Old 01-02-2013, 03:15 AM   #2626
_davin
Member#: 260501
2003 miata SE
Blurple
I'm running naked myself, but I'm going to get a ptp blanket blanket and a coated grimmspeed shield when I put my new AVO tmic on.
_davin is offline   Reply With Quote
Old 01-02-2013, 09:12 AM   #2627
PearlRex11
Member#: 284420
2011 WRX Sedan
The stock is better than the aftermarket ones from what I've heard due to the thickness of the metal and the way it is shaped. Probably not much of a difference though. The stock is very very easy to modify. Benefit to going aftermarket is that you can return to stock without it looking like you were stage 2 as much. Be careful running nothing at all, my friends paint is coming off right by his hood scoop directly above the turbo from doing this.
PearlRex11 is offline   Reply With Quote
Old 01-02-2013, 09:37 AM   #2628
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
Stock+aftermarket is even better!
nightdown fox is offline   Reply With Quote
Old 01-02-2013, 10:19 AM   #2629
thildwrx
Member#: 303531
12 Subaru WRX
What did you use?
thildwrx is offline   Reply With Quote
Old 01-02-2013, 11:41 AM   #2630
_davin
Member#: 260501
2003 miata SE
Blurple
Well I live in Alaska so the ambient temperatures are so low it's not really an issue. Besides it's winter right now and I'm not usually on it very hard anyway.
Old 01-02-2013, 01:36 PM   #2631
PearlRex11
Member#: 284420
2011 WRX Sedan
Originally Posted by thildwrx View Post
What did you use?
I cut the stock one with tin snips and filed the edges, literally takes 10 minutes if that. Saves you about $50
Old 01-02-2013, 02:28 PM   #2632
thildwrx
Member#: 303531
12 Subaru WRX
Awesome thanks for the info!!!
Old 01-02-2013, 04:06 PM   #2633
Ying
Member#: 166490
2011 WRX
On my last car I cut the stock heat shield with a dremel. Worked like a charm.
Ying is offline   Reply With Quote
Old 01-06-2013, 10:23 AM   #2634
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
So I went and got the coolant ECU recall done and gave COBB the rom here: https://forums.cobbtuning.com/forums...Program-WQC-39. A '12 STI owner posted a stock rom with the recall update there too. Hopefully they can use the data to update their maps.
Sidenote, since this issue only affects 2011+ cars, I'm really glad we have a 2011+ discussion thread.
Old 01-06-2013, 12:45 PM   #2635
thildwrx
Member#: 303531
12 Subaru WRX
Ok so I just bought a used cobb downpipe. The guy only had it on the car for 1000 miles. My question I have a spt exhaust on my 12 wrx with 8000 miles, do I need new gaskets for it? When you buy a downpipe new does it come with gaskets?
Old 01-06-2013, 12:47 PM   #2636
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
you can probably get away with using the stock gasket for the bottom, its a good idea to get a new gasket where it mates to the turbo since that one is much harder to change if its leaking
Celery GT-5 is offline   Reply With Quote
Old 01-06-2013, 12:53 PM   #2637
_davin
Member#: 260501
2003 miata SE
Blurple
Yeah, get a new one for the turbo and you should be able to reuse the doughnut gasket.
Old 01-06-2013, 01:05 PM   #2638
zamudio1987
Member#: 297588
2011 wrx
white
Default 2011 wrx 5spd to 6 spd swap
hi guys new to nosiac looking to get some advice. im looking to swap out my 5 spd for a 6 spd. does anybody know which tranny would fit my 2011 wrx. i have major upgrades and need a 6 spd. any advice would be helpful.
zamudio1987 is offline   Reply With Quote
Old 01-06-2013, 01:07 PM   #2639
Celery GT-5
Member#: 98210
2002 WRX SRP
you pretty much need to do the full 5x114.3 conversion with all the axles and such to make it work from what I've heard
Old 01-06-2013, 01:21 PM   #2640
thildwrx
Member#: 303531
12 Subaru WRX
Where would I get the gasket? Direct from cobb?
Old 01-06-2013, 01:26 PM   #2641
_davin
Member#: 260501
2003 miata SE
Blurple
Subaru dealership, same gaskets for the stock downpipe.
Old 01-06-2013, 01:33 PM   #2642
thildwrx
Member#: 303531
12 Subaru WRX
Great thanks
Old 01-06-2013, 02:40 PM   #2643
PearlRex11
Member#: 284420
2011 WRX Sedan
I appreciate you guys taking the time to do that, considering you didn't have to seeing how you received the update. I haven't seen the letter from Subaru but I might have just overlooked it. Hope Cobb can do something with that info. Thanks again
Old 01-06-2013, 03:24 PM   #2644
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
No problem man, it's all about helping the community! I figured it was safer for me to collect the update for COBB since my car is otherwise stock rather than having a Stage 2 risk it.
Old 01-06-2013, 09:15 PM   #2645
SWP is Sexy
Member#: 302389
2011 WRX
I'm a stormtrooper pewpew
I'm also curious about solid info on this. Its something I'll be looking into in the future
SWP is Sexy is offline   Reply With Quote
Old 01-08-2013, 12:21 AM   #2646
JFIV
Member#: 298002
2011 WRX Base
Obsidian Black Pearl
Anyone else feel like the gear ratio for 4th and 5th gear in the 2011 WRX is odd? I feel like the 4th gear pulls much harder and longer than 5th? I feel like a fool for asking this and don't know if I'm describing it correctly but maybe someone will understand what I'm talking about.
JFIV is offline   Reply With Quote
Old 01-08-2013, 12:30 AM   #2647
_davin
Member#: 260501
2003 miata SE
Blurple
5th is the final gear, you shouldn't be pulling in it unless you're already going like 120.
Old 01-08-2013, 12:32 AM   #2648
Celery GT-5
Member#: 98210
2002 WRX SRP
generally the lower gears will pull harder than higher ones...otherwise it would be hard to do things like, for example, moving
Old 01-08-2013, 06:34 AM   #2649
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
I never received one either. What exactly was recalled or was it tsb? The only recall I've heard of from subaru is the one that they just announced about the puddle lights on the foresters and legacy's.
So what's the difference?
I don't know if its applicable for the gr's, the legacy 6 speed is usually much cheaper than the Sti 6 speed and the gears are more usable... We all know the Sti is geared for towing boats out of the water.
Louie is offline   Reply With Quote
Old 01-08-2013, 11:18 AM   #2650
Celery GT-5
Member#: 98210
2002 WRX SRP
I think newer wrx gears are already about the same as legacy gears
Differences of 2011 wrx motor and 2011 sti motor stpkenton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-06-2012 11:03 AM
Differences of 2011 wrx motor and 2011 sti motor stpkenton Newbies & FAQs 3 05-12-2011 09:27 PM
2011 Subaru shifter fitment! All TWM Shifters still fit! TWM Performance Vendor Announcements 14 02-28-2011 03:27 PM
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb agentmaxwell Private 'For Sale' Classifieds 1 05-24-2006 07:41 PM
Attn: Clayton, Ben and all others involved in the 6MT discussion. sherifx Mid West Subaru Owners Club Forum -- MWSOC 1 07-31-2002 03:00 AM
