Old 08-16-2011, 11:34 AM   #251
Sti_Kent
Member#: 290645
2011 Sti Hatch
:bump:
Since its clear there arent quite that many 2011 owners ...
Ive seen reviews claiming the 2011 sti took an evolution towardsnusing parts from the spec C, is that true?
Likewise, would you all say the hype is true and the 2011 actually improved from the '10 model?
Thanks, just looking for model specific info beyond whats found in the manifesto.
Sti_Kent is offline   Reply With Quote
Old 08-16-2011, 12:29 PM   #252
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
Celery GT-5 is offline   Reply With Quote
Old 08-18-2011, 04:09 PM   #253
shaggydog
Member#: 247390
'11 STi
I guess ill post up my mods too, fairly basic thus far:
Engine:
SF Intake + Cobb AP
GS Light Crank Pulley
GS AOS
Cusco Engine Mounts
Beatrush Forged Pitch Stop
Drivetrain/Tranny:
Cusco Tranny Mount
TiC Crossmember Bushings
Whiteline Rear Diff Inserts
Kartboy Rear Subframe Donuts
Kartboy STS + F/R Bushings
Suspension:
Whiteline 24mm Front/ 22mm Rear Sways
Kartboy Endlinks
GTSpec Fender Braces
GTSpec A Braces (currently sitting in my garage)
Whiteline Steering Rack Bushings (also sitting in my garage)
Interior:
JPM Coachworks Shift/Brake Boots
WC Lathe Werks Custom Knob and Reverse Lockout Ring
JDM Armrest Extension
Exterior:
HT Auto Lip
Bluebat Smoke Overlays
Roof Vinyl
GS Front Plate Relocation Kit
RA Mudflaps
Hella Supertones
35% & 20% Tint w/ Crystalline
Future Mods:
Stoptech SS Brake Lines and new fluid
I.C.E.
Gauges
Tires
Im currently waiting on ARK to make their CBE, should be finishing up in September. If i dont like the tone it produces ill go with the Blitz Nur Spec R and i have yet to decided on the DP. Im going to pair that piping with the Invidia ELH. All piping will be ceramic coated and once installed ill drive up to Cobb and get tuned.
shaggydog is offline   Reply With Quote
Old 08-18-2011, 04:12 PM   #254
BullyWRX
Member#: 258756
2011 WRX
ELH's will ensure that you sound like a Honda.
BullyWRX is offline   Reply With Quote
Old 08-18-2011, 04:31 PM   #255
shaggydog
Member#: 247390
'11 STi
The sound is subjective. Plus your engine will run much more efficient. Id rather sound like a Honda and have a happy engine than keep the subie rumble.
.02
Old 08-18-2011, 04:44 PM   #256
Vash337
Member#: 282107
2011 wrx sedan
obsidian black
yea, im on the fence about it. but in the end function>style
Vash337 is offline   Reply With Quote
Old 08-18-2011, 05:44 PM   #257
BullyWRX
Member#: 258756
2011 WRX
.02
INFIDEL!!!!!!!!!!!! Subie rumblz are greater than all else!
Old 08-22-2011, 01:07 AM   #258
mark22179
Member#: 291560
2011 WRX
Satin White Pearl
Default 2011 Wrx
Just got mine yesterday!!! I am used to driving a 2wd Clutch....any tips and what and what not to do's on an AWD? Remember, be nice to the newbie!!!
mark22179 is offline   Reply With Quote
Old 08-22-2011, 06:26 AM   #259
MFwrx
Member#: 264415
2011 impreza WRX
NEVER dump the clutch and if you do don't expect to get anywhere quickly. Personal experience
MFwrx is offline   Reply With Quote
Old 08-24-2011, 01:29 PM   #260
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
Whatcha guys think about paint-matched front lips for our cars?
I've seen 04-07's with them. I kinda like them. I also kinda like the obvious front lip look with them being carbon fiber or black.
Old 08-24-2011, 02:44 PM   #261
shaggydog
Member#: 247390
'11 STi
There is nothing wrong with it. It comes down to the owner. I think it looks good either way.
The only downside to a painted lip that i can think of would be it chipping. Ive only had my lip for a few weeks and its already taken a pounding. For what its worth, i left mine black.
