Old 07-10-2013, 03:34 AM   #3076
JWHWRX112
Member#: 351928
2012 WRX Sedan
What kind of sways are you considering? I'm considering Cobb's right now but haven't fully committed yet
JWHWRX112 is offline   Reply With Quote
Old 07-10-2013, 04:24 AM   #3077
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
Idk maybe whiteline
Celery GT-5 is offline   Reply With Quote
Old 07-10-2013, 10:38 AM   #3078
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Originally Posted by Celery GT-5 View Post
Idk maybe whiteline
Love my white line sways. The powder coat is standing up up much better than the old painted ones.
Louie is offline   Reply With Quote
Old 07-11-2013, 12:37 AM   #3079
PearlRex11
Member#: 284420
2011 WRX Sedan
Installed the Harman Motive rear sway bar and kartboy rear endlinks. I will save the front sway and endlinks for another day. I'm really liking the rear one so far though. I can tell a huge difference even over the sti rear I had on there, I actually got the rear end to come out a little (closed course obviously) but it felt very controlled and it was easy to control it as well. Will be interesting to see what difference the front makes.
PearlRex11 is offline   Reply With Quote
Old 07-13-2013, 02:10 PM   #3080
Celery GT-5
Member#: 98210
2002 WRX SRP
nice
so new development with the misfiring..sort of
i was playing around with hoses under the hood. took off the ic, made sure everything was tight, wiggled some stuff. Anyway I seem to have made it worse. It felt kind of odd when I was driving around like it was a bit more sluggish down low and it seemed to be engine braking faster tha usual..may have been my imagination, idk.
Anyway this morning I turned it on to log the idle. It was misfiring constantly for like 10 mins. I decided to shut it off and restart it for some reason and that just stopped it almost totally. Seems like some sort of fueling issue.
here is the log if anyone is curious
https://docs.google.com/file/d/0BxQF...it?usp=sharing
Old 07-15-2013, 10:53 AM   #3081
PearlRex11
Member#: 284420
2011 WRX Sedan
Have you thought about upgrading to the dw65? I was talking with Clark Turner and he seems to think it's a must even at stage 2. I've heard it's not a very difficult install and even if it doesn't fix your issue it definitely couldn't hurt?
Old 07-15-2013, 11:57 AM   #3082
Celery GT-5
Member#: 98210
2002 WRX SRP
what is dw65?
after doing some logging it seems like the right tgv motor is out of whack. You can see if you look at the log I posted that when the misfires are happening the angle is bouncing all over the place only on the right side. Eric and my friend pointed it out to me. I tried loosening the motor and twisting it to get it to read 82 degrees, seemed slightly better. Then I took it to the car wash and when the water sprayed my hood it misfired and the angle started bouncing around so it may be a loose wire or something stupid. It always seems worse in rain and humidity.
So I can either replace the motor if I can find one, delete the tgvs which seems like a pain or I believe I can just unplug them which will lock them in the open position and then disable the CEL's with rom raider.
Or I can try to use my warranty lol.
Old 07-15-2013, 12:32 PM   #3083
PearlRex11
Member#: 284420
2011 WRX Sedan
http://www.deatschwerks.com/products...s/dw65c-detail
It doesn't seem like that is your problem in this case but it's something I'm going to be looking into in the future. Glad you are getting to the bottom of this issue, a friend of mine that has minimal experience did his own tgv deletes so they may not be too bad. I would say go for warranty first though, that is if you have located a mod friendly stealership.
Old 07-15-2013, 12:52 PM   #3084
Celery GT-5
Member#: 98210
2002 WRX SRP
I'm sure a fuel pump wouldn't be a bad idea
I may just unplug them and disable the codes until the warranty is over lol
edit: although I'm finding conflicting info on what happens if you unplug them, some say they stay open and others say closed
Old 07-16-2013, 03:42 PM   #3085
corvid
Member#: 300097
Now my third gear is jumping around in revs at constant throttle on a smooth flat road at consistent speed. Wtf, time for another clutch? Replace 3rd? Also getting the feeling of engine braking at too high of speed-that bouncy, bucking motion in second and third at constant throttle. I have no idea what the issue is. Going to take it to the dealer, and probably hear from the mouth breathing service guy that I have been racing.. Ok.
corvid is offline   Reply With Quote
Old 07-16-2013, 03:45 PM   #3086
Celery GT-5
Member#: 98210
2002 WRX SRP
how many miles do you have?
sure sounds clutch related
Old 07-16-2013, 05:29 PM   #3087
corvid
Member#: 300097
13700 or thereabouts
great, another clutch issue. what the hell. Hopefully they'll just lemon it. Makes me want to get an sti just to avoid this kind of crap. I had the original replaced at 11k, including the throwout bearing. Not that I am an expert on transmission things, as far as I am concerned transmissions are magic potatoes.
