Old 05-24-2013, 12:13 AM   #2926
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
unless you are using dino oil its totally pointless
Celery GT-5 is offline   Reply With Quote
Old 05-24-2013, 01:43 AM   #2927
PearlRex11
Member#: 284420
2011 WRX Sedan
Originally Posted by corvid View Post
gotcha. My dealership is still using the 3750 so Ill roll with it
My 2011 came with the free 2yr 24k maintenance including oil changes, they only give you enough oil changes to equal out to doing one every 7500. If you do them every 3000 then you run out of them in half the time. I wouldn't think dealerships would vary in that department.
PearlRex11 is offline   Reply With Quote
Old 05-24-2013, 01:49 AM   #2928
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
Dealerships are all over the place with this stuff
Old 05-24-2013, 02:21 AM   #2929
corvid
Member#: 300097
Its more of a personal thing
corvid is offline   Reply With Quote
Old 05-24-2013, 10:42 AM   #2930
PearlRex11
Member#: 284420
2011 WRX Sedan
That's cool, I have been doing my oil changes at 3k since I got the car. I personally will look into at least slightly longer intervals if the oil is still doing what it needs to do after 3k. In my mind that 3k oci was accurate for the Dino oil back in the day when synthetic didn't exist but it doesn't seem like it applies to today's synthetics. In the other hand piece of mind is a very important thing, I will be doing a Blackstone test before I do that for my own piece of mind.
Old 05-24-2013, 05:58 PM   #2931
PearlRex11
Member#: 284420
2011 WRX Sedan
Anyone else have the annoying clutch squeak? Mine sounds like it's coming from the firewall. I tried to spray some white lithium grease but did no good. It only squeaks after I've driven it around for a little bit and its only at the last inch of the clutch pedal being pushed in. Doesn't sound like a throwout bearing or the firewall flexing.
Old 05-24-2013, 06:19 PM   #2932
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Check if your firewall welds are broken.
xabre1200 is offline   Reply With Quote
Old 05-24-2013, 10:28 PM   #2933
PearlRex11
Member#: 284420
2011 WRX Sedan
I think I'm reverting back to stock tomorrow and taking it in for it. Doesn't seem like it's the firewall but I'd rather take it in while I still have a warranty.
Old 05-24-2013, 10:29 PM   #2934
PearlRex11
Member#: 284420
2011 WRX Sedan
Is their anyway to get a look at the welds without removing the entire dash?
Edit: nvm actually found your YouTube video (xabre) . I will check that out first, thanks for the info
Old 05-24-2013, 10:41 PM   #2935
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Ah yeah I was going to make an entire video of the process but I had no idea what I was doing lol. Pretty much just take off the windshield wipers, remove the plastic clips that hold the plastic panel to your car that's right under your windshield wipers, remove the bolts that hold in the windshield wiper motor and you can see all the welds. It should be pretty obvious is your welds are broken but id have someone go in and step on the clutch. A tip is to take your time removing the little plastic piece that hold the larger plastic trim to the left and right side of your car. They are very easy to break... Which is why my right side is being held in by double sided tape (
Old 05-24-2013, 10:56 PM   #2936
PearlRex11
Member#: 284420
2011 WRX Sedan
I appreciate the info. So it seems I won't have to remove the wiper motor to be able to see the welds? Is yours still squeaking?
Old 05-24-2013, 11:12 PM   #2937
PearlRex11
Member#: 284420
2011 WRX Sedan
Here is a pretty good write up- http://www.wrxforums.com/forums/84-d...olt-style.html
Maybe I won't jump the gun and revert back to stock yet. Will be checking on this in the morning first.
Old 05-25-2013, 02:30 AM   #2938
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
You don't have to but it's only 3 bolts so I think you might as well just to be certain since there are some welds in hard to see places.
Old 05-25-2013, 12:03 PM   #2939
FerdSimao
Member#: 280691
2012 WRX Ice Silver Sedan
Do you guys think that if I get the lid on my cobb sf intake box powder coated it would hold up? I'm also thinking about the top side of my Grimmspeed turbo heat shield but I don't know if it will hold up. I do have a turbo blanket and the underside on the heat shield with DEI gold tape. I was told that powder coated is good for up to 400 F. I think it will be ok. What do you guys think?
