Old 08-19-2013, 06:25 PM   #3201
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
I'm at 26000 too, its starting to feel slightly notchy but it may be my imagination
I think I might change the gear oil soon because I'll probably hit 30k when its cold out
Celery GT-5 is offline   Reply With Quote
Old 08-19-2013, 06:27 PM   #3202
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Hmm well changing out your transmission fluid is a 30,000 mile maintenance so you're due for one at your next oil change.
xabre1200 is offline   Reply With Quote
Old 08-19-2013, 06:54 PM   #3203
Celery GT-5
Member#: 98210
2002 WRX SRP
yeah, its close enough
Old 08-19-2013, 09:21 PM   #3204
PearlRex11
Member#: 284420
2011 WRX Sedan
Originally Posted by xabre1200 View Post
Anyone have issues with shifting gears? I've heard of people changing their transmission fluid out and turning their crunchy gear boxes into very smooth shifting ones. I'm only at 26,000 miles and have occasionally experienced resistance into 3rd gear when shifting.
I have a friend that did the 30k maintenance on his and used motul tranny fluid. He swears it made it completely smoother. He also said he can downshift into 1st at higher speed than before. I'll be using motul in mine, couldn't hurt.
PearlRex11 is offline   Reply With Quote
Old 08-19-2013, 09:29 PM   #3205
Celery GT-5
Member#: 98210
2002 WRX SRP
or you could use the uncle scotty cocktail
http://www.grimmspeed.com/catalog/pr...products_id=76
Old 08-19-2013, 09:52 PM   #3206
PearlRex11
Member#: 284420
2011 WRX Sedan
Curious how someone came up with that concoction. Lol
Old 08-19-2013, 10:06 PM   #3207
Celery GT-5
Member#: 98210
2002 WRX SRP
yeah idk
Old 08-19-2013, 10:07 PM   #3208
Poptart1318
Member#: 230510
2011 MX-5
I had the same experience. Between 25-30k miles the transmission started feeling notchier, shifts were generally not as smooth and it would barely go into first at anything other than a full stop. Finally got around to replacing the trans/diff fluid with Motul around 32k miles and it felt brand new again, the difference was noticeable immediately. Have around 7k miles on the new fluid at this point and it still feels great.
Poptart1318 is offline   Reply With Quote
Old 08-19-2013, 11:40 PM   #3209
Celery GT-5
Member#: 98210
2002 WRX SRP
unabomber says:
What brand/type of transmission fluid should I use and how do I do it myself?
The Subaru 5MT can be a picky about what fluid you should use. Popular fluids that have a large fan base are:
a. OEM fluid AKA Subaru Extra-S
b. Uncle Scotty's Cocktail of 1qt Redline lightweight shockproof, 1qt Pennzoil or GM Synchromesh, 2qt Castrol HypoyC 80w-90
c. Redline lightweight shockproof
d. Motul 300
While we are big fans of sticking to OEM fluids on NASIOC, this is one case where using something not SOA recommended has shown actual benefit, mainly in helping with synchro interaction.
You 6MT users can use whatever you like, though there is some benefit by using one of the above fluids as they do aid in synchro engagement.
Old 08-19-2013, 11:41 PM   #3210
Celery GT-5
Member#: 98210
2002 WRX SRP
double post
Old 08-20-2013, 09:23 AM   #3211
tcoffin014
Member#: 173734
2011 WRX
Sexy White Princess
I used motul at around 30k and it's been much better ever since. I'm at 45k now. Reverse is easier to get into and also first while moving. I had some problems with second and third gear before too, but that went away with the motul
tcoffin014 is offline   Reply With Quote
Old 08-20-2013, 12:59 PM   #3212
Celery GT-5
Member#: 98210
2002 WRX SRP
Originally Posted by corvid View Post
Cliffs: possible egv issue
anything more on this?
