Old 05-19-2011, 08:27 AM   #26
krauser2
Member#: 153751
2002 Mazda Miata
The Darkness
install reference
http://forums.nasioc.com/forums/show....php?t=1752267
Wd 40, anti seize, tap
not rocket surgery yet, but like scotty said, I'm waiting for that infamous thread to pop up
krauser2 is offline   Reply With Quote
Old 05-19-2011, 08:59 AM   #27
Feign
Member#: 68604
06 STi
I'd recommend an alignment after this. Something will be out of whack after you do this.
Feign is offline   Reply With Quote
Old 05-19-2011, 10:02 AM   #28
ogboot
Member#: 170906
psm
Welp, it's already happened after all, from the other thread:
http://forums.nasioc.com/forums/show...2&postcount=15
be careful folks.
ogboot is offline   Reply With Quote
Old 05-19-2011, 11:06 AM   #29
krauser2
Member#: 153751
2002 Mazda Miata
The Darkness
I saw that, improper prep prior to install
Old 05-19-2011, 12:55 PM   #30
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
Did this last night, cost me 15, but thats because of the area I'm in. used 8.8 bolts, only issue I had was no matter what I did the drivers side hole would only let the bolt thread in, the bushing didnt fit, even after loosening the subframe mounts. I ended up just grinding ~2 mils off one side of the hole, still a snug fit, and it actually git rid of a lot of the noise that came from the rear of the car. Seems worth it imo, will see how it effects handling today, but I'm not expecting much because I already have a rpm front subframe.
The Satch is offline   Reply With Quote
Old 05-19-2011, 03:43 PM   #31
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
Built Motor and all. WRB
Ok, sorry guys, i fixed the original thread now.
It now specifies what grade bolts to use, and also has step by step instructions of the install ***Including cleaning the threads out first***
chet.wrb is offline   Reply With Quote
Old 05-19-2011, 04:02 PM   #32
subi400
Member#: 216984
1996 Impreza outback
Green
Subscribed!
subi400 is offline   Reply With Quote
Old 05-19-2011, 04:59 PM   #33
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
This might be one of the better DIY mods on the site - with a great way to save yourself some money.
axelthrasher is offline   Reply With Quote
Old 05-19-2011, 05:59 PM   #34
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
**Updated again with more ways to clean the threads, and some more installation tips.**
Old 05-20-2011, 01:27 AM   #35
fastwrx25
Member#: 126441
03 bugeye
wish this was out years ago, wouldve saved me money.
thanks for posting this up, great mod really firms up the rear.
someone order this from mcmaster and post up part numbers.
fastwrx25 is offline   Reply With Quote
Old 05-20-2011, 10:13 AM   #36
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
For ordering through mcmaster carr.
2x Bronze flange bearing part number: 2938T15 (0.97 each)
1x Bolt part number: 91180A726 (6.82 for 5)
Old 05-20-2011, 11:57 AM   #37
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
Originally Posted by kpluiten View Post
The 04-05 STI's have solid steel subframe mounts. All other Imprezas have rubber isolated mounts.
SWEET
you saved me some cash
indytruckboy is offline   Reply With Quote
Old 05-20-2011, 08:54 PM   #38
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
Check out my DIY fog light mod i just did. i havn't found any fog light mods this simple, and done right.
http://forums.nasioc.com/forums/show...6#post34156286
Old 05-21-2011, 10:46 AM   #39
arf80
Member#: 125580
2011 WRX 5dr
I've already got the Kartboy rear subframe bushings installed, is this mod still worth doing?
arf80 is offline   Reply With Quote
Old 05-21-2011, 08:05 PM   #40
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
it wont make as much of a difference, but it should still keep the rear sub frame a little bit tighter.
Old 06-17-2011, 10:20 PM   #41
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
Still have to bolts in my car, and still no problems(about 2 months DDed with lots of spirited driving). i love the way the rear end feels now.
I also installed these on a friend's car, and they went in great and work great on his car also.
Old 04-12-2012, 07:03 PM   #42
D3F0
Member#: 265799
1988 Subaru RX TURBO
Sorry to bump this but how did this lock down bolt mod workout I will be doing this myself soon because aftermarket is a little pricey compared to this =).
D3F0 is offline   Reply With Quote
Old 04-12-2012, 07:11 PM   #43
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
So I have about 30,000 miles on the bolts now, and they still work perfectly. I checked them the other day to make sure they are tight, and they are fine. Working on building my stroker motor now, so these will be getting plenty of stress in the future also.
Old 04-12-2012, 08:22 PM   #44
D3F0
Member#: 265799
Thanks for the update I will diffidently be doing this I am about to cut my whole trunk out lol cause all my bolts for my sub frame in general have snapped nuts in there. How did this affect handling and where did you get the brass 3/4" OD x 1/2" ID Bronze Flange Bearing.
Old 04-12-2012, 08:25 PM   #45
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
I got mine from my local ace hardware. But as I posted before, mcmaster.com has them, and most hardware stores can order them if they don't stock them.
Old 04-12-2012, 09:19 PM   #46
thejaredhuang
Member#: 86206
2006 WRX Wagon
If you live in SoCal, McFadden-Dale hardware has the best prices for fasteners that I've seen.
thejaredhuang is offline   Reply With Quote
Old 04-12-2012, 09:33 PM   #47
D3F0
Member#: 265799
Thanks guys ill check my local ace and go from there appreciate the info.
Old 04-13-2012, 07:13 AM   #48
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Fastenal is better. If you have one close by.
Bolt grade 10.9
http://www.fastenal.com/web/products...x?sku=11114723
Flange
http://www.fastenal.com/web/products...ex?sku=0435322
Rob
Part numbers are:
11114856 for bolt its the full thread won't affect performance!
0435322 for the bushing
sackytar is offline   Reply With Quote
Old 04-17-2012, 03:01 PM   #49
sackytar
Member#: 149262
PrimerGrey
FYI got these from fastenal and they were 10 bucks and change. Bonus!!
Old 04-17-2012, 03:28 PM   #50
sorrowfulkiller
Member#: 170439
I <3 Lamp
Subscribed for future use....
sorrowfulkiller is offline   Reply With Quote
Leave in Rear Subframe Lockdown Bolts forever? paulpat Brakes, Steering & Suspension 11 01-03-2011 10:42 AM
FS : Whiteline Subframe Lockdown Bolts SOLD! andrewp724 Suspension/Brakes/Handling 8 10-04-2010 09:29 PM
Help with subframe lockdown bolt install kmook Brakes, Steering & Suspension 11 10-19-2009 12:03 AM
Brand New Perrin Rear Subframe Lockdown Kit whitneyas Suspension/Brakes/Handling 2 07-28-2008 01:29 PM
