#26 | |
Member#: 257195
South East
Vehicle:2004 WRX 2.1L 12k miles strong |
#27 | |
Member#: 7164
Vehicle:---> Spoiler alert: Everyone dies at the end. |
Your stock map requires a stock car for proper operation. What you will have is a long, looong way from that. You need a tuner to help you with A) initial fire-up map, B) low-boost break-in map, C)final tune. The break-in oil will need to changed after the initial start-up, then at least once again before the final tune. |
#28 | |
Member#: 145145
Vehicle:2006 wrx STi |
Bottom Line, if you put stock 2.0L pistons in with a 79mm stroke crank the pistons will hit the heads; hence the need for a "stroker piston". The sttroker pistons is basically a 2.0 bore, with a 2.5L compression height. Oh, and on the subject of Oil/pumps. I would use a 10mm pump for your application especially considering the fact that you do not have AVCS. On my 2.1 with Mahle pistons I used Shell Rotella T 15W-40 for break in oil and it worked great. the rings seated fast. The motor never smoked and I never had to add any oil between changes. That being said, what are your planned clearances? I would not run a 40 weight oil unless you plan to run larger than stock clearances. |
#29 | |
Member#: 257195
South East
Specificly this thread. |
#30 |
Member#: 257378
Vehicle:2000 2.1rs stm |
you guys are making me a little weary about the map i was planning to run for my break in, the set up for my 2.1 is gunna run a vf39, pinks, and a sti tmic, i was initiall gunna use cobbs ots map for this setup on a 2.0 since it tunes by target afr and not injector pulse with, so in theory it should seek the proper afr despite the 100cc difference in displacement. i called precision tuning and asked them what they throught of the idea and they agreed that since the car is tuned for target afr that it would be fine to run this map for a break in as long as i stay out of boost. i imaging i could always go in and back off the boost solenoid duty cycle to keep me out of boost too for extra precaution
#31 |
Member#: 41561
Vehicle:04 GT3076 2.1 Stroker = Broken 3rd |
You would be fine with OTS map as a breakin map. the extra displacement is just going to make your hit load sites you normally wouldnt with a 2.0. the car will fireup no problem.
#32 |
Member#: 257195
South East
just my thoughts (again not a car guru).
If the engine isn't knocking and the car is hitting correct A/F ratio why couldn't the stage 1 map not work? Maybe not ideal performance but still. |
#33 |
Member#: 257378
oh i have no doubt the car will fire up just fine, i figure as long as im not pushing the engine and i watch my afr's i should be ill be fine, ill just put on 1500 miles back and forth from work, change the oil at 100, 500, and 1000 miles and then pay a visit to precision tuning to dial her in.
#34 | ||
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
By changing the stroke, you change the VE curve. Especially in lower RPMs where you'll be cruising and breaking it in on moderate boost. When you increase VE, you tend to lower the amount of timing advance the engine wants. Thus, the previous map will have more timing than you want... which almost certainly will result in knock. Using a 75mm stroke map with a 79mm stroke engine is setting yourself up for cruise and spool knock. This is not a huge deal if you transcribe to breaking it in super easy, but most like some moderate boost and vacuum to seat the rings. With 75mm stroke mapping, you will not want to enter boost at all, staying in load cells that are as low load as possible. It will run, but it won't run well enough to break it in, and you want to be able to break it in with some boost and vacuum as quickly as possible. Quote:
#35 |
Member#: 257378
so what do you suggest would be the best route, should i go into the ots map and take the timing back say like 3-5 degrees maybe more across the board and then leave the boost solenoid duty cycle alone so i see some low boost for the break in period
#36 |
Member#: 111048
Vehicle:I <3 debt word rally suck. |
imo 15w40 is an awfully thick oil to break the engine in. i would stick to cheap 5w30 for at least 100 miles
#37 |
Member#: 111048
dont baby for 300 or you will have a oil happy engine. ring break in is less than 50 miles of operation. get those babies seated with some healthy boost and lots of decel to pull them rings down on the wall.
#38 |
Member#: 7164
^^^^ Word.