Old 08-20-2013, 02:57 PM   #3213
G2Spfld
Member#: 354284
2013 Imp Sport CVT
X2- I'm curious as well
G2Spfld is offline   Reply With Quote
Old 08-20-2013, 09:25 PM   #3214
corvid
Member#: 300097
Won't know anything real for a little while, until it has been taken in and checked out. The tech was a master tech and saw exactly what I was talking about and agrees there is a problem which is half the battle. He says tgv is a non issue here, but might be egv, though he isn't sure and is going to research. Apparently other models he's seen have had similar issues.
corvid is offline   Reply With Quote
Old 08-20-2013, 09:42 PM   #3215
Celery GT-5
Member#: 98210
2002 WRX SRP
well its a start
Old 08-21-2013, 07:08 PM   #3216
corvid
Member#: 300097
Its a start but my appointment cant come fast enough. All the symptoms are coming back- rough bouncy idle, nearly stalling when backing out of my driveway, jumping/bouncing tach at relatively low engine speed, etc. Now it is getting to be at a higher rpm range, closer to 2500. Its most definitely not gas, and the weather has changed back and forth enough that it isnt likely to be the cause- humidity was high and low, temperatures are cool overnight and about 75 in the day, no rain, no real variation in pressure or weather.
Old 08-21-2013, 07:22 PM   #3217
SWP is Sexy
Member#: 302389
2011 WRX
I'm a stormtrooper pewpew
Maybe the MAF? Sounds similar to vacuum leak symptoms too
SWP is Sexy is offline   Reply With Quote
Old 08-21-2013, 08:35 PM   #3218
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
I would start by cleaning the MAF sensor. Swapping out my intake and stock air filter box between dealership warranty claims caused my MAF sensor to become dirty causing my car to have a hard time starting.
Old 08-21-2013, 08:47 PM   #3219
corvid
Member#: 300097
Ill check into that. I've seen different techniques from just a quick spray to downing the maf in maf cleaner. Whats broscience and whats legitimate? I might just mention it to the shop and see what they say.
Old 08-21-2013, 08:59 PM   #3220
Celery GT-5
Member#: 98210
2002 WRX SRP
i doubt its a dirty maf on a relatively new car
Old 08-21-2013, 09:51 PM   #3221
corvid
Member#: 300097
True, since its still under 15k...could still be possible. What else could it be? It seems like all the easy, simple answers are out.
Old 08-21-2013, 10:29 PM   #3222
Celery GT-5
Member#: 98210
2002 WRX SRP
idk, I'm pretty stumped about my own car aside from the tgv possibility, luckily it seems better now in my case. It could be one of those things that is hard to figure out until it gets more severe. Probably no harm in cleaning your maf though.
Old 08-22-2013, 01:26 AM   #3223
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Just keep bringing it to your dealership. If they can't fix it claim lemon law.
Old 08-22-2013, 01:29 AM   #3224
corvid
Member#: 300097
Yeah that will be the in the future if they cant fix it. I'll leave it to them to figure out, they certainly know more about cars than myself...plus I trust them
Old 08-22-2013, 11:29 AM   #3225
sebs
Member#: 331200
2012 impreza sport
grey
Has anyone "vinyl tinted" their tail lights on a 2012 impreza sport? I've got a grey one and I'm attempting to tint them matte black. I did the bumper reflectors and 3rd break light and it looks great. The tail lights are very intimidating. Any help or suggestions?
sebs is offline   Reply With Quote
Differences of 2011 wrx motor and 2011 sti motor stpkenton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-06-2012 11:03 AM
Differences of 2011 wrx motor and 2011 sti motor stpkenton Newbies & FAQs 3 05-12-2011 09:27 PM
2011 Subaru shifter fitment! All TWM Shifters still fit! TWM Performance Vendor Announcements 14 02-28-2011 03:27 PM
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb agentmaxwell Private 'For Sale' Classifieds 1 05-24-2006 07:41 PM
Attn: Clayton, Ben and all others involved in the 6MT discussion. sherifx Mid West Subaru Owners Club Forum -- MWSOC 1 07-31-2002 03:00 AM
