Old 08-02-2013, 12:46 AM   #3151
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
well its hard to say if cant datalog it. if you have the same weird tgv issue that i have it should be fine. if you truly had bad gas you just need to keep driving until it clears but from what I hear problems that are actually from bad gas are pretty rare.
have you noticed any power loss?
Celery GT-5 is offline   Reply With Quote
Old 08-02-2013, 01:47 AM   #3152
corvid
Member#: 300097
Not particularly, but I am also not tracking the car so if there is a loss, I'm not seeing it. Maybe Ill bring it in, although without codes I dont think theres anything they can do really...and torque has no data relating to the tgv...pretty much only the o2 sensors are the only relevant things
corvid is offline   Reply With Quote
Old 08-02-2013, 02:17 AM   #3153
Celery GT-5
Member#: 98210
2002 WRX SRP
Don't you ever accelerate hard, redline a gear or something? go WOT?
it took my car something like a year of on and off weird idle before the codes showed up.
Old 08-02-2013, 02:28 AM   #3154
corvid
Member#: 300097
Close to those, but I havent really had an opportunity since getting the gas.
edit- went out, doesnt seem to be underperforming as far as I can tell. A little rough on acceleration and still a rough idle but thats about it.
Old 08-02-2013, 09:49 AM   #3155
Celery GT-5
Member#: 98210
2002 WRX SRP
hrm if its rough on acceleration you should probably be careful, mine is sometimes rough when its cruising but when I get on it seems smooth
Old 08-02-2013, 03:27 PM   #3156
corvid
Member#: 300097
Ok ill take it easy, which I was going to do anyway seeing as how my tank is filled with liquid gold.
Well that and I would rather avoid a ticket... Gone the whole time I've had this car without even getting pulled over. Knock on wood
Old 08-02-2013, 03:51 PM   #3157
Celery GT-5
Member#: 98210
2002 WRX SRP
radar detector ftw
Old 08-02-2013, 06:24 PM   #3158
corvid
Member#: 300097
radar detector ftw
Indeed. I have it mounted high and hidden with a mute button by the ebrake. Its definitely saved me a few times where i am not paying attention and slowly get to 10 over.
Old 08-02-2013, 06:55 PM   #3159
Celery GT-5
Member#: 98210
2002 WRX SRP
I got mine back in 2005, the only clocked ticket I've has since then was when I was driving my grandparents radar detectorless MDX though a little speed trap town..lol
Old 08-04-2013, 01:38 AM   #3160
Celery GT-5
Member#: 98210
2002 WRX SRP
is that a tranny leak? lol
Old 08-09-2013, 10:37 PM   #3161
tcoffin014
Member#: 173734
2011 WRX
Sexy White Princess
What's the proper brake bleeding order for our cars? I've searched and heard of people using both methods: pf, dr, df, pr and pr, dr, pf, df. Which one's right? Or does it even matter?
tcoffin014 is offline   Reply With Quote
Old 08-09-2013, 11:38 PM   #3162
G2Spfld
Member#: 354284
2013 Imp Sport CVT
I always started with farthest away and worked in. PR,DR,PF,DF. If your changing fluid, I would buy the Motive bleeding kit, like $75 or so and it holds new fluid and pumps old fluid out. Just crack PR to force bleed old fluid and air out till you see new fluid then just crack the others to drain local old fluid out till new fluid comes out and your finished. 1 person can change fluid and bleed air in under 10 minutes. And the system is pressure flushed at same time. Makes it very easy to change fluid routinely. And your ABS will love you for it.
http://www.fastwrx.com/mopobl.html
G2Spfld is offline   Reply With Quote
Old 08-09-2013, 11:53 PM   #3163
tcoffin014
Member#: 173734
2011 WRX
Sexy White Princess
I've thought about that, but I have someone to help me so I don't think it will be too bad. Thanks
Old 08-09-2013, 11:55 PM   #3164
G2Spfld
Member#: 354284
2013 Imp Sport CVT
No worries
Old 08-10-2013, 07:38 AM   #3165
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Our brakes work in banks which is passengers rear inner then outer, then drivers front inner then outer, drivers rear inner then outer, last is passengers front inner then outer.
