline, kartboy etc"you just spent more too get too the same point.
Folks always gotta make things sound like rocket science. lol
Props for thinking out of the box...
rexworx is online now   Reply With Quote
Old 05-19-2011, 03:40 AM   #23
Uncle Scotty
Member#: 16200
OK buy Nates beans
the issue is that the f00-f00 low rent kiddies are gonna flock to this and then we will get all sorts of
threads and posts about this and it will not end well......there is gonna be a lot(MORE) half assed bull**** running around
just like there always is when threads like this get posted.....
Old 05-19-2011, 08:19 AM   #24
Big-E
Member#: 123843
2016 STI LTD
CWP
Besides not properly cleaning the capture-nut threads and loosening the existing four crossmember bolts to center it, what grade bolt(s) should be used? Hopefully not the "regular" bolts from the local hardware store? Perhaps either 8.8 or 10.9?
Don't get me wrong, but I'm pro-DIY if it's done properly; safety first. I can see a 'softer' bolt and the bushing resting against the crossmember, the crossmember shifting just that much and snapping the bolt.
Old 05-19-2011, 08:21 AM   #25
krauser2
Member#: 153751
2002 Mazda Miata
The Darkness
thats why you gotta take the time and tap it in...just tap-tap tap it in
Leave in Rear Subframe Lockdown Bolts forever? paulpat Brakes, Steering & Suspension 11 01-03-2011 10:42 AM
FS : Whiteline Subframe Lockdown Bolts SOLD! andrewp724 Suspension/Brakes/Handling 8 10-04-2010 09:29 PM
Help with subframe lockdown bolt install kmook Brakes, Steering & Suspension 11 10-19-2009 12:03 AM
Brand New Perrin Rear Subframe Lockdown Kit whitneyas Suspension/Brakes/Handling 2 07-28-2008 01:29 PM
