Old 05-19-2011, 01:49 PM   #1
Keats_16G_Rex
Member#: 222636
1991 Legacy SS
Default 2004 WRX hanging/high idle issue
I've searched regarding this problem of a hanging idle/high idle, but can't seem to find any more info besides the IACV. If I'm in heavy traffic letting the car idle, it will gradually start rising in RPM's all the way to 3 or 4k. Also happens while i'm doing a bunch of WOT pulls back to back.
I have already cleaned the TB, lubed the throttle cable connections, and cleaned/changed the IACV gasket. I'm pretty sure the gasket is seated correctly as there is no coolant being burned (no smoke out the exhaust).
Any suggestions??
Thanks fellas.
Keats_16G_Rex is offline   Reply With Quote
Old 05-19-2011, 02:01 PM   #2
Clur
Member#: 238257
2004 Wrx
San Remo Red
you loosened the Cruise control?? My 04 does same thing when engine bay get real hot.. turbo heats up the cruise control box and something in there expands.. i have my cable honestly all the way loose and it'll still tighten a good amount.. your symptoms sound the same.. next time idle goes up like that pull over and check cruise cable.. its the one nearest too you if your leaning in over the passenger side.. check if the slack is tight
don't know if you've tried this.. but thought i'd mention it.
Clur
Clur is offline   Reply With Quote
Old 05-19-2011, 08:29 PM   #3
Keats_16G_Rex
Member#: 222636
1991 Legacy SS
Yea I have adjusted both the throttle cable and the CC cable. I guess it does help, but always thought of it as a band-aid to the actual problem.
Old 05-20-2011, 12:37 AM   #4
blynch04wrx
Member#: 249387
There's a recall for the cc cable go to ur local dealer they can do it for free it's a clip for the throttle body I just got it don't to mine last week
blynch04wrx is offline   Reply With Quote
Old 05-23-2011, 10:12 PM   #5
exDSMer
Member#: 283669
2003 Impreza WRX
Definitely make sure that both cables have a little slack. Neither should be taut.
exDSMer is offline   Reply With Quote
Old 05-31-2011, 10:33 AM   #6
aknightly_wrx
Member#: 279779
2007 Impreza 2.5i
Urban Gray Metallic
Default High idle!
I was at the beach yesterday and was sitting in traffic and my car was idling just over 4 thousand rpm! I hope that it is just the cc cable
aknightly_wrx is offline   Reply With Quote
Old 05-31-2011, 03:52 PM   #7
tyrel.boyce
Member#: 270178
2002 Subaru WRB
380HP stock motor HTA68
I would definetly check both of those cables and you should be fine.
tyrel.boyce is offline   Reply With Quote
Old 05-31-2011, 04:02 PM   #8
berge56
Member#: 56754
2004 Hybrid 2.5XTR
RIP [email protected]
Clur
This.
berge56 is offline   Reply With Quote
Old 05-31-2011, 04:37 PM   #9
krauser2
Member#: 153751
2002 Mazda Miata
The Darkness
mine does it to about 2k when it gets very hot
did it today actually
krauser2 is offline   Reply With Quote
Old 05-31-2011, 04:46 PM   #10
ganzhimself
Member#: 252648
2010 Mini Cooper
Pepper White
My 05 has been doing it and the CC cable is adjusted all the way out... Thinking of adjusting the throttle cable some, as it's not doing it as bad as it was before, but it's still annoying to sit in traffic with the idle hitting 1500-1700 RPMs. Not to mention it makes the car a bit difficult to drive in low-speed conditions.
ganzhimself is offline   Reply With Quote
Old 05-31-2011, 05:20 PM   #11
Legacy01
Member#: 256016
2005 WRX
CGM
Mine does this too...2005 WRX...idle gets to 1800-2K. Started doing this when the weather got hot...and more often than not when my A/C is on. I checked the coolant temp with my AP V2 and the highest it read was 215 degrees F.
If I drive on the highway around 70 mph for a few miles when I get to a stop the idle goes back down to normal, but in traffic it will eventually start to raise again. I just don't want to overheat. Possible thermostat stuck closed?
How would the cruise control affect the idle if I'm not using the cruise at all, even on the highway?
I have a 10 degree colder thermostat that I have been waiting to install...seems like a good time to do that just to be safe...the last thing I need is to overheat and ruin things more than they are now.
Suggestions?
Legacy01 is offline   Reply With Quote
Old 06-02-2011, 11:57 AM   #12
Legacy01
Member#: 256016
2005 WRX
CGM
Just read the TSB on the CC issue...seems that a little liquid wrench, wire brush and lithium grease seemed to help when loosening the CC cable. Hasn't happened since.
Guess its time for a nice turbo blanket and some heatwrap for my DP
Old 06-25-2011, 10:16 AM   #13
Legacy01
Member#: 256016
2005 WRX
CGM
Apparently, there is no recall for the CC clip for a 2005 WRX...according to Minooka Subaru here where I live in PA. Service Pro was pretty adamant about it too....