The goal is removing all of the old fluid and replace it with new fluid without any air bubbles.
You tube has many good videos how to do it
Louie is offline   Reply With Quote
Old 08-10-2013, 02:05 PM   #3166
tcoffin014
Member#: 173734
2011 WRX
Sexy White Princess
Now I'm confused again lol. I understand how to do it. I just don't know the order. I guess it doesn't matter too much since I've heard of people using both sequences
Old 08-10-2013, 02:32 PM   #3167
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Well.. Give it a shot. if you have a brake failure...you'll know why it failed.
Just kidding.
Old 08-11-2013, 12:57 AM   #3168
Celery GT-5
Member#: 98210
2002 WRX SRP
so my stock tires are getting some inner camber wear. Any replacement recommendations? I'd like to get wheels too but everything is either a knock off or crazy expensive or an rpf1..lol
Old 08-11-2013, 09:41 AM   #3169
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Enkei I think is the cheapest wheel without paying $500 a wheel(which seems to be a bargain these days). But enkei has the rajin which looks nice for around $1200.
As far as tires...conti dws
I know a guy who is selling 18x9.5 weds tc105n.
Old 08-11-2013, 03:07 PM   #3170
Celery GT-5
Member#: 98210
2002 WRX SRP
Well I don't need all seasons so I may go for conti DW, I had some on my G35 and they were pretty good
http://www.tirerack.com/tires/tires....omCompare1=yes
those raijin's are pretty nice, didn't realize they came in 18x8.5 and 18x9.5 and 5x100
Old 08-11-2013, 03:19 PM   #3171
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Lol, I didn't realize the app changed DW to DWS. I am getting a set for my new bbs wheels.
Old 08-11-2013, 06:50 PM   #3172
Celery GT-5
Member#: 98210
2002 WRX SRP
Yeah they are good tires. Sidewalls are a bit soft, but great for spirited daily driving.
Its probably between those and potenza S-04s or w/e
Old 08-11-2013, 06:53 PM   #3173
SWP is Sexy
Member#: 302389
2011 WRX
I'm a stormtrooper pewpew
The only thing I don't like about the Raijins is the sharp bend angle on the spokes as they come to center. Wish it was a smoother curve
SWP is Sexy is offline   Reply With Quote
Old 08-11-2013, 07:40 PM   #3174
Celery GT-5
Member#: 98210
2002 WRX SRP
they seem like fake BBS's to me..idk
they don't look great on white
Old 08-13-2013, 09:03 PM   #3175
PearlRex11
Member#: 284420
2011 WRX Sedan
Celery, did you find the oil you are going with? Just did my second change in mine and also my friends with the t6, still happy with it so far.
Got around to installing my front sway bar with the kb endlinks. The endlinks don't line up the way I want them to, even with some spacers in there, (not the actual kb spacers) I didn't notice I needed to add spacers for the whitline bar until I was installing it. The alignment of the endlink is off for sure and causes them to make a pop noise if I turn it really hard, I need to order the actual kb spacers and figure out the right set up. Great improvement in handling so far though!
PearlRex11 is offline   Reply With Quote
Differences of 2011 wrx motor and 2011 sti motor stpkenton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-06-2012 11:03 AM
Differences of 2011 wrx motor and 2011 sti motor stpkenton Newbies & FAQs 3 05-12-2011 09:27 PM
2011 Subaru shifter fitment! All TWM Shifters still fit! TWM Performance Vendor Announcements 14 02-28-2011 03:27 PM
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb agentmaxwell Private 'For Sale' Classifieds 1 05-24-2006 07:41 PM
Attn: Clayton, Ben and all others involved in the 6MT discussion. sherifx Mid West Subaru Owners Club Forum -- MWSOC 1 07-31-2002 03:00 AM
