Old 07-17-2013, 12:21 AM   #3101
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
yeah I haven't let anyone touch my car aside for alignment and I think that was the shop my bro works it. I guess not taking it to subaru made my TGV go nuts
Celery GT-5 is offline   Reply With Quote
Old 07-17-2013, 01:41 AM   #3102
Vjaramillo
Member#: 359666
2013 Impreza limited
Ice silver
I had a e36 m3 with 126k and never had any issues with it. Did work one it myself and took it to my mechanic for major maintenance. Wasn't that expensive. It cost more for tires and rims than any mechanical parts.
Vjaramillo is offline   Reply With Quote
Old 07-17-2013, 01:48 AM   #3103
Celery GT-5
Member#: 98210
2002 WRX SRP
from what i've heard the e36s are more reliable and cheaper to maintain than e46s
Old 07-17-2013, 12:01 PM   #3104
tcoffin014
Member#: 173734
2011 WRX
Sexy White Princess
Well my most recent bad experience was for an alignment lol. So I'm going to be doing my own alignments now too
tcoffin014 is offline   Reply With Quote
Old 07-17-2013, 12:57 PM   #3105
Celery GT-5
Member#: 98210
2002 WRX SRP
I didn't get an alignment after installing my konis lol
Old 07-19-2013, 08:06 PM   #3106
corvid
Member#: 300097
So, rough idle, jumping RPMs at ~2k (constant throttle), solid CEL w/flashing cruise and TC off- code was all four cylinders were misfiring (just lovely). They think it was bad gas, so I need to run it down to near completely empty then refill with better Shell or Chevron gas (might even go E0) and see what that does. I am hoping it was bad gas and not something worse.
corvid is offline   Reply With Quote
Old 07-20-2013, 12:33 AM   #3107
Celery GT-5
Member#: 98210
2002 WRX SRP
that's sort of my problem. datalog your TGV angles. Although after a tank of vpower it seems better and I start questioning the TGV theory..lol. I think I'll just delete them and go from there
my highway mpg was terrible too, I got 22.4 on a 250 mile trip although I was hauling an engine and tranny, going 80 a lot of the way, it was 95-100 degrees and I'm using 0w40 now.
Old 07-20-2013, 12:43 AM   #3108
corvid
Member#: 300097
what about additives? I am going to run down the tank before a road trip, but I would rather not push the issue with the engine...although I seem to recall that they need to be added to an empty tank, not a tank 3/4 full
Old 07-20-2013, 12:46 AM   #3109
Celery GT-5
Member#: 98210
2002 WRX SRP
i tried techron, didn't seem to help. You are supposed to pour it in a near empty tank and then fill the tank.
idk it sure sounds similar to my issue
Old 07-20-2013, 01:01 AM   #3110
corvid
Member#: 300097
I see. Maybe Ill run it down as far as I can, then fill up with either shell or 0 ethanol and maybe give some cleaner a shot
Old 07-21-2013, 05:54 PM   #3111
corvid
Member#: 300097
Does torque pro allow for logging? Any other options? I don't have a tactrix or AP, so my options are limited to apps for now.
Since they reset everything its been running better but not like it used to, not my a long shot. Assuming bad fuel, I should stay out of boost/wot correct?
Sure is making the forester xt and brz look attractive.
Old 07-22-2013, 12:28 AM   #3112
Celery GT-5
Member#: 98210
2002 WRX SRP
I think torque can log but I don't know how. I guess avoid boost if you have no idea what's wrong
Old 07-22-2013, 02:32 PM   #3113
corvid
Member#: 300097
Not finding anything about tgvs in torque pro, but it does have a load of info. Pretty sweet having whatever gauges you want for $20 including bluetooth adapter.
Still having issues. I think the best plan would be to run the tank down asap and especially before a road trip, then dump in a bottle of techron and fill up with 0% ethanol. Logically that should compensate well for the apparently high ethanol I have now. Just a little less than 3/4 tank left lol. Its weird going from trying to be efficient to wanting to blast through gas (aka $$$).
Old 07-22-2013, 04:54 PM   #3114
Celery GT-5
Member#: 98210
2002 WRX SRP
why not take it to the dealer if you are stock?