Old 09-02-2011, 01:48 AM   #14
elchupanigre
Member#: 250498
04 wrx
jbp
my idle goes psycho on my up to 4000..
it's got the clip for the cc cable recall thing already
i cleaned the iacv less than a year ago already..
WHAT DO I DO..
MY CLUTCH GOT SO BONED FROM THIS
elchupanigre is offline   Reply With Quote
Old 09-02-2011, 02:14 AM   #15
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
WHAT DO I DO..
I... what?
XanRules is offline   Reply With Quote
Old 09-02-2011, 12:37 PM   #16
hoffmanEstates
Member#: 122043
04 wagonier
psm
i have this issue also but i dont run CC i cleaned the iacv and new gasket and was okm for a week now the prob is back again.
hoffmanEstates is offline   Reply With Quote
Old 03-14-2012, 07:03 PM   #17
Subie_Coop
Member#: 307821
2002 WRX(Hybrid otw)
& 95 Impreza L
This happened to my 2002 WRX last year the same day I picked up my car from a recall at the stealership. It was idling about 1500-1800rpm, brought it back to them and told them to fix it, but they had no idea what it was.
Luckily there was another WRX owner picking up his car at the same time we were looking at it out front of the stealership, he suggested the throttle cable so we adjusted it a bit, the idle came down and the cars been fine since.
no more recalls.
Subie_Coop is offline   Reply With Quote
Old 03-29-2012, 11:37 PM   #18
sublyme
Member#: 244114
2016 WRX premium
my car has done this twice in the last 3 years. both times i turned off the car and turned it back on. problem gone.. one day it was blistering hot outside, and the other it was maybe around 70F. both times I was waiting a long while in a drive thru..
sublyme is offline   Reply With Quote
Old 04-12-2012, 10:18 PM   #19
RALLYREX22
Member#: 260651
2004 WRX
SILVER
04 wrx same problem the hotter the day the higher the rpm. It hits 4500 while in heavy traffic im adjusting cruise cable tomorrow hope it works
RALLYREX22 is offline   Reply With Quote
Old 04-16-2012, 09:17 PM   #20
eclone
Member#: 31567
I've been having similar issues recently. RPM can hang anywhere to 3k when the car is warm/hot. Thought it was either one of the cables, MAF etc. Did so cleaning playing around and it didn't help. Anyway, noticed the throttle return spring wasn't backing all the way to the screw when I let off, and realized it's problem with the spring rusting and getting stuck so it's not fully returning to position. Sprayed some WD40 on it and worked it into the spring to break down some of that rust on it and seems ok so far. Going to do this for the next couple days to clean/loosen up the rust and scrub it off with a small wire brush.
Hopes this will help others here with the problem. I'll update if the problem returns.
eclone is offline   Reply With Quote
Old 04-16-2012, 11:12 PM   #21
alieus
Member#: 155634
2006 WRX
SRR
I have seen this on my friends 02 wrx. After he took off the heat shield to install a larger turbo he never put it back on as a result the heat cooked the Cruise Control unit so much it just tightens the cable to cause the high rpm. We actually took off the entire cruise cable the problem never happened again.
alieus is offline   Reply With Quote
Old 04-17-2012, 01:15 PM   #22
boyurlazy
Member#: 129385
I had the same problem, went for the recall for the CC clip, but still happening. Decided to pull the CC cable off and so far so good.
boyurlazy is offline   Reply With Quote
Old 05-27-2012, 09:55 PM   #23
sublyme
Member#: 244114
2016 WRX premium
I just experienced this again!
i know its not iacv, i cleaned that up really good + replaced gasket about 5k ago
Hot as balls outside, sitting in a drive thru. Idle slowly started to climb. I turned off the car for a minute and fired it back up- issue came right back. Drove about 1 mile down the street and the idle fixed itself almost immediately at the first light. I dont care if i have to rip out the CC cable, I don't use cruise control anyhow. Can anyone confirm this is a sure fix?
Old 05-28-2012, 04:04 AM   #24
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
my 05 wrx does this as well....i'm gonna look into the springs on the throttle body...clean them up and make sure there not grabbing onto on another....
my car only does this in hot weather as well...never in the winter
cosseywrx is offline   Reply With Quote
Old 05-28-2012, 10:34 AM   #25
berge56
Member#: 56754
2004 Hybrid 2.5XTR
Loosen up the cable for your cruise control..... as the cruise control unit get's hotter (it's right next to the turbo) it will pull the cable causing the idle to climb in traffic.
FS : 2004 WRX Helix High Flow Cat Downpipe brynboy SCIC Private Classifieds 6 12-06-2010 05:39 PM
FS : VA 2004 WRX STI Highly Modded $21k OBO billy720 Private Vehicle 'For Sale' Classifieds 1 11-11-2010 11:16 PM
another high idle issue, with lights dimming R-raid Service & Maintenance 14 08-23-2010 10:46 PM
high idle ISSUES!! majunche66 Built Motor Discussion 6 03-14-2009 07:44 AM
People with cold startup high idle issues 98EJ20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-22-2008 06:47 PM