Old 08-24-2011, 05:51 PM   #262
_davin
Member#: 260501
2003 miata SE
Blurple
There's probably an FAQ on this, but since you brought it up. What is the easiest/smoothest way to pseudo-launch our cars quickly?
_davin is offline   Reply With Quote
Old 08-24-2011, 06:19 PM   #263
BullyWRX
Member#: 258756
2011 WRX
^^^^^4-5k RPM and slip the clutch.
Old 08-24-2011, 08:13 PM   #264
_davin
Member#: 260501
2003 miata SE
Blurple
I'm assuming slip means gradualy letting off untill it engages, as opposed to dumping?
Old 08-24-2011, 09:59 PM   #265
Poptart1318
Member#: 230510
2011 MX-5
I wouldn't slip it too much, you'll roast it with the rpms up there. As he said 4-5k is good, and let off the clutch quickly without completely dumping it if that makes sense
Poptart1318 is offline   Reply With Quote
Old 08-25-2011, 12:12 AM   #266
BullyWRX
Member#: 258756
2011 WRX
Right! You want to avoid just abruptly releasing the clutch, also referred to as "side-stepping" it.
Old 08-25-2011, 07:21 PM   #267
_davin
Member#: 260501
2003 miata SE
Blurple
Thanks, I look forward to trying this next spring. One of my dunlops blew out recently and I had to throw some new blizzaks on early. Has anyone had any luck getting one of these new tires warranty replaced?
Also my SPT boost gauge just started flickering last night...
Old 08-25-2011, 07:33 PM   #268
shaggydog
Member#: 247390
'11 STi
Everyone has had trouble with the those gauges. Most of them do not work. Id check your connections.
Hey i just noticed you are from North Pole. I lived there for 3 yrs when i was younger and went to NP middle. Food Factory had awesome wings!!
Old 08-25-2011, 07:36 PM   #269
chanomatik
Member#: 159474
SNOSLO
It'll die. Mine died earlier this year and I got it replaced under warranty. Apparently it's a 2010 SPT gauge that isn't supposed to work, but does, even better than the 2011 ones that are supposed to be mounted. My replacement 2010 one has been fine, I dim it almost every night when I go driving late and no flickering yet.
Is Kendall your local Subie dealer in Fairbanks?
Old 08-25-2011, 07:46 PM   #270
Celery GT-5
Member#: 98210
2002 WRX SRP
flat tires are not a warranty issue.....
Old 08-25-2011, 08:34 PM   #271
_davin
Member#: 260501
2003 miata SE
Blurple
I grew up in Fairbanks, Wife and I just bought our house out here last year for lack of options. And the NP FF closed down years ago, but there's still one in Fairbanks with awesome cheessteaks.
Yeah, I haven't even gone there yet once though. Suppose I have to now.
Not for the car, but the stock Dunlops come with their own warranty.
Old 08-25-2011, 10:21 PM   #272
Celery GT-5
Member#: 98210
2002 WRX SRP
if they fail from a defect, not if you just got a flat tire from road debris
Old 08-29-2011, 11:24 PM   #273
derek2011wrx
Member#: 282931
Has anyone put an ewg on their 2011 yet?
derek2011wrx is offline   Reply With Quote
Old 08-29-2011, 11:38 PM   #274
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
xabre1200 is offline   Reply With Quote
Old 08-31-2011, 10:07 AM   #275
derek2011wrx
Member#: 282931
Originally Posted by xabre1200
Not bad. I'm probably gonna go with the 38mm in the next cpl months or so
Differences of 2011 wrx motor and 2011 sti motor stpkenton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-06-2012 11:03 AM
Differences of 2011 wrx motor and 2011 sti motor stpkenton Newbies & FAQs 3 05-12-2011 09:27 PM
2011 Subaru shifter fitment! All TWM Shifters still fit! TWM Performance Vendor Announcements 14 02-28-2011 03:27 PM
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb agentmaxwell Private 'For Sale' Classifieds 1 05-24-2006 07:41 PM
Attn: Clayton, Ben and all others involved in the 6MT discussion. sherifx Mid West Subaru Owners Club Forum -- MWSOC 1 07-31-2002 03:00 AM