Old 07-22-2013, 05:06 PM   #3115
corvid
Member#: 300097
I did, and was told to run down the tank then fill up with better gas, and to avoid places like Safeway, Fred Meyer, and Costco, as apparently they take the leftovers from other stations and don't have the additives Shell and Chevron offer.
I'm just hoping that I am not going to do some serious damage that will conveniently show up after the warranty is done, let alone put my car out of commission for a while.
Old 07-22-2013, 05:09 PM   #3116
Celery GT-5
Member#: 98210
2002 WRX SRP
my car seemed a little better after a tank of shell but I think its still just the TGVs...im not too worried about it though, I think the only thing these misfires would actually hurt are the cats which I don't have lol
Old 07-22-2013, 05:45 PM   #3117
corvid
Member#: 300097
Well Ill do what he said, run it down and fill with good fuel (pretty sure Ill do E0 and techron) then see how it goes. If it is still bad after that Ill take it back in.
Old 07-22-2013, 05:49 PM   #3118
Celery GT-5
Member#: 98210
2002 WRX SRP
is it misfiring while you are moving or just at idle?
Old 07-22-2013, 05:56 PM   #3119
corvid
Member#: 300097
I think both, but definitely at idle. I did the exhaust thing posted earlier and can feel it, if that is legit. It seems to coincide with the rough idle.
Still runs crappy while moving.
Old 07-22-2013, 06:16 PM   #3120
Celery GT-5
Member#: 98210
2002 WRX SRP
mine feels a little weird when cruising sometimes but when you get on it, it seems fine. Also the MPG seems fine and I still have very little oil consumption so far. I don't think I will burn more oil with M1 0w40 since its thicker than 5w30 except at extremely cold temps but I'm still keeping an eye on it since its mobil 1.
Dealer down the road just got an 08 R32, maybe i'll trade it in for that lol
Old 07-23-2013, 01:32 AM   #3121
poorkim
Member#: 361697
2007 Subaru WRX
My car does the same thing!!!! It feels like misfiring and especially when I hit the gas it feels like a sputter!!! I've only been putting shell or chevron 91 with octane booster additive every other gas tank, but I think after running fuel from other gas stations and learning my lesson maybe my fuel pump/filter is going out? Because the problem still randomly continues, no check engine lights or codes?
poorkim is offline   Reply With Quote
Old 07-23-2013, 01:46 AM   #3122
SWP is Sexy
Member#: 302389
2011 WRX
I'm a stormtrooper pewpew
Octane booster is useless, I've never seen any evidence that it does anything. I'd say use your money on two more gallons of good gas instead
SWP is Sexy is offline   Reply With Quote
Old 07-23-2013, 01:47 PM   #3123
corvid
Member#: 300097
Most are crap, but there are apparently legit options like Torco.
Most raise the octane rating a few points meaning you'd go from 91 to 91.2.
Old 07-23-2013, 10:18 PM   #3124
PearlRex11
Member#: 284420
2011 WRX Sedan
I have heard this about torco as well. I believe it was recommended to me from someone at cobb as a matter of fact. I think most boosters are crap though.
PearlRex11 is offline   Reply With Quote
Old 07-26-2013, 04:42 PM   #3125
corvid
Member#: 300097
Getting "Not OK" on torque for o2 bank 4 sensor 4...I don't get it. no other issues I can see. I wish it would read oil temp though.
Got my 20 ounce techron bottle and only 50% of the tank to go. I figure I will pour all but a little in when I fill up with zero ethanol, then save the remainder for the next fill up which would come up pretty quick after the 200 mile trip.
Idle is still rough but better than it was. The way I understand it, it's inevitable that the issues will return as long as I have the bad fuel. Hopefully I can burn through it before the rev bouncing returns... I'll probably make a YouTube account and load the videos.
Differences of 2011 wrx motor and 2011 sti motor stpkenton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-06-2012 11:03 AM
Differences of 2011 wrx motor and 2011 sti motor stpkenton Newbies & FAQs 3 05-12-2011 09:27 PM
2011 Subaru shifter fitment! All TWM Shifters still fit! TWM Performance Vendor Announcements 14 02-28-2011 03:27 PM
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb agentmaxwell Private 'For Sale' Classifieds 1 05-24-2006 07:41 PM
Attn: Clayton, Ben and all others involved in the 6MT discussion. sherifx Mid West Subaru Owners Club Forum -- MWSOC 1 07-31-2002 03:00 AM
