Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 03-20-2013, 05:27 PM   #76
chris84bond
Member#: 51723
My10 had the same issue...got the dealer to acknowledge it after 3 trips. Go figure, as soon a they did they had a brz on the lot.
On the plus side...doesn't squeak anymore
chris84bond is offline   Reply With Quote
Old 03-20-2013, 05:33 PM   #77
2012BayAreaWRX
Member#: 350801
2012 Subaru
Plasma Blue
Any modifications to the car? My stock clutch on my 2012 WRX went out around 8k with just full bolt ons + protune.
I'm thinking your clutch is going out. Possibly Subaru will cover it under warranty. If your ECU doesn't show any abusive behavior.
2012BayAreaWRX is offline   Reply With Quote
Old 04-17-2013, 10:52 AM   #78
loudnlow
Member#: 44723
'13 WRX Sedan
'08 Fozzy
In terms of driving with this issue, is it dangerous? Is it something that I should try to fix as soon as possible, or will it be ok for a couple months?
Thanks
loudnlow is offline   Reply With Quote
Old 04-19-2013, 05:16 PM   #79
davidboies
Member#: 304390
I have a 2009 wrx sedan with 113,000 miles on it. It's had a squeaky clutch for as long as I can remember. I didn't think anything about it until I started having trouble putting the car in reverse and 1st, and the brake pedal would move over with the clutch when I presse in the clutch. Took it to the dealer and they adjusted the clutch. It helped for a little while, but then it went right back to what it was doing before.
Took it to subaru and they said its a cracked firewall and they wont/cant fix it. Same thing with the dealer i got it from. They all say they need to send it to a dfferent shop. Car wont start since the clutch wont go all the way in, so im getting the car towed back to my house and plan on fixing it myself.
I'd like to keep this from happening again. I know ill need to remove the dash and possibly the steering column to get to where ill need to weld. I'd like to reinforce that area too. Is that all ill need to do and do I really have to take out the steerig column? I plan on getting the grimmspeed brace as well.
Now, does anybody have any advice/experience they could share?
davidboies is offline   Reply With Quote
Old 04-22-2013, 06:46 PM   #80
Armyofcase
Member#: 281396
2009 WRX Sedan
World Rally Blue
Hey guys! I have a 2009 WRX Sedan and have the same issue. Cracks in the firewall...no easy way to fix it other than taking out the dash and rewelding everything. Sad news is that after this was done, it cracked again so I'm back to square one. That being said, I contacted a class action attorney to see about legal ramifications concerning this. They took a look at the issue and we've got a really strong case to force a possible recall on our behalf for all 08+ WRX's affected. If you have a moment, please give Greg Coleman Law a call at 1-800-Hurt-Now. His website is www.gregcolemanlaw.com. We need to get as many people that have had this problem chiming in. Hopefully, if you've already paid to have this fixed you will get reimbursed by SOA. If you haven't fixed this yet, then they will fix their problem. Thanks everyone!!!
Armyofcase is offline   Reply With Quote
Old 04-24-2013, 10:50 AM   #81
davidboies
Member#: 304390
bump definitely calling later
Old 04-24-2013, 02:56 PM   #82
Subiezilla
Member#: 280543
Besides the 3 welds underneath the windshield wiper assembly are their other places that the firewall may be cracked or broken or look out for?
Subiezilla is offline   Reply With Quote
Old 04-24-2013, 10:44 PM   #83
Armyofcase
Member#: 281396
2009 WRX Sedan
World Rally Blue
There are two welds under the windshield wiper motor; the third is behind the dash on the shelf of the firewall. We're gaining traction on this so please if you know anyone that has had this happen, give Greg Coleman a call at 865-247-0080. Thanks!
Old 04-24-2013, 11:28 PM   #84
Subiezilla
Member#: 280543
Well my 2 welds under the wiper motor are intact but I have the annoying sound so I can't say for sure it's the welds that are busted. For your case did the welds break then the sounds happened? Or first the sound came then the welds broke? Also on mine there is a little bit of movement on my slave cylinder reservoir.
Should I still call n join the lawsuit?
Old 04-25-2013, 12:59 PM   #85
stl2009wrx
Member#: 287822
2009 WRX
I am currently having the problem with the clutch. I can barely manage to get into gear. Does SOA not understand there was a lawsuit almost 10 years ago that stated the you are allowed to use aftermarket parts without it voiding warranty issues? I'm 31, and I'm currently an engineering student, so I know about strengths of materials. Subaru should realize that they are in the wrong and should fix the problem. If not, it will cost them a lot more in the long run with lawsuits.
stl2009wrx is offline   Reply With Quote
Old 04-25-2013, 01:15 PM   #86
P-Train
Member#: 279233
2008 WRX
That be Magnusson Moss right?
P-Train is online now   Reply With Quote
Old 04-25-2013, 01:37 PM   #87
stl2009wrx
Member#: 287822
2009 WRX
Yes that act talked about covering defects. I'm not still in warranty range, but a manufacturer defect should be covered anyway. Subaru does not does not explicitly tell not to use an aftermarket clutch. I had the dealer put in mone, and was told nothing other than they have put them in before. The welds themselves are not technically breaking. It is the metal by the welds that is breaking
Old 04-25-2013, 01:40 PM   #88
stl2009wrx
Member#: 287822
2009 WRX
This should lead any strengths and materials engineer to cone to the conclusion that the metal used in that spot wasn't strong enough to support the stresses involved. It is a clear cut manufacturers defect. I don't understand how Subaru doesn't get that.