Old 07-16-2013, 05:36 PM   #3088
Celery GT-5
Member#: 98210
2002 WRX SRP
sti wouldn't help you with clutch problems. maybe the dealer installed it wrong or didn't adjust the pedal travel after installing it. even if you beat the living **** out of it the clutch shouldn't be wearing out that often.
actually if its only 3rd gear I guess that makes it a tranny issue, not a clutch issue. if the clutch was going it would have have trouble if you punch it at a low rpm in 4th or 5th also.
Old 07-16-2013, 05:42 PM   #3089
corvid
Member#: 300097
well I haven't been going WOT at low rpms so havent seen anything there. Its 2nd and 3rd and this is at minimum the second big pain in the ass, so if it isnt the clutch, then I dont know what to do about it. I just dont want to hear some bull**** about how they cant replicate it, since they did that before then when I finally convince them to open it up, the clutch is crumbling and at like 10%.
Old 07-16-2013, 07:54 PM   #3090
Celery GT-5
Member#: 98210
2002 WRX SRP
Its rage trade in time! Let's get camrys
Old 07-16-2013, 08:18 PM   #3091
corvid
Member#: 300097
Yeah I miss driving the equivalent of a refigerator
Old 07-16-2013, 09:31 PM   #3092
Celery GT-5
Member#: 98210
2002 WRX SRP
Lol brz?
Old 07-16-2013, 09:45 PM   #3093
corvid
Member#: 300097
nah if I am going to spend money on a new car it needs to have balls. Plus, I like awd for mountain driving in the winter/crappy conditions
Old 07-16-2013, 10:01 PM   #3094
tcoffin014
Member#: 173734
2011 WRX
Sexy White Princess
I'm going to be rage trading in/selling within the next couple of years. I'm thinking either 06 STi or E46 M3
tcoffin014 is offline   Reply With Quote
Old 07-16-2013, 10:02 PM   #3095
Celery GT-5
Member#: 98210
2002 WRX SRP
Yeah I know
Hard to give up awd and boost
Old 07-16-2013, 10:12 PM   #3096
Celery GT-5
Member#: 98210
2002 WRX SRP
Yeah I'm constantly searching cars.com for those. Problem with older sti's is they are beat and insanely expensive. There is an 04 sti with 200,000 miles for 13k lol
Old 07-16-2013, 10:25 PM   #3097
corvid
Member#: 300097
used wrx/sti if you like blowing money for no reason other than the name (ie, used 2011 wrx just like mine would go for $26k, wat)
used bmw if you have access to cheap oem parts and the ability/means to fix everything
I wouldnt touch an out of warranty bmw/mb/audi with a 13 foot pole.
Old 07-16-2013, 10:27 PM   #3098
Celery GT-5
Member#: 98210
2002 WRX SRP
id like to get some sort of bmw one day to play around with but i wouldnt want it to be my main car
Old 07-16-2013, 10:40 PM   #3099
PearlRex11
Member#: 284420
2011 WRX Sedan
I can't see how the rpms would be jumping around if it was the transmission. Did you follow the 500 mile break in on the new clutch?
Old 07-16-2013, 11:51 PM   #3100
tcoffin014
Member#: 173734
2011 WRX
Sexy White Princess
Well obviously if I got an m3 I would save extra money for parts. I'm pretty mechanically inclined so any work needed would be performed by me. I just got ripped off at the dealership the other day and decided to NEVER bring my car anywhere to get it worked on. I have had pretty much a bad experience every time I've taken my car somewhere
Differences of 2011 wrx motor and 2011 sti motor stpkenton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-06-2012 11:03 AM
Differences of 2011 wrx motor and 2011 sti motor stpkenton Newbies & FAQs 3 05-12-2011 09:27 PM
2011 Subaru shifter fitment! All TWM Shifters still fit! TWM Performance Vendor Announcements 14 02-28-2011 03:27 PM
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb agentmaxwell Private 'For Sale' Classifieds 1 05-24-2006 07:41 PM
Attn: Clayton, Ben and all others involved in the 6MT discussion. sherifx Mid West Subaru Owners Club Forum -- MWSOC 1 07-31-2002 03:00 AM
