Old 09-10-2013, 06:25 PM   #3276
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
yeah i get little oddities when I'm cruising too..but its been better...weird
Celery GT-5 is offline   Reply With Quote
Old 09-10-2013, 08:55 PM   #3277
rwfloberg
Member#: 327538
2012 WRX (307/344)
Im coming up on brakes. How noticeable is getting stainless steel lines? Also, are most of you getting rotors on first pad change, or simply pads. Ive always done just pads in the past, but under light braking I get a minor wheel shimmy.
rwfloberg is offline   Reply With Quote
Old 09-10-2013, 08:58 PM   #3278
Asharus
Member#: 276300
2015 Ford Mustang GT
Oxford White
my pads are still good at 60k, what mileage are you at?
Asharus is offline   Reply With Quote
Old 09-10-2013, 09:00 PM   #3279
Celery GT-5
Member#: 98210
2002 WRX SRP
Old 09-10-2013, 09:34 PM   #3280
rwfloberg
Member#: 327538
2012 WRX (307/344)
35k
Maybe im being a little ambitious with brake change lol
Old 09-10-2013, 09:41 PM   #3281
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
SS lines are good.. Less pedal squish... Master cylinder brace is a good pedal feel mod
Louie is offline   Reply With Quote
Old 09-10-2013, 09:58 PM   #3282
Dka67
Member#: 296721
11 5door
This^. And Oil!
Dka67 is offline   Reply With Quote
Old 09-10-2013, 10:03 PM   #3283
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
35k
Btw, I replaced my brakes at 5k miles
Old 09-10-2013, 11:11 PM   #3284
Asharus
Member#: 276300
Oxford White
35k
nah, just depends on driving conditions. im about 80% highway and im really good at engine braking / not tailgaiting so i dont use the brakes much.
Old 09-10-2013, 11:14 PM   #3285
Celery GT-5
Member#: 98210
2002 WRX SRP
i want to do the brakes just because they feel crappy lol
Old 09-11-2013, 06:39 AM   #3286
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
...because you use your feet to slow your 3300lb sled to a stop? Just kidding. I wish I has more highway miles on mine
Old 09-11-2013, 12:10 PM   #3287
rwfloberg
Member#: 327538
2012 WRX (307/344)
Im probably 75% highway
Loui do you think the stainless steel lines are worth the $100? Mines a DD seen a drag strip twice. Im willing to spend the money if its a worthwhile upgrade, but if its just a marginal upgrade Id rather spend $100 elsewhere
Old 09-13-2013, 10:08 AM   #3288
tcoffin014
Member#: 173734
2011 WRX
Sexy White Princess
I just had to go talking about how my blinker was fixed. I've noticed it do the fast blinking a couple of times but only right when I turn it on then it goes to normal. Maybe the bulb is actually going out this time
tcoffin014 is offline   Reply With Quote
Old 09-13-2013, 10:31 AM   #3289
SWP is Sexy
Member#: 302389
2011 WRX
I'm a stormtrooper pewpew
Did you have the dealership replace the wiring already? That was a very common problem, happened to mine within 1k and I just took it into the dealership and they had it fixed within an hour
SWP is Sexy is offline   Reply With Quote
Old 09-13-2013, 10:35 AM   #3290
Celery GT-5
Member#: 98210
2002 WRX SRP
i wiggled it and its been fine for over 2 years lol
Old 09-13-2013, 10:47 AM   #3291
Asharus
Member#: 276300
Oxford White
mine started acting up after about 3 months or less. i read about the harness issue here and took it in and told them about it. all they did was replace the bulb though, no problems since.
Old 09-13-2013, 10:48 AM   #3292
Asharus
Member#: 276300
Oxford White
btw that was the only warranty work theyve performed on the car, besides the weak fuel door spring. now im at 60k miles
Old 09-15-2013, 10:02 PM   #3293
Celery GT-5
Member#: 98210
2002 WRX SRP
got some conti DW's ftw
they seem way better for highway cruising
also currently reading 27.9mpg after about 200 miles of driving
Old 09-16-2013, 12:15 AM   #3294
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Wanna update you guys on my car. About 2 weeks ago I took my car into the dealership to diagnose a funny whirling noise I was hearing in my transmission. Dealership found it was a misaligned part in the tranny, fixed it and sent me along my way. That night I noticed my clutch creaking as I let the clutch up from the floor though not when I pressed it down. I had a similar issue a year ago where I had a defective throw out bearing and had that warrantied.
I brought my car back to the dealership and they called me the next day saying I've got a defective pressure plate and theyre going to need to basically do the same thing they did on my car a year ago.
I'm glad that they're going to give me a new clutch and all but I'm worried about this happening again in a year. Is my car just being a lemon or do I just have some massive bad luck. They say my clutch wear is normal and told me they were both manufacture defects... any one have any insight? I'm just worried about this happening again and my car not being under warranty in a few years.
xabre1200 is offline   Reply With Quote
Old 09-16-2013, 01:44 AM   #3295
PearlRex11
Member#: 284420
2011 WRX Sedan
I've heard that a lot of people have been having clutch related issues. I know mine had to be replaced under warranty due to slipping when taking of and squeaking due to the excessive amount pressure needed to press my clutch in. I hope mine lasts me longer than another 25k.
PearlRex11 is offline   Reply With Quote
Old 09-16-2013, 02:38 AM   #3296
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Yeah it's a real shame. I'm worried about this issue in the long run especially since it's the 2nd time it's happened to me.
Old 09-16-2013, 06:07 PM   #3297
tcoffin014
Member#: 173734
2011 WRX
Sexy White Princess
I had the squeak too. The first time they replaced the throw out bearing and clutch fork. They said it was wearing weird. The second time the replaced the clutch fork, master cylinder, slave cylinder? (maybe), and I bought an aftermarket clutch kit with flywheel, clutch disk, pressure plate and throw out bearing. It was doing fine for a while after all of that. Now it's starting to squeak again. I have no idea what it is but I'm starting to think it's just one of those weird things that has no cure for now. I'm just hoping it won't ruin my car. I have 45000 miles. I just want to sell my car and get an 07 sti
Old 09-16-2013, 06:20 PM   #3298
Celery GT-5
Member#: 98210
2002 WRX SRP
Car is misfiring again
Old 09-16-2013, 06:51 PM   #3299
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
You guys need to mod more. No issues here.
rsutton1223 is offline   Reply With Quote
Old 09-16-2013, 07:10 PM   #3300
corvid
Member#: 300097
Same.
corvid is offline   Reply With Quote
Differences of 2011 wrx motor and 2011 sti motor stpkenton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-06-2012 11:03 AM
Differences of 2011 wrx motor and 2011 sti motor stpkenton Newbies & FAQs 3 05-12-2011 09:27 PM
2011 Subaru shifter fitment! All TWM Shifters still fit! TWM Performance Vendor Announcements 14 02-28-2011 03:27 PM
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb agentmaxwell Private 'For Sale' Classifieds 1 05-24-2006 07:41 PM
Attn: Clayton, Ben and all others involved in the 6MT discussion. sherifx Mid West Subaru Owners Club Forum -- MWSOC 1 07-31-2002 03:00 AM