FerdSimao is offline   Reply With Quote
Old 05-25-2013, 01:16 PM   #2940
PearlRex11
Member#: 284420
2011 WRX Sedan
The intake lid should be fine. I don't think the heat shield would hold up though, is it just going to be for looks? Try VHT spray paint
Old 05-25-2013, 01:19 PM   #2941
PearlRex11
Member#: 284420
2011 WRX Sedan
Yeah I'm going to take it out and look at it. I am think the rod on the master cylinder is the issue actually. It's just really hard to get a can of lubricant in that area.
Old 05-25-2013, 06:45 PM   #2942
PearlRex11
Member#: 284420
2011 WRX Sedan
The spot welds are fine, I think it's the master cylinder. Will probably take it in sometime soon.
Old 05-25-2013, 09:27 PM   #2943
rmj
Member#: 276611
2011 STi 5-Door
Plasma Blue Pearl
Got 4th gear tuned by Nuke at NF today!
rmj is offline   Reply With Quote
Old 05-26-2013, 02:52 AM   #2944
FerdSimao
Member#: 280691
Yeah it will just be to add some bling to the engine bay!! I sure hope the tip side of my heat shield doesn't reach 400 F. Yeah but I'm not sure. I'll have to ask the coater guy and see what he thinks. I tried searching for pics but couldn't find anyone who powder coated the heat shield. Just ceramic coat and VHT paint.
Old 05-26-2013, 02:59 PM   #2945
PearlRex11
Member#: 284420
2011 WRX Sedan
I believe the turbo gets significantly hotter than that (1000+) and the heat shields job is to absorb/deflect that heat, I have a feeling the powder coat will discolor at the very least. It would be interesting to see the outcome though, I hope it works out.
Old 05-26-2013, 04:03 PM   #2946
FerdSimao
Member#: 280691
I understand that the turbo gets that hot. But my turbo is wrapped in thePTP blanket and the underside of my Grimmspeed heat shield has the DEI gold tape so I believe the top of the heat shield doesn't get that hot. I mean I can touch it after hard driving. So it might be ok to powder coat. I guess I will see.
Old 05-26-2013, 05:04 PM   #2947
PearlRex11
Member#: 284420
2011 WRX Sedan
Yeah that doesn't sound too bad then, didn't remember seeing you had a blanket on it.
Old 05-30-2013, 12:43 AM   #2948
PearlRex11
Member#: 284420
2011 WRX Sedan
Update on the clutch squeak. I found a "mod" friendly Subaru dealership and ended up taking my car in this morning with the dp+tune on it. I told them that the clutch had a squeak in it and they ended up calling me later today and said that the clutch was harder to press than it was supposed to be and that is causing the squeak due to the higher strain on the clutch pedal assembly (not sure the technical term for each little component) so they are replacing the clutch, throwout bearing and flywheel under warranty. The service writer also told me that SOA will replace your clutch no questions asked if they find something wrong with it and you are still under your 3yr/36k but only once during that time and the extended warranty doesn't cover the clutch after the 36k is up. They are even covering my loaner Chevy Cruze for the next day or two for them to finish the work. Hope that info helps someone.
Old 05-30-2013, 01:57 AM   #2949
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
Good to hear
Old 05-30-2013, 05:32 AM   #2950
corvid
Member#: 300097
I had mine replaced at 11k, with zero mods. I was told it was probably a faulty clutch, and that even though they used up the one replacement under warranty, they still can replace it again should another issue arise. Something about a good will program or something along those lines...
Differences of 2011 wrx motor and 2011 sti motor stpkenton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-06-2012 12:03 PM
Differences of 2011 wrx motor and 2011 sti motor stpkenton Newbies & FAQs 3 05-12-2011 10:27 PM
2011 Subaru shifter fitment! All TWM Shifters still fit! TWM Performance Vendor Announcements 14 02-28-2011 04:27 PM
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb agentmaxwell Private 'For Sale' Classifieds 1 05-24-2006 08:41 PM
Attn: Clayton, Ben and all others involved in the 6MT discussion. sherifx Mid West Subaru Owners Club Forum -- MWSOC 1 07-31-2002 04:00 AM