Hard break-in all the way, provided you give the engine some run-in time to be certain everything's happy. With my build, the tuner ran a low-boost map and then a higher-boost (but not full) in the first 50 miles with an oil change done between map swaps to look for trouble. He ran the car on the mid-boost tune until 150 miles. Another oil change and I was putting the whip to it HARD after the first 150 miles of break-in and oil changes. Full boost, full throttle, assloads of engine braking and the engine burns no oil after 24K miles. Brutnus: you should probably add a turbo inlet and possibly a Crawford or Ixiz AOS (delete the PCV valve -- you don't need it). Last edited by Spenk; 05-20-2011 at 08:10 PM. |
#39 | |
Member#: 4414
Break in you can see in the big thread on it. I live near a nice long hill. I can warm the car up on the way to the hill, get a nice long pull up at 2.5-4k RPM at 5+psi, then a nice long decel on the way down. Turn around and you get it again. Alternate moderate boost and max decel as early as you can in the break in to get a good seal on the rings. Once you get a chance to do that, drain the oil and you can drive "normal" for as long as you feel necessary for remainder of break-in. I think the 2nd part of break-in is much less important than the initial ring seat. |
#40 |
Member#: 175095
PRSIC
Vehicle:2000 RS Silver |
What kind of HP and torque can we expect from a forged 2.1 stroker? Compared to a forged 205
#41 |
Member#: 242422
Vehicle:'02 18G-XT 2.5L WRX '01 RS Coupe |
Cool build! I would do the TGVs but only if you can save a lot of money and do it yourself.
Why are you going with a new pick up? |
#42 |
Member#: 242422
#43 | |
Member#: 4414
If you think about the EJ205 vs. the USDM 2.5L engines (EJ255 and EJ257) there are four main differences: - heads have better cams ... results in better flow at high flows, usually meaning better peak HP. Partly made possible from AVCS due to emissions. - Stroke is longer ... shifts torque curve left, more power in the low end, better cruise fuel economy, slightly lowers redline. - Bore is larger ... results in more power everywhere if there is turbo flow to support it. Heavier pistons will slightly reduce VE at very high RPM. Displacement directly impacts fuel economy - AVCS ... can result in 20-25% more torque in the low end. no loss of high end power. Usually improves fuel economy. A stroker addresses one of these (stroke), a hybrid addresses two (stroke and displacement). People think displacement is the biggest benefit to driveability and feel, but AVCS and stroke are almost certainly bigger contributors. AVCS is huge for low end torque and drivability, and why EJ207 swaps are a popular option as well. |
#44 | |
Member#: 7164
#46 |
Member#: 7164
#47 |
Member#: 242422
Ok so a legitimate crack occurs. You could have just said so instead of replying with
.Now let's not take over this guy's build thread. Good luck with the 2.1 stroker! |
#48 |
Member#: 3687
Vehicle:MY99 GF4 JDM 6spd NF Performance |
I stress that you take out all oil galley's on the block and clean the galleys out well.
#49 |
Member#: 178811
Vehicle:2013 WRB BRZ :banana: |
Instead of DIYing TGV deletes or buying them from GrimmSpeed, I'd suggest a V8 manifold. Good thing I have one for sale too! /shameless plug
Sell the Cobb AP and go for an OS tune on the 2.1, also I would suggest an 18G sized turbo. |
#50 |
Member#: 257195
South East
| Thread Tools | |
| Display Modes | |
| 2.1L Stroker Engine Group Buy | Maxwell Power | Vendor 'Group Buy' Classifieds | 142 | 04-03-2012 01:55 PM |
| 2.1l Stroker build oil? | jakedademon | Built Motor Discussion | 20 | 03-16-2011 09:26 PM |
| Have confusion about ej20 2.1L build.. I want to use the STI crank. | glutetoot | Factory 2.0L Turbo Powertrain | 4 | 10-02-2010 12:07 PM |
| Build closed deck stroked 2.1L Cheap | Texy32 | Engine/Power/Exhaust | 35 | 05-01-2010 07:57 PM |
| My first engine build. 2.5RS SOHC N/A -> Turbo | Ninja007 | Built Motor Discussion | 3 | 01-31-2009 01:36 PM |