Old 04-26-2013, 01:44 PM   #89
LASOOBIE
Member#: 314389
2009 WRX Sedan
I am dealing with SOA right now about the issue. Supposed to hear back from them on Monday. My car just sits in the dealership as of now
LASOOBIE is offline   Reply With Quote
Old 04-26-2013, 03:08 PM   #90
P-Train
Member#: 279233
2008 WRX
I'm sure they realize it but just refuse to admit it. They suck.
Old 04-26-2013, 04:00 PM   #91
davidboies
Member#: 304390
so is there a way to fix it without it happening again?
Old 04-29-2013, 10:23 PM   #92
stl2009wrx
Member#: 287822
2009 WRX
Check out this thread I started. I will be going step by step on dealing with SOA, the dealership, and how to fix it if Subaru won't
http://forums.nasioc.com/forums/show....php?t=2499563
Old 04-29-2013, 11:21 PM   #93
Subiezilla
Member#: 280543
Update: upgraded today from a squeaky pedal to a 2 stage click when pressing the clutch pedal in. Only noticeable when the car is off >\ I'm my mind I imagine its the spot welds under the wiper blade motor clicking errr
Old 04-29-2013, 11:29 PM   #94
stl2009wrx
Member#: 287822
2009 WRX
You are probably right. It's easy to check those welds though, but not so easy to fix. Keep us updated.
Old 04-30-2013, 10:16 AM   #95
P-Train
Member#: 279233
2008 WRX
Not sure if you guys have seen this in the other thread that's out there but this was my "quick" solution to the broken spot weld behind the instrument cluster.
I'm really happy with it. It's nice and quiet now the pedal also feels a little better too.
Originally Posted by P-Train View Post
Alright folks so last night I took a whack at repairing this issue without welding. I pulled the dash out and found the infamous broken spot weld.
I took a couple of shots to try and give an idea exactly where it was because when I was researching it I had a little trouble visualizing exactly where this was.
So I was planning on doing a nut and bolt/ JB weld sort of fix. I found a pre-existing hole that was perfect for a 5/16" screw so I used that and drilled another though the part that had broken free.
I also hacked up some quick and dirty clamp and bolt system to hold everything together.
Mounting it up I used lock washers, Loctite and JB Weld anywhere I could. I wish I had more time to let the JB cure before I had to drive it but overall I'm happy with how this came out.
The whole set-up fit pretty well behind the dash with minimal interference. As for functionality, It works pretty well, the loud obnoxious popping is gone, but I still have a very slight creak. No where near as loud as it was before, quiet enough to be drowned out by wind noise if your window is down. I would have liked to machine up something a little nicer so the fit would be perfect, but I couldn't afford the downtime. (I had to give my Dad a ride to the airport this morning). We'll see how this holds up over time. But for now I at least feel better about driving it everyday through the city. If I'm feeling ambitious one day maybe I'll machine something nice up to replace this lol.
Old 04-30-2013, 10:28 AM   #96
stl2009wrx
Member#: 287822
2009 WRX
Why wouldn't you just weld it since you took the time to remove that much if the dash? A good certified welder shouldn't charge you more than $50 to weld that whole bracket tight.
Old 04-30-2013, 10:48 AM   #97
P-Train
Member#: 279233
2008 WRX
pulling the dash was wasn't that bad, so I wouldn't mind doing it again But it was kind of a spur of the moment thing. Plus I didn't want to deal with metal that thin being heat affected and breaking later.
Old 04-30-2013, 11:00 AM   #98
stl2009wrx
Member#: 287822
2009 WRX
That is my concern as well. I'm going to be welding in additional supports for that bracket. Plus welding across the top and bottom of the entire bracket for added security. I'm still trying to decide the best course of action with the firewall flex though. I've seen someone welding a piece of pipe to the steering column, but I thinks that's a bad idea, so I might do a cardboard mock up of an entire bracing fir the firewall to see what I can come up with. Anyone have any ideas?
Old 04-30-2013, 11:03 AM   #99
P-Train
Member#: 279233
2008 WRX
I've been toying with the thought of adding some extra support structure on the pedal structure. I'll add it if I make anything up.
Old 04-30-2013, 12:49 PM   #100
JustyWRC
Member#: 153088
2005 Baja Turbo
06 Forester 09 WRX
I read that other post but didn't really care to read this whole thread fully. What I got out of what I did read was that people put in a non Subaru part and it broke something and now want Subaru to fix it. They apparently haven't on many cases so someone is getting a class action lawsuit against Subaru over it.
Yeah. I'd like to see the outcome of that....
going to vt. straight shot anything to worry about? polarisboy385 General Community 55 01-21-2011 05:22 PM
If you're not doing anything wrong, you don't have anything to worry about. Corn-Picker Political Playground 7 07-24-2008 01:08 AM
'98 RS heagasket anything to worry about? jamesfacts Normally Aspirated Powertrain 11 02-04-2004 07:28 PM
Getting 91 MR2 - anything to worry about? WRXVII Off-Topic 16 10-05-2003 02:50 AM
Anything to worry about...? XROLLER Brakes, Steering & Suspension 4 05-15-2002 01:04 PM
